The path ahead is...
Started by Anastasia, December 25, 2019, 07:07:53 PM
You notice a door to the side to where the ground is.
'Door here. Let's check it out.'
Lays heads towards it, planning to check it over for traps and locks.
The door is locked but not trapped.
Alyssa pulls out her Skeleton Key and taps it against the door.
Knock, CL 25
The door pops ajar, the skeleton key once again successful.
This opens to a narrow hallway, which looks to head further down and around a bend. The rough, stony path curves downward, and your blind sight helps you again, for you can feel tiny little shapes on the ground that your eyes don't see.
Can I tell if they're traps or something?
Your general blacksmithing knowledge knows the shape of caltrops when you see them.
'Caltrops on the ground. Amusing.'
Alyssa uses her TK to scoop them up and save them for later use.
The caltrops don't move - they seem stuck to the ground.
'Hm. They're embedded or something. Let's just fly over.'
'Let's,' Ianvasah says as you begin to fly over. As you do...!!!
Smooth squares of the floor, each with several caltrops, abruptly rise up and fly right up at the two of you.
Ref saves all, -5 circumstance penalty.
Ref/Cunning Insight:
[blockquote]Rolled 1d20+39 : 3 + 39, total 42[/blockquote]
> roll 1d20+29 evasion
<Penuche> Kotono invokes Penuche's magic: < 49 > [d20=20]
"Ah!" Ianvasah dodges back, as do you. Both of you just manage to avoid the assault, pushed back the way you came. Dozens of gaps are in the path now, and you notice something with your sharp eyes. Little greenish black spores are on the bottom of where the stones were, starting to drift up into the air. At the same time, you can feel the invisible blocks with caltrops turn, trying to bar your way ahead.
