"Let me see." Moore says as he goes forward to see if he can figure it out!
Take 10 for 72 for Disable Device.
Active Spells: Superior Resistance (CL 35), True Seeing (CL10), Bibliotecha Arcana (CL35), Epic Mage Armor (CL24), Mind Blank (CL17) and Afina's Perfect Sight (CL27).
You reach the trap and begin to work on it.
Give me a Dex check.
[22:30] <Nephrite> roll 1d20+46
[22:30] <Kobot> Nephrite rolled 1d20+46 --> [ 1d20=15 ]{61}
You find that the trap has a section of wall that you remove, the inner workings of it there. Yet as you do, your nimble fingers are able to note that both sides of it are carefully crafted buttons - press them and something will happen. Fortunately, you avoid doing that and can continue to disarm it as you please.
Moore will keep at it!
Another take 10 for 72 on Disable Device. If he's not able to because of the time constraints, that's ok.
With a great deal of work, the whirling blades retract to the sides, into the walls. Unless something else turns them back on, it's safe to pass now.
"I haven't had to do that in a while." Moore says with a smile as he turns to proceed ahead. "That was fun."
Refresh me on what the marching order is, and are you waiting on them to catch up to go towards the door ahead?
Moore, Kaja, Jetina, Cresiel, and yes he will wait for them to cross safely.
Kaja walks ahead. When he comes within about 10ft of where the blades where? Suddenly the floor springs up and towards where the blades were, catapulting Kaja towards the now empty passage.
Unfortunately for him, the moment the floor springs up, the blades instantly spring back out, spinning away. "Fu-" is all Kaja gets out as...
> roll 1d20+29
<Kobot> Kotono rolled 1d20+29 --> [ 1d20=12 ]{41}
> roll 1d20+29
> roll 20d10 sliced dragon
<Kobot> Kotono rolled 20d10 sliced dragon --> [ 20d10=110 ]{110}
Kaja is sent through it, scaled body sliced into like meat at the butcher. He lands in a bloodied, face down heap just behind Moore, groaning softly.
"Don't worry, I'm here," Jetina calls, "Once we stop the blades again."
"Well, now I'm a little angry." Moore says. He goes to see if he can turn off the device from this side!
