Crossed swords
Started by Anastasia, July 21, 2020, 12:45:28 PM
Moore will pass through and follow along!
Between that and a spell by Elle, the party is able to pass through all of them.
Deeper down and in. The jungle lightens and ceases as you go deeper within - and yet ahead is a far larger chamber, and in it you can see brighter light shine out.
Seira leads the way, in case of any unexpected dangers.
If Moore hadn't witnessed a few things brighter than this before, he'd probably have to squint to see.
He wonders how far they'll have to even go, but for now, just continues on!
Within is a great place of light, comign from everything - including a vast, vast lake of boiling green acid, which roils like a sea at storm. There are no islands within it, only stormy expanses.
Donald whistles, "So it's somewhere in here, is it?"
"I'm immune to acid, so I'll take a look below," Seira voices, shielding her artifacts just in case and descending into the lake.
The stomach, maybe?
Moore nods to Seira and will wait for her to explore!
Seira dives in. The acid does nothing to her as she begins to search about - it's a vast, deep space here with poor visibility. How are you going to do this?
Happily, her perception is boosted magically and she's been relying on her senses here as it is with all that blinding light. She also tries a bit of divination, since it might not be blocked while she's inside the actual creature interfering with divinations!
Sensual Blessing gives me scent, low-light vision, darkvision 60ft, blindsight 60ft and tremorsense 60ft. Also will try something like Locate Object with a divinely-boosted range to look for Wildaros.
Gimme perception and a d100 real quick.
Perception 10 for 120.
20:10 <Corwin> roll 1d100
20:10 <Penuche> Corwin invokes Penuche's magic: < 98 > [d100=98]
You wander in the acid and explore - but deific senses are huge here. You soon enough can feel a large lump lying amid all this acid, a ways away but not fitting in with anything else.
Time to go and check it out! Seira comes near the lump, and then uses telekinesis to try and clear up its surface so she'll have a better idea what it is.
It appears to be a large crystalline growth. The acid doesn't burn it and it seems intact.
Seira tries to pick it up! Telekinetically!
