"I'm a little bleeding," Kaja retorts with a grimace, "Nothing deadly, though, everything's still attached. Glad my skin's my armor."
Sure enough, you find another panel on this side, too.
Moore will see if there's any way to permanently disable it on this side!
Take 10 for 72 again.
You are able to disable it again, though you note it can still be triggered.
Is it triggered by stepping on the floor?
You don't see any sign of that on this side. On the other side...well, the answer's obvious and demonstrated.
"Okay, just fly over here. There must be a panel on the floor that turns it back on." He says as he watches the device itself in case it flips back on.
Done. The party flies over and Jetina promptly heals up Kaja. Cresiel glances back, "Devious and persistent," Cresiel says at last. "We had best be on our utmost guard."
"It would certainly have been a problem for lesser creatures." Moore says and proceeds on, while doing something to protect himself anyway.
Divine Shield on himself for 170 HP.
Unsurprisingly, this door is locked as well.
Another Knock will do it!
Alter reality for knock again.
"This seems designed for your typical rogue-ish type." Moore says as he goes to open the door now.
"The classic treasure seeker," Jetina agrees, "Which we are not."
The door pops open. A hallway that goes 20ft until six steps go up, a raised hall for about 15ft then you can see steps going down and a door beyond them.
Moore will proceed to check for magic and traps as he goes forward!
Take 10 on Spellcraft for 113 and Perception for 96.
Hm?
5ft from the stairs you notice something. The tiniest seam running along the floor, from wall to wall. As if this section of floor can move.
Moore rubs his forehead.
"I think we need to fly over this one too." He says as he points towards the floor. "I think this will flatten or collapse."
"Are you sure this isn't in Hell?" Kaja asks slowly.
Cresiel merely peers ahead. "I will go first, to ensure there are no aerial traps."
