Labalyn's memorial
Moore flies up to the door!
Any magic on it? Spellcraft of 113 again.
Yes. It won't open unless you have a specific item - which is what Rosenose gave you.
"He really has been there a long time..." Moore murmurs as he puts his hand on the door to push it open! Or... pull it, or... whatever way it goes.
The door slides aside. Within lies a short hall, leading to another door at the other side.
Moore proceeds, but checks for magic and traps as he goes!
Perception 96, Spellcraft 113. It will become a theme.
"No sense trapping a place no one can ever get to." Moore says as he proceeds to the door to open it!
Ahead is a large, silent room. Old stone lies here and within rests a single coffin. It is made of the same stone as the walls, a plain colored brown carved well. The coffin is without decoration. It simply sits on the ground, no other doors leading further along here.
Moore will approach the coffin and look for magic here as well!
Perception for 96 and Spellcraft for 113, anything of note here? This also assumes the coffin doesn't have someone in it that opens it when he gets close!
No magic - but you can't detect anything past the surface. Something in the stone blocks it cold.
Moore does the sensible thing and tries knocking on the top of the coffin!
Maybe it's not sensible, but if there is something inside then it's at least polite.
Sorry about delays, lots of things interrupting the past 30 minutes or so.
"...knocking on a coffin?" Jetina says at last, "Why?"
The coffin does not respond to that knocking.
"I had a theory, but it's been proven incorrect." Moore says as he moves to try and open the coffin now, either by hand or, failing that, divine will!
The coffin opens smoothly. Inside lies a swirling portal, one of ebony black.
"That was my second hypothesis." Moore says. "What we are looking for is inside here." He explains. "Or, perhaps I should say, the way to our destination is through here. Come, I have no cause for concern."
He will attempt to enter said portal!
