Time to get big again!
Maybe she should just stay big as long as she's here?
Anyway, now suitably embiggened, Alicia sends out a wave of exhaustion to tire the giant yeti out!
Waves of exhaustion, no save just SR.
[18:37] <@Ebiris> roll 1d20+38 SR
[18:37] <Penuche> Ebiris invokes Penuche's magic: < 47 > [d20=9]
Alicia HP: 1074+240/1074
Active spells:  Many moments of prescience (CL 34), extended mind blank (CL 35), extended nondetection (CL 35), greater heroism (CL 34), repelling shield (CL 34), extended ray deflection (CL 35), epic mage armour (CL 35), dance of the unicorn (CL 36), recitation (CL 35), opal protection (CL 35)
Defences: AC 98, CMD 122, spell resistance 50, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 49)
Stat buffs/penalties: +4 morale skills/attack/saves, +9 shield AC, +10 armour AC, +25 competence perception, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size, +8 saves vs poison, +3 luck attack/saves, +3 morale AC
Sorcerer spell slots: 6/16/16/16/9/9/9/8/4/5/6/3/4/3/4
Duskblade spell slots: 6/23/23/16/10/7/3
Moments of prescience: 2
The yeti sags at this, fatigue washing over him in a wave. "Uuuuugh..." it groans, "Magic!"
Alicia's done, btw. Had a swift left but not using it.
> roll 1d20+13 Antenora
<Penuche> Kotono invokes Penuche's magic: < 15 > [d20=2]
> roll 1d20+12 Syala
<Penuche> Kotono invokes Penuche's magic: < 14 > [d20=2]
> roll 1d20+9 Yeti
<Penuche> Kotono invokes Penuche's magic: < 21 > [d20=12]
Init is Alicia (Supreme Init) > Ragarr (21) > Antenora (15) > Syala (14)
Shameful init.
Ragarr yawns deeply before he reaches up and tears away a giant hunk of stone from the ceiling, then hurtles it right at you.
> roll 1d20+67
<Penuche> Kotono invokes Penuche's magic: < 76 > [d20=9]
AC?
Yet you dodge this hunk with sublime ease as the yeti yawns again.
Antenora.
> roll 1d20+56 (+4 charge, +6 various, -10 PA)
<Penuche> Kotono invokes Penuche's magic: < 69 > [d20=13]
> roll 3d8+159+2d6
<Penuche> Kotono invokes Penuche's magic: < 178 > [d8=3,7,7][d6=1,1]
Antenora charges in, the yawning yeti not even lifting up a counter as she plunges her spear into his chest - for all it can do with the size difference. It grimaces and looks to her, "You annoying..." A yawn interrupts it as...
Syala.
Syala points as a looming treant matches the giant yeti, swinging hard for him. "Go!"
> roll 1d20+59 Syala
<Penuche> Kotono invokes Penuche's magic: < 68 > [d20=9]
> OOC: +6 more for bonuses on her.
> roll 35d10
<Penuche> Kotono invokes Penuche's magic: < 173 > [d10=4,7,10,5,7,5,10,5,1,8,3,5,4,4,4,7,2,3,2,8,3,4,6,1,2,4,2,2,10,8,3,7,5,6,6]
> roll 15d6
<Penuche> Kotono invokes Penuche's magic: < 59 > [d6=5,4,4,2,2,4,6,3,2,6,1,6,6,4,4]
The elder treant's blow sends the yeti careening to the side and into an impact with one of the ridges and crystalline formations, which it crashes into hard and lands in a heap. Antenora hangs on, spear stuck in him. She stands atop him when it's over, as the yeti struggles to rise.
Go.
Antenora
HP: 840/840
Bonuses: Attack+5 (+3 luck, +2 strength), Damage+3 (+3 strength) AC+6 (+3 morale, +3 luck), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Resources: Holy Fury 39/39 (enc) Divine Retribution 1/1 Smite Evil 13/13 Channel Energy 16/17 Lay On Hands 490/490 Remove Disease 10/10 (week), Spiritual Connection 3/3 Blinding Speed 24/25 Divine Blast 15/17
Spells Used: Healx2, Opal Protection, Opal Fury
SLAs Used:
Spells Active: Mind Blank (CL36), Recitation (CL36), Opal Protection (CL36), Opal Fury (CL36)
Syala
HP: 700/700
Bonuses: Attack+3 (+3 luck), Damage+0 AC+24 (+3 morale, +3 luck, +18 armor), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Spells Used: 1 8th level spell, 1 9th level spell, 1 10th level spell, 1 11th level spell, 1 12th level spell, 1 14th level spell.
SLAs Used:
Spells Active: Mind Blank (CL36), Energy Immunity(Fire)(CL35), Epic Mage Armor (CL35), Recitation (CL36), Opal Protection (CL36)
Walking closer now, Alicia brings her sword down in a heavy crushing blow onto Ragarr, careful to avoid Antenora!
[19:44] <@Ebiris> roll 1d20+63 blinding speed, -30 pa, quickened true strike
[19:44] <Penuche> Ebiris invokes Penuche's magic: < 79 > [d20=16]
[19:44] <@Ebiris> roll 6d6+118+2d6
[19:44] <Penuche> Ebiris invokes Penuche's magic: < 148 > [d6=4,2,6,6,5,2,3,2]
Duskblade spell slots: 6/23/23/15/10/7/3
The heavy blow hits hard, slamming down into his stomach. It's enough to knock the air from him, a gasping cry as he struggles. "Uuuurrrrghhhhh!" he roars, trying to get up.
Provokes from you and Antenora.
Another heavy sword swing comes down at that opening!
[20:14] <@Ebiris> roll 1d20+43 no true strike but same mods otherwise
[20:14] <Penuche> Ebiris invokes Penuche's magic: < 49 > [d20=6]
[20:14] <@Ebiris> roll 6d6+118+2d6
[20:14] <Penuche> Ebiris invokes Penuche's magic: < 149 > [d6=6,4,6,2,6,1,5,1]
> roll 1d20+62 (+6 various)
<Penuche> Kotono invokes Penuche's magic: < 75 > [d20=13]
> roll 1d8+33+2d6
<Penuche> Kotono invokes Penuche's magic: < 47 > [d8=5][d6=5,4]
Another blow and down the yeti goes, a yawning groan before it just lies there.
Free act.
"I don't think that really needed all three of us," Alicia says thoughtfully. "Oh well - Partanyx, lets keep going?"
"He was more size than anything else," Antenora agrees, "But a brave effort."
"Not every foe here is invincible," Syala agrees as you're lead along. "And it's not one battle here, it's a dozen. All he needed was to expend us, weaken us. Endurance matters here."
"But is it satisfying for the one who fights us later if they don't get to experience us at our best?" Alicia asks. "The feel I usually get with Ysgard battles is everyone wants a legendary duel of their own, rather than everyone working together to slowly bleed the enemy over time."
"Be that as it may, we're popular," Syala says, "And I bet all of them understand combat and tactics, including Jormugandr, especially if he's gotten wind of our plan. Not that I think he has, but it's good to remember he's not just a dumb snake."
"Never said for a moment that he was, but I still think he'd be disappointed with a cheap win. Making us prove our endurance is one thing but at the end of the day we're all friends who just want to test our strengths here, it's not like he has to defeat us for the sake of peace," Alicia says as they continue onwards with Partanyx, remaining in her giant size.
