Labalyn's memorial
Sure.
Jetina maneuvers around - and Torm laughs. He laughs and - !!!
How close did you get to Torm?
Me, specifically? I guess I never moved when he flew back after Jetina, so I am however far away from Cresiel and Jetina as Jetina was originally, if that makes sense.
Close enough.
Around Torm fire erupts. A flame ebony black, in which the broken, headless bodies of mortals can be seen. These flames erupt out around all of you, like an inferno as Torm stabs his sword down into the ground. "Offer your souls!"
Ref all, -10 circumstance penalty.
[21:00] <Nephrite> roll 1d20+42+18+1 evasion, Moore
[21:01] <Penuche2> Nephrite invokes Penuche's magic: < 76 > [d20=15]
[21:01] <Nephrite> roll 1d20+41+18 evasion, Jetina
[21:01] <Penuche2> Nephrite invokes Penuche's magic: < 69 > [d20=10]
Forgot the -10, so that's 66 and 59 respectively.
> roll 1d20+71 evasion Cresiel
<Penuche2> Kotono invokes Penuche's magic: < 83 > [d20=12]
> roll 50d12+150
<Penuche2> Kotono invokes Penuche's magic: < 430 > [50d12=280]
Full damage to both of you, but Cresiel evades. HP after that body check?
Cresiel: 287
Kaja: 207
Jetina & Moore: 197
Mass Valiant fury for +6 str/con morale and +2 morale will saves and extra attack ala haste.
Inspire Excellence for +12 competence to Strength for everyone.
He's using his Harmonize move ability to also cast Destined Strike, which is the following:
+4 to attack and damage rolls, Improved Critical Feat, +23 to threat confirmations right now.
Inspire Heroics, +14 morale bonus to saves and +14 dodge to AC for everyone.
Oh, I forgot, but everyone also gains the following benefits for future rounds: they gain fast healing 11, and gain damage reduction 11/-
He's using his move action to Inspire Courage.
Courage +20 morale bonus on saving throws against charm and fear effects and a +20 morale bonus on attack and weapon damage rolls.
Cresiel
HP: 1068/1068(963) (regeneration 20)
Aura: Protective 20ft (+4 deflection/+4 resistance vs evil)
Resources: Holy Fury 39/39 (enc) Channel Energy 18/18 Divine Retribution 1/1 Blinding Speed 24/25 Knight's Challenge 15/15
Spells Used:
SLAs Used:
Spells Active: Detect Evil (CL35), Detect Snares and Pits (CL35), Discern Lies (CL35), True Seeing (CL35)
Notes: Adjacent allies gain a shield bonus equal to Cresiel's shield bonus.
Kaja
HP: 753/753(648)
Aura:
Resources: Breath Weapon 1/1 Dervish Dance 13/13 Endless Cuts 3/3 +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd) 1/1
Spells Used:
SLAs Used:
Spells Active:
Notes: Goes in and wrecks things. The end.
Jetina
HP: 314/705(600) (fast healing 5)
Aura: Courage 10ft (+4 morale vs fear), Positive Energy 10ft (1 hit point healing/round)
Resources: Smite Evil 7/7 Smite 6/6 Channel Energy 14/14 Emergency Healing 3/5 True Believer 1/1
Spells Used: 3 9th level spell used
SLAs Used:
Spells Active:
Notes: Divine Vigor is +10ft land movement and +2 temp hp per hit die. Divine Shield is Cha mod to shield bonus to armor class.
They have Dr/11, so that's 419, for whatever it matters.
222 damage after the temp HP to Jetina, so that should put her at...
261+the 210 from her +12 con (I think it was factored in from Cresiel but not Moore's HP buffs), +275 ...523.
Moore had a Divine Shield up for... 190, so that did 32 damage to him, so he's at...  723+210+105-32 = 1006.
DR doesn't apply to this, it's not physical damage.
A moment later Torm is a blur, a burst around all of you that...
Fort.
Oh, then the numbers are still correct, since I hadn't actually factored that in.
[21:34] <Nephrite> roll 1d20+72 Moore, mettle
[21:34] <Penuche2> Nephrite invokes Penuche's magic: < 85 > [d20=13]
[21:34] <Nephrite> roll 1d20+72 Jetina, mettle
[21:34] <Penuche2> Nephrite invokes Penuche's magic: < 74 > [d20=2]
Remember +18 from buffs and then also the bonus Con.
> roll 1d20+71 Cresiel mettle
<Penuche2> Kotono invokes Penuche's magic: < 80 > [d20=9]
Again all of you shake it off. Ahead Kaja is on the far bridge now, going under the arch you made. Torm is hot on his heels, once again demonic energy as...
Go.
Wait, when did Torm go after him? Did he turn into something to give chase, or is he just now moving after him after those attacks? Just want to be clear.
Edited, a small bit got left off.
Moore attempts something quickly!
His boots have a swift action to teleport him 10 feet forward, he's testing if teleportation / dimension door / whatever stuff will work here.
"Teleportation is out, so go!" Moore shouts.
Moore will double move to catch up to Torm. That's 180 x 2 for 360. Does that put him close to catching up or not?
It puts you within about 50ft of him.
