Labalyn's memorial
Okay. In that case...
Moore turns to Cresiel. "Go. I will protect you, for a change."
Moore is using his Regalia to give Cresiel a movement action - that will let him go 200 ft. Then Cresiel can choose what to do after that. It seems like if he moves again that puts him within 10 feet, which is a lot closer.
Moore will hold his turn for Cresiel, then move 180 feet. Jetina will use her Greater Flight cloak and move 80 feet.
Thanks, that'll work.
Init is Torm (Supreme Init) > Moore (59) > Cresiel (54) > Kaja = Blood Kaja = Jetina (33)
Cresiel flies ahead fully on, a deadly charge augmented by you. He rushes into Torm, hammer raised high as he goes for it all.
> roll 1d20 -35 PA going for the home runa gain
<Penuche> Kotono invokes Penuche's magic: < 5 > [d20=5]
This time Torm sidesteps with a speed that borders on the impossible, the avatar untouched as Kaja runs beyond, closer and closer to the Guardian. On he runs as...
Jetina.
Jetina will use her Greater Flight cloak and move 80 feet. Note to self, make that an "always use this all the time" thing so this doesn't come up again.
Run.
Run.
Run.
It's not enough. Kaja flees but Torm is suddenly right behind him, a blur as his greatsword comes down.
> roll 1d20+99 (+2 charge, +12 rage, +15 smite good, +4 ???, +8 ???,  +1 ???, +4 ???, +3 ????, +12 ??? -40 PA)
<Penuche> Kotono invokes Penuche's magic: < 106 > [d20=7]
> roll 6d6+549+3d6+3d6
<Penuche> Kotono invokes Penuche's magic: < 587 > [d6=1,4,3,5,1,2,5,4,2,2,4,5]
Kaja is split from the top of his left shoulder to his hip, more blood gushing out. Torm reaches out a moment later, hand rife with the energies of death and destruction. At the same time Cresiel utters a single word of martyrdom, as the wound appears on him and leaves Kaja.
Damage transferred to Cresiel.
> roll 1d20 touch AC at least he's out of range for echo on the others
<Penuche> Kotono invokes Penuche's magic: < 13 > [d20=13]
> roll 1d20+47 Kaja fort
<Penuche> Kotono invokes Penuche's magic: < 48 > [d20=1]
> roll 50d10
<Penuche> Kotono invokes Penuche's magic: < 309 > [50d10=309]
Boosted con saves Kaja, if barely.
The touch causes Kaja's scales to turn gray, his entire body ashy and crumbling. Yet he endures, running along from that attack, a desperate stumble as...
Moore.
Cresiel: 287
Mass Valiant fury for +6 str/con morale and +2 morale will saves and extra attack ala haste.
Inspire Excellence for +12 competence to Strength for everyone.
He's using his Harmonize move ability to also cast Destined Strike, which is the following:
+4 to attack and damage rolls, Improved Critical Feat, +23 to threat confirmations right now.
Inspire Heroics, +14 morale bonus to saves and +14 dodge to AC for everyone.
Oh, I forgot, but everyone also gains the following benefits for future rounds: they gain fast healing 11, and gain damage reduction 11/-
He's using his move action to Inspire Courage.
Courage +20 morale bonus on saving throws against charm and fear effects and a +20 morale bonus on attack and weapon damage rolls.
Cresiel
HP: 381/1068(963) (regeneration 20)
Aura: Protective 20ft (+4 deflection/+4 resistance vs evil)
Resources: Holy Fury 39/39 (enc) Channel Energy 18/18 Divine Retribution 1/1 Blinding Speed 24/25 Knight's Challenge 15/15
Spells Used:
SLAs Used:
Spells Active: Detect Evil (CL35), Detect Snares and Pits (CL35), Discern Lies (CL35), True Seeing (CL35)
Notes: Adjacent allies gain a shield bonus equal to Cresiel's shield bonus.
Kaja
HP: 651/753(648)
Aura:
Resources: Breath Weapon 1/1 Dervish Dance 13/13 Endless Cuts 3/3 +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd) 1/1
Spells Used:
SLAs Used:
Spells Active:
Notes: Goes in and wrecks things. The end.
Jetina
HP: 314/705(600) (fast healing 5)
Aura: Courage 10ft (+4 morale vs fear), Positive Energy 10ft (1 hit point healing/round)
Resources: Smite Evil 7/7 Smite 6/6 Channel Energy 14/14 Emergency Healing 3/5 True Believer 1/1
Spells Used: 3 9th level spell used
SLAs Used:
Spells Active:
Notes: Divine Vigor is +10ft land movement and +2 temp hp per hit die. Divine Shield is Cha mod to shield bonus to armor class.
Before anything else, was Cresiel in range to use Cresiel's Valiant Stand?
Yes, he meant to use it and I was airheaded. Fixed.
Roger that.
Moore flies in, closer, and shouts a word of healing!
Moore moves 180 feet closer. Mass Heal, 250 for Cresiel and Kaja, they should be close enough together for that to work, I think? And he should have range on them with it.
Healing spreads over your allies again as the avatar of Torm turns, a wordless cry of anger as Cresiel matches him, sword against sword.
> roll 5#1d20 going for the homerun blinding speed used along with max PA
<Penuche> Kotono invokes Penuche's magic: < 11, 5, 12, 18, 1 >
Yet Torm's guard is perfect against those blows, and he even wheels around as Kaja runs, a flick of his blade as it passes through himself harmlessly, slashing for Kaja. "Heal me," he cries to Jetina as...
Kaja provokes the AoO by running all out, he's in good enough healt ot risk it and hope Jetina emergency heals him, if he survives.
> roll 1d20+97 (+12 rage, +15 smite good, +4 ???, +8 ???,  +1 ???, +4 ???, +3 ????, +12 ??? -40 PA)
<Penuche> Kotono invokes Penuche's magic: < 101 > [d20=4]
> roll 2d6+103+3d6+3d6
<Penuche> Kotono invokes Penuche's magic: < 126 > [d6=2,3,5,3,2,3,2,3]
Kaja is grazed across the back as the blood Kaja continues to bite at him, trying to score a wound against far too tough a body. Yet it doesn't stop Kaja, who sprints ahead dead on and...
A stop.
I see you have the pebble, Kaja.
You bear wounds of hate and fury, but you stand before me.
I suppose that will do.
Cresiel
Resources: Holy Fury 39/39 (enc) Channel Energy 18/18 Divine Retribution 1/1 Blinding Speed 23/25 Knight's Challenge 15/15
Spells Used:
SLAs Used:
Kaja
HP:627/753(648)
Aura:
Spells Used:
SLAs Used:
Spells Active:
Jetina
HP: 564/705(600) (fast healing 5)
SLAs Used:
Spells Active:
Moore stops himself -- is it ... over?
Jetina's ready for an emergency healing if needed.
None of you move - not even Torm. There is silence for long moments.
Silence.
Silence.
Here.
Kaja holds the divine seed in his hands.
Farewell.
I shall leave and return to nothingness.
Do with this treasure as you will.
Return to whence you all came, you have no purpose here now.
You stand in your room in Hope's Landing, untouched.
Moore blinks.
Then blinks again.
"Did... did... ...we...?" He blinks again.
There's no sign of the others. You stand alone in your room.
He ought to be able to sense the others in Hope's Landing, correct?
You can sense Cresiel here. You do not sense Kaja or Jetina.
Kaja, where are you? I will open a gate.
Jetina, where are you? I will open a gate.
He's immediately in Cresiel's room.
Wait... ...if he's... here, then... oh no.
