The duty to live
Started by Anastasia, May 12, 2020, 05:15:05 PM
The last hit scores a kill, so we'll just roll that since none of them are beating the temp HP that replenishes each kill.
> roll 28d6
<Penuche> Kotono invokes Penuche's magic: < 92 > [d6=6,6,3,1,1,3,1,3,5,1,6,3,2,2,1,4,5,3,6,1,5,2,4,4,4,2,3,5]
Sulia, however, needs no saves thanks to boosting her saves and now improved evasion.
A slash. An explosion. Another and another and another. You rip through four balors like tissue paper, the explosions battering you and yet no great harm as you use their life against their deaths. Sulia blurs through the explosions, untouched by one and all as meanwhile Antenora stays above and out of immediate harm, as chunks of ceiling rain down and...
Anything else this turn?
<Ebiris> Inspire greatness and inspire courage. +5 bonus d10 hd, +5 competence attack, +3 competence fort, +14 morale attack/damage.
Divine Familiar benefits.
Counts as 36 hit dice for any effects that matter with those.
Hit points change to 379 if they're not already higher.
Base attack bonus changes to +36 if it's not already higher.
Base saves (before stats/feats/abilities) change to Fort +18, Ref +9, Will +18 if they're not already higher.
Gains Alicia's base skill ranks for any skills his aren't higher than. That's +39 to acrobatics, craft (landscaping), craft (painting), diplomacy, intimidate, fly, knowledge (arcana), knowledge (history), knowledge (nature), knowledge (religion), knowledge (planes), perception, perform (oratory), profession (general), sense motive, spellcraft, survival, and swim. And +16 to bluff.
Intelligence rises to 23 if it's not already higher.
Gains +18 to natural armour.
Gains improved evasion.
Gains spell resistance 41.
Can cast Limited Wish as a spell-like ability twice per day.
Antenora
HP: 893/900
Bonuses: Attack+3 (+3 luck), Damage+0 AC+6 (+3 morale, +3 luck), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Resources: Holy Fury 39/41 (enc) Divine Retribution 1/1 Smite Evil 13/13 Channel Energy 18/18 Lay On Hands 540/540 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 25/25 Divine Blast 18/18
Spells Used: 1 opal protection, 1 heal
SLAs Used:
Spells Active: Many Moments of Prescience (CL38), Recitation (CL36), Mass Death Ward (CL36), Sublime Revelry(CL36), Opal Protection (CL38)
Typical Charging Numbers: 36 for base smite damage, 72 for charging smite +2 per per level. So 108 bonus damage baseline. Raw attack plus smite is 1d8+145+2d6+2d6 (+4/+4d6 if fiendbane hits). Doesn't include other factors.
Empress Sulia
HP: 493+200/770
Aura: Divine (30ft)
Bonuses: Attack+3 (+3 luck), Damage+0 AC+18 (+3 morale, +3 luck, +12 armor), Saves+6 (+3 morale, +3 luck), Skills+0, Checks+0
Resources: Channel Energy 16/16 Inspire Confidence 9/9 Inspire Nobility 6/6 Charity Domain 3/3 Nobility Domain 3/3 Suffering Domain 3/3, Divine Shield 13/14
Spells Used:
SLAs Used:
Spells Active: Epic Mage Armor (CL36). Many Moments of Prescience (CL38), Recitation (CL37), Mass Death Ward (CL36), Sublime Revelry(CL36), Opal Protection (CL38)
Notes:
[/quote]
Alicia's all done.
Marie's repeat spells go off again now.
[17:21] <@Ebiris> roll 1d3+32 repeat sandalphon from last round
[17:21] <Penuche> Ebiris invokes Penuche's magic: < 35 > [d3=3]
[17:21] <Penuche> Ebiris invokes Penuche's magic: < 34 > [d3=2]
138 damage and 4 negative levels and entangled to every enemy still alive.
Alicia HP: 1244+148/1244
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 39), extended nondetection (CL 39), greater heroism (CL 36), extended ray deflection (CL 39), epic mage armour (CL 36), sensual blessing (CL 36), greater foresight (CL 38), keen edge (CL 36 on sword), dance of the unicorn (CL 36), extended greater anticipate teleportation (CL 38), repelling shield (CL 38), freedom of movement (CL 36), greater visage of the deity (CL 36), recitation (CL 36), true seeing (CL 36), death ward (CL 36), sublime revelry (CL 36), opal protection (CL 38), dance of the unicorn (CL 36)
Defences: AC 94, CMD 143, spell resistance 51, energy immunity (fire, cold, negative energy), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +4 morale skills/saves, +10 armour AC, +25 competence perception, +7 insight AC/ref, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size AC, +9 shield AC, +3 luck AC/attack/saves, +3 morale AC,  +5 bonus hd, +5 competence attack, +4 competence fort, +14 morale attack/damage
Sorcerer spell slots: 6/16/16/14/9/9/13/9/9/5/8/5/7/7/6/2
Duskblade spell slots: 6/22/22/23/11/6/16
Marie HP: 830+20/830
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 36), extended nondetection (CL 36), greater heroism (CL 36), greater arcane sight (CL 36), epic mage armour (CL 36), sensual blessing (CL 36), repelling shield (CL 36), freedom of movement (CL 36), recitation (CL 36), true seeing (CL 36), bibliotheca arcana (CL 36), death ward (CL 36), sublime revelry (CL 36), opal protection (CL 38), superior invisibility (CL 41), project image (CL 41)
Defences: AC 98, CMD 107, spell resistance 51, energy immunity (electricity, fire, sonic, negative energy), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 51), freedom of movement
Stat buffs/penalties: +4 morale skills/saves, +25 competence perception, +9 shield AC, +3 luck AC/attack/saves, +15 insight knowledge, +3 morale AC, +5 bonus hd, +5 competence attack, +4 competence fort, +14 morale attack/damage
Sorcerer spell slots: 6/9/10/8/8/9/9/7/7/8/7/5/4/7/4
The balors are blasted again and again, slammed back and slowed. They are entangled and slammed, all as...
