Rebirth and redemption
How fast are you able to move?
70 ft, 100 if haste is still around.
The two of you run fast as you can, leaving the serpent behind in a blur of hasted movement. Down the burrow tunnel as fast as you can. In the distance as you do, you hear a roar echoing behind you. Dolmaya glances back, "Don't stop!"
Alyssa doesn't!
She does slow enough for Dolmaya to keep up, however.
[blockquote]Rolled 1d20+11 : 20 + 11, total 31[/blockquote]
> roll 1d20+4 Dolmaya
<Kobot> Kotono rolled 1d20+4 Dolmaya --> [ 1d20=19 ]{23}
Run, run, run. Haste expires and you're able to keep the pace as you go down the burrow. The roars of the Child of Jormugandr follow you but you keep the pace. Running, hurrying, fleeing. Up a slope, hurrying away. There! A dead end, a high roofed cavern. But 50ft up near the roof is an exit, sunlight streaming in from it.
"A wish," Dolmaya snaps, "Quickly! Weave, honor my power and let us climb!"
Wish for spider climb on both of you.
Immediately Dolmaya begins climbing up the walls as fast as she can.
Up you go as the roars get closer. Just as you're about to reach exit and freedom, you hear a roar behind you of, "DON'T YOU DARE RUN AWAY!"
Alyssa keeps going, but calls back, "Best two out of three!"
Thus you escape out to a roar of fury - onto a cliff ledge, a drop thousands of feet into icy cold waters below. You look out from this vantage, a cliff side view of a crystal blue fjord and mountains all around it. The air is sharply cold, only your innate resistances protecting you from injury. Mountains and rugged forests, valleys, fjords. A great deal can be seen from here, a view for countless miles all around from your lofty perch.
"Well, this is awkward. Let me try something. If we're out of the valley it might work now..."
Alyssa tries to teleport a bit to the side, to see if the block is gone.
It works just fine. Just as well, for a moment later the walls rattle, the entire mountainside shaking, as rocks tumble down to your sides from above.
"Get us out of here," Dolmaya says, pointing, "That forest down there will do!"
