Walking to Rosewater
[17:58] <@Ebiris> roll 1d20+65+15 spending a round to pop divine insight
[17:58] <Penuche> Ebiris invokes Penuche's magic: < 99 > [d20=19]
So we're on round 3 of 4 now.
The ritual looks to have fed the souls right into Violet. She's receptive to them somehow, deeper magic and workings wrought within her. With that and the sheer weight of the souls taken in the ritual, Violet is swollen with power.
Normally yes without incident. In this case it would require a particularly potent unbinding or the like - this is a little more than a typical situation, but if you're fast it might work.
She's a goddess of liberation so she might as well do something right today. She starts to cast it then...
Unbinding has a casting time of 1 round, so I can cast it on the last round of the time stop and it'll go off when the time stop ends and Violet is an acceptable target.
Alicia HP: 1044+20/1044
Active spells:  Extended greater anticipate teleportation (CL 35), extended mind blank (CL 35), extended nondetection (CL 35), epic mage armour (CL 39), pass without trace (CL 34), greater heroism (CL 34), energy immunity (acid) (CL 34), energy immunity (sonic) (CL 34), telepathic bond (CL 34), sensual blessing (CL 34), recitation (CL 34), foresight (CL 34), greater visage of the deity (CL 34), power of the huntress (CL 34), repelling shield (CL 34), spell turning (CL 35), righteous wrath of the faithful (CL 34), invisibility (CL 34), opal protection (CL 35), celestial valor (CL 35), life's grace (CL 35), Seira's arcane thesis (CL 34), brilliant aura (CL 34), Latha's sunmantle (CL 34), keen edge (CL 34), extended dance of the unicorn (CL 35), many moments of prescience (CL 34)
Defences: AC 114, CMD 136, spell resistance 49, energy immunity (fire, cold, acid, sonic), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 49), freedom of movement
Stat buffs/penalties: +10 armour AC, +10 circumstance stealth, +4 morale attack/saves/skills, +3 luck AC/attack/saves, +2 insight AC/reflex, +15 natural armour, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, -8 size attack/AC, +20 competence stealth, +8 enhancement natural armour AC, +9 shield AC, +3 morale damage, +3 morale AC, +4 sacred attack/damage/AC/saves, +10 CL vs SR, +5 spell DCs
Sorcerer spell slots: 6/16/16/12/9/9/14/9/4/5/8/1/4/4/2
Duskblade spell slots: 6/23/23/19/11/7/9
Okay. So you mean for it to go off once it ends, preemptively?
Yes. I start casting in round 4 of the time stop. It takes one round to cast, so when that round ends, the time stop both ends and the unbinding takes effect. The long casting time plays to my benefit here because I couldn't do this if it was a standard action to cast, since my turn is over outside of the time stop.
Sure. Gimme a CL on it and I'll adjudicate.
[18:49] <@Ebiris> roll 1d20+37
[18:49] <Penuche> Ebiris invokes Penuche's magic: < 49 > [d20=12]
Your magic is strong - the moment the timestop ends, it slams into Violet. There's a horrible moment when she writhes about, before some of them escape. Handful after handful of souls, rushing out from her. "You bitch!" She snaps at that, a moment of raw, furious anger. You feel her resist, some slipping back in while others escape - more escape you think, but not all - until with a shudder she lets out a godawful belch, souls erupting out from her mouth. A new torrent as more escape from her, more and more and more.
"AGH!" Then it stops, like a tap turned off, a death glare your way.
"Save the gloating until it's a done deal," Alicia scoffs contemptuously. She can take some measure of satisfaction out of this miserable outing.
> roll 1d20+14 group init for the dragons for the sake of my ease.
<Penuche> Kotono invokes Penuche's magic: < 19 > [d20=5]
> roll 1d20+51 Pazuzu Avatar
<Penuche> Kotono invokes Penuche's magic: < 53 > [d20=2]
> roll 1d20+48 Violet
<Penuche> Kotono invokes Penuche's magic: < 65 > [d20=17]
> roll 1d20+24 Antenora
<Penuche> Kotono invokes Penuche's magic: < 30 > [d20=6]
> roll 1d20+23 Syala
<Penuche> Kotono invokes Penuche's magic: < 43 > [d20=20]
> roll 1d20+24 Latha
<Penuche> Kotono invokes Penuche's magic: < 31 > [d20=7]
Init is Alicia (Supreme Init) > Violet (65) > Pazuzu (53) > Syala (43) > Latha (31) > Antenora (30) > Dragons (19) > ???? (0)
Violet rights herself in the air, a negligent gesture at you, "But it doesn't matter, I have so much," she laughs, "So many ways and paths to power now! I've found something no one can match!" You sense it - the magic of druids flows through her, great spears of stone rising out of the earth to curve in at you, jabbing and trying to impale you from all directions.