Marie.
Marie slightly changes up her song, more magical effects layered into the words to bolster everyone!
Swapping bardsong to inspire heroics. +10 morale to saves, +10 dodge to AC for the party. The other songs continue to take effect for another five minutes because divine bard.
But since there's a lot of balors still even after Alicia killed a few, she keeps up her missile barrage to assail them, filling the chamber with glowing projectiles blasting outwards from her illusory decoy!
[17:49] <@Ebiris> roll 1d3+32 sandalphon's amazing barrage, repeat/fell drain/twin/entangle
[17:49] <Penuche> Ebiris invokes Penuche's magic: < 34 > [d3=2]
[17:49] <@Ebiris> roll 1d3+32 sandalphon's amazing barrage, repeat/fell drain/twin/entangle/quicken
[17:49] <Penuche> Ebiris invokes Penuche's magic: < 33 > [d3=1]
134 damage, 4 negative levels, and entangled. Again.
Defences: AC 104, CMD 153, spell resistance 51, energy immunity (fire, cold, negative energy), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +4 morale skills, +10 armour AC, +25 competence perception, +7 insight AC/ref, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size AC, +9 shield AC, +3 luck AC/attack/saves, +3 morale AC,  +5 bonus hd, +5 competence attack, +4 competence fort, +14 morale attack/damage, +10 morale saves, +10 dodge AC
Defences: AC 108, CMD 117, spell resistance 51, energy immunity (electricity, fire, sonic, negative energy), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 51), freedom of movement
Stat buffs/penalties: +4 morale skills, +25 competence perception, +9 shield AC, +3 luck AC/attack/saves, +15 insight knowledge, +3 morale AC, +5 bonus hd, +5 competence attack, +4 competence fort, +14 morale attack/damage, +10 morale saves, +10 dodge AC
Sorcerer spell slots: 6/9/10/8/8/9/9/7/7/8/7/5/2/7/4
More missiles strike, slamming the balors. They're starting to slow from the offensive, enough to give them pause. Yet they continue to seek and stab, a horrible melee below that also spills up towards Antenora. Entangled and blazing, bloodied and beaten, the demons nonetheless continue with a savagery that does not relent even now.
> roll 1d20+79 (+3 ????, +1 ????, +10 ????, +1 ????, +4 ????)
<Penuche> Kotono invokes Penuche's magic: < 90 > [d20=11]
ACs now?
Antenora
HP: 893/900
SLAs Used:
Empress Sulia
HP: 493+200/770
Aura: Divine (30ft)
Spells Used:
SLAs Used:
Notes:
104 for Alicia, 108 for Marie (but she's well away from the actual fight and contributing via her projected image). Don't forget Sulia's +18 to natural armour from being a familiar.
She's even small enough to sit on Alicia's head right now.
But this time the party is prepared and able to dodge, able to endure as those terrible eyes glow. A parry, a dodge. Their numbers are weakening even as a dozen beams sail out at Alicia, seeking her from all angles.
Yet nothing happens. Whatever it is, it's not enough to harm her, not quite.
Antenora and Sulia.
'Alicia, do you need healing?' Antenora sends lightning fast.
'Not even a little,' Alicia thinks back tersely.
If they're shooting beams with spells/spell-likes, Alicia has spell-casting harrier and a lot of AoOs.
Go for an AoO then, sure.
[19:28] <@Ebiris> roll 1d20+105 just one?
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 123 > [d20=18]
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 107 > [d20=2]
[19:28] <@Ebiris> roll 16d6+128+5d6+6d4+240 if that critted
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 459 > [d6=5,2,3,5,4,2,4,4,1,5,2,5,4,5,5,1,4,4,1,2,6][d4=3,2,2,4,3,3]
[19:28] <@Ebiris> roll 8d6+64+5d6+6d4+120 if not, rather
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 238 > [d6=2,1,1,6,3,2,2,5,4,6,1,3,3][d4=3,2,1,3,4,2]
Alicia HP: 1244+240/1244
I was just gonna have it apply to a few for the sake of ease.
