Temporal pixies
"I have some knowledge of it," Sanzha agrees, "Do you need to hear it?"
"Only if you feel it's relevant to anything we may find there, or any trouble we might run into." Moore says. "Or if there's any relevant policies governing it that you're aware of. If not, then we can simply transport ourselves to the closest point and make our way there. I assume you can't simply Gate there."
A look of amusement, "The entire place is trouble. What do you expect of such a foolish idea as what spawned it?" Lady Sanzha replies.
"It's obscure enough that even I don't know about it," Sylvie points out, "Enlighten us." Her voice gets just a bit of an edge, a point to it.
With ever so slight a smile, "Oh, first of all, it's an icy tomb," Lady Sanzha explains, "But that's merely a point of charm, not its actual purpose. It's said it has endless stairways, and it may be true. Long ago, an ambitious marid sought to copy the Infinite Stair, to create an artificial hub to all the planes. This went poorly as you imagine, and the place was sealed and forbidden from being spoken of."
Epic Mage Armor (CL24), Mind Blank (CL17) and Afina's Perfect Sight (CL27).
Cresiel
HP: 1018/1018 (regeneration 21)
Aura: Protective 20ft (+4 deflection/+4 resistance vs evil), Divine 10ft (various)
Resources: Holy Fury 40/40 (enc) Channel Energy 18/18 Divine Retribution 1/1 Blinding Speed 25/25 Knight's Challenge 15/15 Smite 1/1 Endurance Domain 1/1 Protection Domain 1/1 Renewal Domain 1/1
Spells Used:
SLAs Used:
Spells Active: Detect Evil (CL36), Detect Snares and Pits (CL36), Discern Lies (CL36), True Seeing (CL36)
Notes: Adjacent allies gain a shield bonus equal to Cresiel's shield bonus. Use divine shield as a swift action.
Jetina
HP: 864/864 (fast healing 5)
Aura: Courage 10ft (+4 morale vs fear), Positive Energy 10ft (1 hit point healing/round), Divine 10ft (various)
Resources: Smite Evil 7/7 Smite 7/7 Channel Energy 17/17 Emergency Healing 8/8 True Believer 1/1 Blinding Speed 25/25 Charity Domain 1/1 Life Domain 1/1 Nobility Domain 1/1
Spells Used:
SLAs Used:
Spells Active:
Notes: Divine Vigor is +10ft land movement and +2 temp hp per hit die. Divine Shield is Cha mod to shield bonus to armor class.
Sylvie
HP: 798/798
Aura: Divine 10ft (various)
Resources: Inspiration 30/30 (enc) Opportunistic Piety 17/17 Mimic Class Feature 8/8 Mentalism Domain 1/1
Spells Used:
SLAs Used:
Spells Active: Bibliotheca Arcana (CL37), Lore of the Gods (CL37), Superior Mighty Wallop (CL36), Sylvie's Mental Peak (CL36)
Notes:
Lady Sanzha
HP: 792/792 (fast healing 3)
Resources: Channel Elements 17/17 Bardic Music 36/36 Water Devotion 1/1 Trident Elemental Damage 3/3 Nobility Domain 1/1
Spells Used:
SLAs Used:
Spells Active:
Notes:
"Huh, that explains what I learned of it." Moore says. "I thought it was connected to the Infinite Stair, but that makes a lot more sense." A nod. "Do you imagine we should protect ourselves from anything in particular? I imagine Cold may not be a bad idea."
"Cold for certain," Sanzha says, "Beyond that, be flexible. Whatever's in there is strong and has had ages to grow stronger. We may be in for a good fight."
"Good," Cresiel says, "We will purify it if it must be purified and we will cleanse it."
Moore nods. "Then, by your leave, wherever is the closest place we can get to get there." He says.
Let's have Jetina throw up Mass Energy Immunity (Cold), CL36 on everyone. We can handle the other things as stuff comes up.
"The Frozen Ocean of Alraj," Lady Sanzha appears, "Do be aware the natives can be hostile."
Also mass energy immunity (cold) CL 36 from Jetina.
Cresiel
Spells Used:
SLAs Used:
Jetina
Spells Used:
SLAs Used:
Spells Active:
Sylvie
HP: 798/798
Spells Used:
SLAs Used:
Notes:
Lady Sanzha
Spells Used:
SLAs Used:
Spells Active:
Notes:
Cresiel
Spells Used:
SLAs Used:
Jetina
Spells Used:
SLAs Used:
Spells Active:
Sylvie
HP: 798/798
Spells Used:
SLAs Used:
Notes:
Lady Sanzha
Spells Used:
SLAs Used:
Spells Active:
Notes:
Moore nods and will Greater Plane Shift them to that location, unless Sanzha wants to do it!
It's cold.
It's so cold that it almost freezes your heart.
A white, wintry haze is in the air - no the water. The water is full of floating fragments of ice, bitterly cold and frigid. You stand atop a great, churning and frozen ocean, flash frozen mid movement as you stand atop a cresting wave. Your divine vision is sufficient to see ahead - nothing but the ocean, and great titans of ice and water, lumbering about.
"Was the freezing a result of what they tried to do here?" Moore asks.
He trusts Sanzha will lead them wherever it is they go from here in due time.
"No," Sanzha replies in Aquan as you begin to swim ahead. "This is close to the border with Ice. It's a matter of location."
You can see elementals stirring - great ones of water and others of ice - and starting to look the party's way.
Moore nods and will follow after Sanzha. Should any of the elementals decide they want to fight, they'll learn rather quickly why it's not a wise idea.
However, he'll follow Sanzha's lead if they get approached!
Party order?
They're coming your way, alright - you're going to have something, quite possibly a fight. Four of what you suspect are elder water elementals, and two elder ice elementals, as well as an ice elemental monolith.
Sanzha, Moore, Cresiel, Sylvie, Jetina.
"I'll take your lead." Moore says. "If we have to rough them up to get them to back off we can."
Lady Sanzha merely steps forward and utters:
I am Sanzha. Wind and Air serve me. Flee us.
> roll 1d20+75 intimidate (+10 circumstance)
<Penuche> Kotono invokes Penuche's magic: < 84 > [d20=9]
At these words the elementals stop and flee, turning tail from her words.