Reflex.
Power of the huntress (CL 34), +8 enhancement natural armour, +20 competence stealth, +6 init, gains combat reflexes and can't be flat-footed. - These are all somewhat situational or overlap, so apply case by case.
Antenora
HP: 986+20/986
Bonuses: Attack+16 (+5 blessing, +4 sacred, +3 luck, +4 morale), Damage+14 (+7 blessing, +4 sacred, +3 morale), AC+15 (+5 blessing, +4 sacred, +3 morale, +3 luck), Saves+21 (+10 blessing, +4 sacred, +3 luck, +4 morale), Skills+9 (+19 stealth)(+5 blessing+4 morale), Checks+5 (+5 blessing) extra attack per round +2d6 if weapon isn't holy
Resources: Holy Fury 37/37 (enc) Divine Retribution 1/1 Smite Evil 12/12 Channel Energy 17/17 Lay On Hands 476/476 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 25/25 Divine Blast 17/17
Spells Used: Opal Protection
SLAs Used:
Spells Active: Mind Blank (CL35), Nondetection (CL35), Epic Mage Armor (CL39), Pass Without Trace (CL34), Mass Camouflage (CL34), Mass Energy Immunityx2 (Acid, Sonic) (CL34), Recitation (CL34), Righteous Wrath of the Faithful (CL34), Mass Power of the Huntress (CL34), Opal Protection (CL35), Celestial Valor (CL35), Power of the Huntress (CL34)
Typical Charging Numbers: 34 for base smite damage, 68 for charging smite +2 per per level. So 102 bonus damage baseline. Raw attack plus smite is 1d8+135+2d6+2d6 (+4/+4d6 if fiendbane hits). Doesn't include other factors.
Latha
HP: 756+20/756
Aura: Holy Light 30ft (7d6+7 damage vs evil/round) Protective 20ft (+4 deflection/+4 resistance vs evil)
Bonuses: Attack+16 (+5 blessing, +4 sacred, +3 luck, +4 morale), Damage+12 (+5 blessing, +4 sacred, +3 morale), AC+15 (+5 blessing, +4 sacred, +3 morale, +3 luck), Saves+21 (+10 blessing, +4 sacred, +3 luck, +4 morale), Skills+9 (+19 stealth)(+5 blessing+4 morale), Checks+5 (+5 blessing) extra attack per round +2d6 if weapon isn't holy
Resources: Channel Energy 14/14 Sun Devotion 4/4
Spells Used: Vivacious Empowered Righteous Smite, Celestial Valor, Mass Energy Immunityx2
SLAs Used:
Notes: Level + 17 extra damage per hit vs undead during sun devotion.
Syala
HP: 680+20/680
Spells Used:
SLAs Used:
[19:43] <@Ebiris> roll 1d20+60
[19:43] <Penuche> Ebiris invokes Penuche's magic: < 69 > [d20=9]
> roll 35d8
<Penuche> Kotono invokes Penuche's magic: < 145 > [d8=1,7,1,6,4,4,4,5,1,2,6,5,4,3,2,2,2,1,7,3,1,6,5,2,8,7,2,4,3,6,7,4,8,7,5]
> roll 145/2
<Penuche> Kotono invokes Penuche's magic: < 72 >
> roll 145+72
<Penuche> Kotono invokes Penuche's magic: < 217 >
> roll 217/2
<Penuche> Kotono invokes Penuche's magic: < 108 >
108 damage.
You are thrust against, wellings of blood under your armor as you hold tight against them. At this Violet utters another word, suddenly a flow of black water that erupts towards the Styx, flying fast and swift.
This does provoke an AoO, if you care to attack her watery form at the moment.
I have lots of AoOs right now, so yes.
[20:01] <@Ebiris> roll 1d20+81
[20:01] <Penuche> Ebiris invokes Penuche's magic: < 90 > [d20=9]
[20:01] <@Ebiris> roll 6d6+49+3d6+2d6
[20:01] <Penuche> Ebiris invokes Penuche's magic: < 97 > [d6=6,6,6,4,3,3,6,6,4,1,3]
Alicia HP: 956/1044
Alicia cleaves down into the dark waters. She cuts some of it away but more keeps going, joining the Styx. At the same time...
With a cry of furious defiance, Pazuzu takes to the air. His blade is in hand, slashing out as he comes right for you.
This does not provoke an AoO as he has a means to get around provoking one form aerial movement.
> roll 1d20+85 (+5 ???, +8 ???, +5 ???, +1 ???, +1 ???, +4 ???, +1 ???, -10 PA)
<Penuche> Kotono invokes Penuche's magic: < 91 > [d20=6]
AC?
