Rebirth and redemption
"Then I have no choice but to do it myself," Dolmaya declares, "Can you cover my slack if I do that?"
"Depends on what we run into. Before we resort to that, let me think..."
Can I use Space Compression to get up there?
As long as it's within range of the spell's effect there's no reason why not.
"I think I might have a spell that can provide a solution..."
Alyssa begins casting!
Space Compression,  CL 35.
Connecting a spot next to me to one at the top of the climb so I can walk through.
It is done easily enough - the points are connected.
Like that both of you are atop the sheer lift, "Much better," Dolmaya agrees.
"A bit of a waste to use a spell on that though."
Alyssa continues on.
You walk several more minutes. Ahead you see a glimmer of light - not sunlight, but of something bright nonetheless.
Alyssa moves quietly and cautiously forward.
Soon enough you see it - crystalline growths, a dull gray color suffused with strong white light. They jut out from the walls, natural deposits.
Alyssa creeps a bit closer and tries to identify what they are.
K:D/Bibliotheca:
Take 10 for 72.
It looks to be quartz, but the energy within it suggests otherwise. Your arcana lets you know this quartz is powerfully charged with magic and reactive - it would be wonderfully useful as a reagent or material.
