The path ahead is...
Started by Anastasia, December 25, 2019, 07:07:53 PM
Alyssa begins chanting out a spell!
Ectoplasmic Terrain, CL 40, 40 rounds.
Create terrain that slows to half speed if something moves through it and gives off day light. Setting brightness to just below blinding Ianvasah and Alyssa. Filling as much space as I can, leaving a direct path to it open.
Concentration check due to the winds.
Concentration/CL+Int check:
[blockquote]Rolled 1d20+50 : 19 + 50, total 69[/blockquote]
Thus bright, ectoplasmic terrain springs up amid the winds, radiant against the silent winds.
Anything else this turn?
Unless I can use a move action to shove it back some, no.
Thus even held, the Eye of Shar's winds howl at the both of you.
Reflex save. I'll rule the slowed momentum of the field is worth a +5 circumstance bonus to the save. The actual vortex doesn't care about how far it has to move you, so long as you're within the area of its effect, but that field's enough to warrant a save bonus.
Ref/Cunning Insight (9/13):
[blockquote]Rolled 1d20+44 : 3 + 44, total 47[/blockquote]
> roll 1d20+34 Ianvasah
<Penuche> Kotono invokes Penuche's magic: < 42 > [d20=8]
Fort both of you.
Fort/Cunning Insight (8/13):
[blockquote]Rolled 1d20+36 : 10 + 36, total 46[/blockquote]
> roll 1d20+26 fort Ianvasah
<Penuche> Kotono invokes Penuche's magic: < 46 > [d20=20]
> roll 70d6 Alyssa
<Penuche> Kotono invokes Penuche's magic: < 225 > [70d6=225]
> roll 10d6 Ianvasah
<Penuche> Kotono invokes Penuche's magic: < 35 > [d6=2,3,2,4,5,1,5,6,3,4]
What's that put Alyssa at?
177
Alyssa
HP: 177/402
AC: 58
Aura:
AC: 39 +20% miss chance (Cloak of Minor Displacement)
Bonuses: Attack+1, Damage+1 AC+20, Saves+0, Skills+0 (+3 Terrain Bonus), +1d6 Sneak Attack Damage
Resources: Spell Push (10/10), 8/13 Inspiration,
Spells Active: Create Magic Tattoo: +1 CL/SR 35/+1 Luck to ATK, Mindblank, Energy Immunity Cold/Electricity/Acid/Sonic/Fire, Epic Mage Armor, Agility/Mind/Strength of the Dragon Princess, Elemental Body (Fire), Bibliotheca Arcana, Spiderskin
Notes: Immune: Fatigue/Diseases/Negative Levels/Planar Alignment Penalties/Death Spells/Death Effects/Energy Drain/Blood Loss/Gas/Vapors, Termorsense 30ft, True Seeing, Darkvision 60ft, Blindsense 30ft, Freedom of Movement
Agony. White hot agony tears at you as you hold the Eye of Shar, as you come in contact with it feet first. Like that your legs are gone ,a roar of agony as you land on your side. With a thrust of sheer telekinetic panic you get a few feet away from it, mind reeling. At the same time Ianvasah manages to dodge it this time, only a bit of bleeding along her leg.
Close your eyes now, Alyssa. It will be over soon. I'll hold you tenderly as you pass into oblivion.
Eye of Shari s done due to the grapple.
Init is Alyssa (32) > Eye of Shar (26) > Ianvasah (23)
Ianvasah is up.
Ianvasah screams something out, but you can't hear it. All you can hear is the beat of your heart, the gentle noise of blood splattering against the ground. All you can hear is the purple velvet of Shar's voice that is not a voice.
'ALYSSA!' In your mind, a silent call through your telepathic bond.
Chance to react before Ianvasah goes.
Ianvasah
HP: 471/585 (fast healing 3)
Aura:
Resources: Protection Domain 1/1
Spells Used: Superb Dispellingx2, Greater Firestorm, Sunstorm,
SLAs Used:
Spells Active:
Notes: Has notes for shapeshift on her sheet.
Alyssa tries to focus past it, 'You've failed at temptation often enough, you should give it up!'
Also I'm sorry, forgot to include this in the post, but I need a concentration check to see if you lose concentration on TK since damage taken.
