21 II
Started by Anastasia, December 10, 2019, 01:41:13 PM
Nothing happens as you approach it. Emily comes with you. "Careful," she warns, "Mom's had many bad experiences with books before she ascended. There are bad books."
"Such as the book that's the reason we're here? Either we walk away or open it...."
> roll 1d20+27 ???
<Penuche> Kotono invokes Penuche's magic: < 39 > [d20=12]
"We open it," Xandra says, "Let us not pretend this is not designed."
"I see no reason not to," Dolmaya seconds, "It should be opened."
"Yes, agreed." Moore says. "Go on."
Alyssa uses her TK to open it!
The book opens. Amazingly, no terror immediately emerges and no calamity happens.
Alyssa begins to read!
> roll 1d20+27 ???
<Penuche> Kotono invokes Penuche's magic: < 47 > [d20=20]
The words are written in white.
The path ahead is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path because the path is not the path
The path is not the path.
I am the path.
Alyssa furrows her brow and starts flipping through the pages.
Give me an immediate Will save.
Do Moore bonus apply, Neph?
Will/Cunning Insight:
[blockquote]Rolled 1d20+37 : 5 + 37, total 42[/blockquote]
Anything that stops int/wis damage?
Depends on the source, but I don't think anything that applies here.
