Crossed swords
Started by Anastasia, July 21, 2020, 12:45:28 PM
Triple checking, +8 from the stat booster, +14 from Inspire Competence, +8 from Song of Fortune, +2 more from Share Skills (the spell), then +1 for aiding, so that's 33.
In that case Elle takes 10.
Green Crystal: This crystal is identical to steel in most ways. A weapon made of this crystal deals double damage to undead creatures, while armor made from it grants fast healing 20 to the wearer and a +2 bonus to Constitution. You have two large crystals of this, which is enough for 9 weapons or 2 suits of armor each.
Orange-Green Crystal: This crystal is identical to adamantine in most ways. A weapon made of this crystal grants a +8 bonus to attack rolls against non living creatures, while armor made from it grants a +5 bonus to the caster level of conjuration (healing) spells. You have two large crystals of this, which is enough for 8 weapons or 2 suits of armor each.
Red-Green Crystal: This crystal is not suitable to be used in weapons or armor. If a large chunk is as an optional material component with a spell, the spell heals 10 hit points per caster level to any living creature affected by the spell. This stacks with any other healing the spell provides. You have two large crystals of this, which is enough for 50 optional material components.
"Goodness." Moore says with a bit of awe. "I bet you'd have to spend a lifetime or two on Jovar to find something even remotely as potent as these."
"You might be able to find and equal there one day, but not lightly," Elle admits, "I've never come across crystal this pure or powerful." She taps one of the red-green crystals. "As long as we don't enchant it further or use it up, broken off pieces will merge back with the greater whole."
Jetina studies it, "It's beyond incredible. It's so supercharged with life energy." A tap of her chest," This armor is incredible, but I want a suit of armor made of the orangish crystal.
"How about layering the Aegis with the green crystal?" Seira's avatar asks, popping in. "And, in fact, would it be possible to make shields rather than armors for the same effect? Does that alter the amount of available material any?"
Elle considers this, "Shields should work and use slightly less than a full set of armor. I'll have to do some measuring, but you could squeeze a bit more out of them that way. As to augmenting existing equipment, possibly. At least the Aegises should be uniquely suited for it."
"It is, isn't it!" Seira agrees cheerfully. "How about eating the crystals? That sometimes works, but would it do anything here?"
Elle considers, considers a long time. "No," she finally says, "I don't see anything worthwhile coming of it, and I suspect most lesser creatures wouldn't survive long with it in them. A degree of separation is best. Few of us can match the unchallenged life force of a tarrasque."
"Makes sense. So let's see who wants what? And in the meantime, I'll visit Hope's Landing?"
I think we can go over wishlist/claims OOC, so let's move on?
Moore nods. "That sounds fine to me."
Sure, go ahead and move plans for what y'all plan to do with this to loot. I'd like to see posts from both of you so I can start to sort this out.
So you were working with Wildaros. Go ahead and sort out how y'all are using that first and I'll sort that, then we'll move on.
I think the armors are much superior to the weapons. Since there are pairs I think it's fair each of us gets one crystal per type. Barring situations where someone wants a weapon or if shields would allow for more of them. If Moore really wants two orange crystals, we can trade. Works?
As for Wildaros, I'll gain all of my potential permanent hp via grinding, then give it over to our guys. Afterwards, Moore's guys can do it, and we'll see from there. The grinding is summoning minions and dispelling them till one reaches 100 temp hp.
Moore would be curious what they might be able to do with a green crystal as a shield and the mock up Set Piece Syllen stuff. Other than that and Jetina wanting the Orange Green for something (probably doesn't have to be armor in her case) Seira can keep everything else. :)
As requested last post, please move that conversation to loot so I can sort that all out there.
Thus Moore, Jetina and Seira head to Hope's Landing and...
What's your play here? Go ahead y'all.
Sorry, it wasn't quite clear.
Moore will bring Seira to Will to introduce them!
