A neverending field
Started by Anastasia, May 03, 2020, 11:28:58 PM
The rest will take the same approach.
Like that, all of you are in. A dull, dark corridor with smoky torches. Steel and fire as you head along - no one's ahead that you can see.
Seira keeps on her toes and studies the magic in more detail, even as she hugs the wall and leads the way towards their destination.
Perception 10 for 95 to not be caught off guard and notice any traps, too. Knowledge: Arcane and Spellcraft 10 for 120 to decypher any spells and wards here.
There are indeed traps - every 10ft there's motion traps, magic designed to catch and notice anything larger than a bug moving through that space. You analyze the spell easily enough, as well as note an array of expected defensive wards. It's the various ones the information mentioned, no surprises there.
Seira looks for a way to neutralize that spell's effect on them without actually taking it down. Would a modification on a spell immunity or globe of invulnerability through Miracle do the trick?
IRC down for you, by the way? Iddy mentioned having problems with IRCCloud last night.
You think so, if done properly and strong enough.
You're far more than strong enough.
Yes, sadly.
Seira makes the preparations, and recasts Shadow Form on everyone in case they need to leave in a hurry. Then, with nothing about to be tripped, she hugs the wall and leads the way to their destination!
If it helps, Iddy's using kiwiirc.
Gimme a quick d100.
'Good so far,' Amaryl sends as you all move ahead, silent and unseen as a moment's shadows.
[blockquote]Rolled 1d100 : 39, total 39[/blockquote]
You slip by and past, able to neutralize them well enough. You come to a door, no one around - this should lead you to where your target is with any luck.
Seira slides up to the door and listens for what is on the other side, be it talking, the sounds of breathing or anyting at all.
Perception remains 95, of course.
You pause as you notice something. There's a faint oiliness to the door, something that looks highly unusual to you. An examination notes the door is coated in a contact poison that causes unconsciousness.
Seira checks the wall next! After all, she can certain slip through it if the door is a bad idea.
The wall lacks the poison on it and only has the standard protections.
'Wait here,' Seira thinks to the others, taking a glance inside the room. She is mindful of the distance, and merely stays in place on the other side to observe.
