Rebirth and redemption
Alyssa stands against them now. Stood against them as a mortal.
"I will stand against them with my will. With my friends. With my allies. With my knowledge, experience, and heart. As all do."
Charisma/Brains Over Everything/Book Bonus:
[blockquote]Rolled 1d20+27 : 9 + 27, total 36[/blockquote]
Drowning. You're drowning and drowning in endless tides of books and white and roads and lore and emptiness.
> roll 1d20+5 ???
<Kobot> Kotono rolled 1d20+5 ??? --> [ 1d20=17 ]{22}
Init is ???? (14000) > ???? Echo (7000) > Split (2817) > Dolmaya (35) > Emily (25) > ???? (22) > Jarem (19) > Bastian (8)
> roll 6#1d20 Dolmaya touch AC
<Kobot> Kotono rolled 6#1d20 Dolmaya touch AC --> [ 1d20=10 ]{10}, [ 1d20=1 ]{1}, [ 1d20=16 ]{16}, [ 1d20=14 ]{14}, [ 1d20=1 ]{1}, [ 1d20=6 ]{6}
> roll 1d57
<Kobot> Kotono rolled 1d57 --> [ 1d57=22 ]{22}
Drowning, drowning drowning drowing - !
Air! You gasp as Jarem has you in his strong arms, "To the portal, now!" Both of his heads bark, pulling you along. "Now!"
Alyssa stumbles, confused, gasping and gagging, nearly vomiting at the sudden discordant shift, but tries to keep up.
You flee. A panic, up and down at war. A tumble, a fall into white and...
Roll 1d4-3 for me.
#651
This dice roll has been tampered with!
Rolled 1d4+3 : 1 + 3, total 4
Edit, was supposed to be -3, so the total is -2.
I told Iddy to edit the last post, the roll's valid.
Gasp.
You suck in air as you're on hands and knees. Yet even now you feel a sense of expansion, a sense of growth. The words of your companions are lost to you as you feel those sensations that spread out amid you. You feel so much more, like you were blind and sleeping until this moment. You feel vastly more alive, a spark within you that glows bright.
Alyssa has gained divine rank zero. Do you need a rundown of the changes from it?
Not a run down, but I know there's a write up somewhere if you can toss me the link? Or is it just what's in the Divine Rules post in the rules & setting board?
DvR0's pretty straightforward and I have a checklist for it. 1+ is when it gets complicated, but this is akin to a template. I would highly suggest applying the enhancement bonus to ability scores first and then working from the topic.
- Outsider type with any appropriate alignment subtypes. You're already an outsider so this doesn't change anything. You do get the chaotic subtype.
- Maximum hit points per hit die. This means you recalculate your hit points as if you got the best possible rolls each level.
- Boosted speed as according to a table based on size, see the divine rules for this table. In short, a medium creature has a base speed of 60ft and a fly speed of 200ft (perfect). Change your base speeds then apply any bonuses to movement speed you have, such as your innate ability that you got recently. The name escapes me, but that'll increase your movement speed even higher.
- A natural armor bonus of +15 that overlaps with preexisting natural armor. In other words, I think you got a...+6 natural armor bonus or so. This overwrites it unless your existing bonus is higher.
- Charisma modifier to armor class as a deflection bonus. - Very straightforward. Charisma modifier as a deflection bonus to armor class. Note that Brains over Everything does not apply to this.
- Damage reduction 10/epic. This is mostly irrelevant as you already have damage reduction, I believe. Correct me if I'm wrong.
- Immunity to aging and it's related effects, cannot die from age. Do not need to eat, sleep or breathe. - Useful to know. Negates certain hazards, such as drowning or starving.
- Can only be permanently slain by an opposed rank check in your home plane. - Which means if killed off your home plane, you simply reform there. Only a deity can kill you for good, and only then if they beat you on a rank check when they do it.
- Immunity to polymorph, petrification, form altering, energy drain, ability drain, ability damage and mind affecting. A rank check can overcome these immunities. Straightforward here. Note these are divine immunities on your sheet and can be overcome by another deity.
- Spell resistance equal to 15 + HD. This overwrites your existing spell resistance unless it's already better.
- Charisma modifier as a resistance bonus to saving throws. Same rules as the charisma to AC as deflection. This overlaps with a cloak of resistance or similar items.
- +10 enhancement bonus to all ability scores. Basically an extra strong belt of magnificence.
Quote from: Anastasia on February 17, 2020, 01:38:24 PM
What is my home plane now since I technically reside in a demi-plane? The Gates of the Moon?
Also, Planar Bubble imparts bonuses based on home plane, so what would those bonuses be?
Yes. This can be changed if you end up out on your own, but that's it for now.
It's mildly good and chaos aligned, that's about it. Most of the events and things are done directly by Selune or Shaundakul. If you make your own realm or otherwise work it out, you'll be able to adjust and grow your own traits. See the Cauldron and Sylica's writeups for how those two came out.
Alright. I'm still working so I'll do the math stuff on my sheet later tonight.
Alyssa closes her eyes and takes a deep breath in, trying to sort out all the new sensations and feeling, taking a moment to inspect the new spark inside of her, trying to define it to herself before shakily standing and looking at the others.
"I'm... more. Far more now. I feel... like I was sleeping or something before."
Latha is with Jarem, chanting as his second head shrinks down and vanishes.
Emily is with you, "It's incredible, isn't it," She smiles right back. "You did it!" A tight hug follows.
Bastian kneels, coughing up blood that twists and sparks into bands of flame. Dolmaya promptly uses blasts of magic to disperse them once they form.
"What the hell happened? I was... In pure white. I couldn't see, hear, or feel anything."
