Rebirth and redemption
Before you go, Dolmaya glances back, "You have plans ready, as much as possible?"
"Losely. I have appropriate spells, I think. My new abilities will serve well enough without a weapon. I've studied nature and crafting as best I can. If there's something else to be done to prepare, I can't think of it."
A slight nod, "We'll endure," Dolmaya agrees, "We have a friend to avenge, let's get started." With that, Dolmaya heads through the portal.
Do you need time to make a mini stat block for your stats without gear? Easier than usual for you.
#140
We can start and I'll get it done as we go.
Edit: In fact:
Alyssa
HP: 405/405
Aura:
AC: 28
SR: 48
Bonuses: Attack+43, Damage+0 AC+0, Saves+0, Skills+0
Resources: Spell Push (10/10), 25 Inspiration
Spells Used:
SLAs Used:
Spells Active:
Notes: Darkvision 60ft, DR 20/adamantine and epic, Resistance 20 Acid/Electricity/Fire 20, Immunity Cold, Never Flat-footed
Sure, I'll do Dolmaya's overnight.
It's...not cold. It's cold but not cold. You lie on ice, your bare body surprisingly fine on it. You feel disoriented but intact.
Alyssa rouses herself with a slight shake, taking in the area and looking for anything they can use to help and trying to identify immediate dangers and needs.
I actually have a few ranks of Survival, so if need be, we can go that route.
Sure, gimme a check and I'll weave it into your reply.
You lie on ice. An iced over river, surrounded by stones and boulders. There's no immediate danger to you since you're resistant to cold now. The river stretches ahead behind you and around a winding bend that stones block, while on the other side a dam of stones and boulders blocks the way ahead that way. You can't quite see over the rocks lying down, but you can see mountains rising in the distance, all around. A valley, looks like.
Alyssa cautiously stands and looks around, trying to see if Dolmaya is near.
She's right behind you, shivering as she looks about, "I envy your protection from the elements already," she remarks candidly, then gestures. A few words of power and she's not longer shivering.
Resist energy, with needs no component unless you're a divine caster with a divine focus.
Dolmaya: Used resist energy for fatemaker, will have full sheeting up overnight or in the morning.
Alyssa nods slowly, "Yes, well... I can help you with that if you want. I can make you immune, or give you Planar Bubble?"
"This will do for now," Dolmaya says, "At least until get our bearings." She goes over to the nearest river bank and peeks over low lying rocks, "It's a rocky valley," she says, "This is going to be hell on our feet if we walk. Look."
