Beastland wanderings
Started by Anastasia, February 19, 2020, 02:58:12 PM
Alyssa points it out to the others and heads towards it.
It's not dangerous down here and without needing to breathe, swimming is simple. You reach the gap - it's a gap straight down, water filled. As you get close, you can feel a current coming up from it, as if pushing water out from below.
Alyssa looks to the others and points down into it, leading the way in.
Are you under freedom of movement or similar?
No. I can teleport us to the bottom of the chasm, if need be.
As you get closer, suddenly the current gets stronger, pulling you ahead.
Str checks, all.
Str/Brains Over Everything:
[blockquote]Rolled 1d20+17 : 9 + 17, total 26[/blockquote]
> roll 1d20+7 Jarem
<Penuche> Kotono invokes Penuche's magic: < 18 > [d20=11]
> roll 1d20+9 Emily
<Penuche> Kotono invokes Penuche's magic: < 22 > [d20=13]
> roll 1d20+15 Bastian
<Penuche> Kotono invokes Penuche's magic: < 20 > [d20=5]
> roll 1d20+5 Dolmaya
<Penuche> Kotono invokes Penuche's magic: < 17 > [d20=12]
> roll 1d20+8 Jessica
<Penuche> Kotono invokes Penuche's magic: < 27 > [d20=19]
Somehow you manage to out think it - you pivot back just so, enough to momentarily give you a chance to jet back, which you do. Jessica's with you while the others are swept down and away, down into the chasm, pulled by a current that changes by the moment.
Alyssa tries to swim to the others, to gather them together and try to anchor them into pulling themselves down the sides of the chasm.
You choose to swim ahead, carried by the current. You reach them quickly - for after about 50ft it empties out into an open cavern. A fall into a lake, shores to either side. Your friends are swimming out as you reach them, to the shores and safe.
The water simply stops at those shores, unnaturally coming to a stop, flowing no further.
"Well, interesting. Very nice, actually. This would make for a fantastic get-away lair. A little climate control and some luxury and it'd be perfect."
Jessica appears next to you once you're out of the water.
"Different," Jarem agrees, taking off his helmet to shake his head dry. "Refreshing."
"So what is this place? A lair?" Emily wonders aloud.
"Likely. All bears can swim fairly well, and they hibernate in caves. Seems a perfectly eccentric match for a celestial bear guardian. Let's start looking around."
Past the shore is a pair of passages that lead further in. In one you see it - a vein of gold runs through the stone, thick as your waist and long, going about 30ft before it tapers off. The other's not so gold-blessed. Both go to turns - one to the left and one to the right and downwards.
"Greed to mislead? What do you think?"
Alyssa wanders, looking for any tracks or sign of passage.