> roll 28d6 halve this since you auto pass the save
<Penuche> Kotono invokes Penuche's magic: < 99 > [d6=5,1,1,3,6,2,5,1,4,4,4,6,2,3,4,2,5,3,6,4,2,3,4,5,1,3,5,5]
Your blade swipes through three balors at once, a chorus of explosions battering around you. You endure them as best you can as meanwhile Sulia's wounds heal, followed by Antenora holding her ground, spear stabbing out.
> roll 1d20+65 (+3 luck, +19 Marie, +4 fiends, -20 PA)
<Penuche> Kotono invokes Penuche's magic: < 81 > [d20=16]
> roll 1d20+60 (+3 luck, +19 Marie, +4 fiends, -20 PA)
<Penuche> Kotono invokes Penuche's magic: < 62 > [d20=2]
> roll 1d20+55 (+3 luck, +19 Marie, +4 fiends, -20 PA)
<Penuche> Kotono invokes Penuche's magic: < 69 > [d20=14]
> roll 1d20+50 (+3 luck, +19 Marie, +4 fiends, -20 PA)
<Penuche> Kotono invokes Penuche's magic: < 54 > [d20=4]
> roll 1d8+113+2d6+2d6
<Penuche> Kotono invokes Penuche's magic: < 132 > [d8=5][d6=3,5,4,2]
Antenora rains down defensive thrusts, testing the balors around her. One takes a wound as it endures, bleeding away as Sulia holds her ground, offering herself up.
Gambit.
> roll 1d20+76 (+3 luck, +19 Marie, +10 Alicia, divine might, -10 power attack)
<Penuche> Kotono invokes Penuche's magic: < 85 > [d20=9]
> roll 1d20+71 (+3 luck, +19 Marie, +10 Alicia, divine might, -10 power attack)
<Penuche> Kotono invokes Penuche's magic: < 72 > [d20=1]
> roll 1d20+66 (+3 luck, +19 Marie, +10 Alicia, divine might, -10 power attack)
<Penuche> Kotono invokes Penuche's magic: < 81 > [d20=15]
> roll 1d20+61 (+3 luck, +19 Marie, +10 Alicia, divine might, -10 power attack)
<Penuche> Kotono invokes Penuche's magic: < 76 > [d20=15]
> roll 1d6+76+2d6
<Penuche> Kotono invokes Penuche's magic: < 82 > [d6=1,2,3]
> roll 1d6+76+2d6
<Penuche> Kotono invokes Penuche's magic: < 88 > [d6=5,6,1]
> roll 1d6+76+2d6
<Penuche> Kotono invokes Penuche's magic: < 83 > [d6=3,2,2]
Sulia holds her own now, flying up as she pushes demons back. She gets distance as much as she can, staff slamming them hard as...
Go.
Antenora
HP: 893/900
SLAs Used:
Empress Sulia
HP: 713+200/770
Aura: Divine (30ft)
Resources: Channel Energy 15/16 Inspire Confidence 9/9 Inspire Nobility 6/6 Charity Domain 3/3 Nobility Domain 3/3 Suffering Domain 3/3, Divine Shield 13/14
Spells Used:
SLAs Used:
Notes:
Deeming the ranks sufficiently thinned and the surviving balors softened up enough by everyone else's attacks, Alicia goes for a finishing attack as her sword sweeps a deadly swathe through all the remaining demons within her reach!
[20:31] <@Ebiris> roll 1d20+105 blinding speed, 6th level arcane strike, channelled vivacious/maximised/enhanced combust, whirlwind attack
[20:31] <Penuche> Ebiris invokes Penuche's magic: < 120 > [d20=15]
[20:31] <@Ebiris> roll 1d20+50 SR
[20:31] <Penuche> Ebiris invokes Penuche's magic: < 56 > [d20=6]
[20:31] <@Ebiris> roll 8d6+64+5d6+6d4+320
[20:31] <Penuche> Ebiris invokes Penuche's magic: < 440 > [d6=3,3,6,2,3,3,1,4,1,4,4,6,2][d4=3,1,1,3,2,4]
If that leads to a lot of them popping I'll use my swifts to throw up quickened walls of force to protect Antenora.
Alicia HP: 1244+191/1244
Sorcerer spell slots: 6/16/16/14/9/9/11/9/9/5/8/5/7/7/6/2
They are going to pop, so how do you plan to protect her?
As the balor explosions ripple out, a quick word of magic from Alicia has a pair of walls of force appear on either side of Antenora, intersecting at a corner on her side facing most of the demons.
Quote
BBBB|###
BBBB|A##
##BBBB##
##BBBB##
Helpful ascii diagram showing the basic concept.
Sorcerer spell slots: 6/16/16/14/9/9/11/7/9/5/8/5/7/7/6/2
> roll 112d6 balors go boom everywhere!
<Penuche> Kotono invokes Penuche's magic: < error: maximum number of dice is 100 >
> roll 100d6+12d6
<Penuche> Kotono invokes Penuche's magic: < 417 > [100d6=373][12d6=44]
> roll 373+44
Alicia halves, Antenora's safe and Sulia evades. HP after that?
