Mystran rest
Started by Anastasia, July 21, 2020, 12:51:45 PM
Then come closer!
Suddenly, the vampire's head splits apart as the water washes him away. A great hand of blood comes forth, going right for your neck.
> roll 1d20+100
<Penuche> Kotono invokes Penuche's magic: < 106 > [d20=6]
AC?
106! But I'll pop my last many moments of prescience to make it 136 because fuck that guy.
Also what exactly is he doing, like is this a spell? If he's targeting Alicia through scrying means she does have a pretty beefy nondetection up (DC 54 to beat)
Aliciavatar HP: 855+20/855
Active spells: Extended mind blank (CL 39), extended nondetection (CL 39), extended ray deflection (CL 39), repelling shield (CL 38), epic mage armour (CL 36), sensual blessing (CL 38), greater foresight (CL 38), seira's arcane thesis (CL 38), freedom of movement (CL 36), greater heroism (CL 36), greater visage of the deity (CL 36), recitation (CL 36), true seeing (CL 36), divine insight (CL 36), mass energy immunity (cold) (CL 39), celestial valor (CL 36), opal inviolability (CL 37)
Defences: AC 106, CMD 114, spell resistance 51, energy immunity (cold, unholy), status immunity (polymorph, petrification, disease, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +10 armour AC, +25 competence perception, +7 insight AC/ref/init, +4 str, +2 dex, +4 con, +2 int, +4 wis, +4 cha, +9 shield AC, +3 luck AC/saves, +4 morale attack/skills/saves, +4 sacred attack/damage/AC/saves, +6 bonus hd, +6 competence attack, +4 competence fort, +10 SR checks, +5 spell DCs
Perceptions: Arcane sight, darkvision 60, true seeing, scent, tremorsense/blindsight 60, perception +79
Sorcerer spells: 6/16/15/13/6/9/14/8/8/8/5/6/6/4/5/2
Duskblade spells: 6/22/22/22/11/6/1
Many moments of prescience: 0/4
As near as you can tell - and you can tell pretty well - it's some sort of innate power to him. If he's the First Vampire, it's probably related to that somehow. Dominion over vampires, domination and worse.
Yet your divine will freezes that hand an inch from your throat, at which point it crumbles to dust. The vampire is washed away by the waters, no further attack as a great cheer goes up at your victory.
Can I tell what happened to the soul of the vampire I just killed? Is it going to the well of souls or being grabbed by the soul eater?
Also can I track the power that was just used against me to tell where the first vampire is? I can pop one of my free action divinations from greater foresight to help, I already made a CL check for the spell earlier that beat his defences to get the Blood Castle answer. Obviously I want more than those two words, like knowing what plane he's on would be nice.
The soul is moving along normally.
You could use a power or ability to do so that's suitable, for. You have a round or so to work with so go ahead.
Does remote sensing work? An attack could be relevant to her portfolio via the war domain? Otherwise I'll just pop that free action divination on the avatar.
The avatar recasts many moments of prescience and adjusts the dimensionally warped space so as to clear a path ahead for everyone while keeping the river flowing to the side of the chamber if needed. "I will see to the destruction of the soul siphon here before calling my work done," she says for the benefit of the Aurora warriors, leading the way ahead towards the blasphemy that incited her presence here.
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 39), extended nondetection (CL 39), extended ray deflection (CL 39), repelling shield (CL 38), epic mage armour (CL 36), sensual blessing (CL 38), greater foresight (CL 38), seira's arcane thesis (CL 38), freedom of movement (CL 36), greater heroism (CL 36), greater visage of the deity (CL 36), recitation (CL 36), true seeing (CL 36), divine insight (CL 36), mass energy immunity (cold) (CL 39), celestial valor (CL 36), opal inviolability (CL 37)
Sorcerer spells: 6/16/15/13/6/9/14/8/8/8/5/5/6/4/5/2
Many moments of prescience: 4/4
Remote sensing could work, sure.
It lies ahead. It is a hunger, a twisted altar. It is carved of red stone rather well, above average work to your eye. The top of it has a white cloth that is stained red laid atop it.
Meanwhile, you can see a figure. A beautiful thing. Gorgeous, really. Masculine and looming, long black hair and wearing a loose, open silk shirt and leather pants. He is a paragon of the masculine, muscled and slender, sheer sexual appeal that borders on the obscene.
Then he looks your way, as if to meet your eyes, and smiles.
In that moment you sense an endless ravine, a chasm of hunger that screams out for you. The creature before you does nothing to hide its nature, merely looking on with rapacious, ravenous hunger. It slowly licks its lips, perfect tongue and long, sharp fangs seen as it does.
Her avatar studies the twisted altar while the real Alicia discerns the location she is viewing.
Any tricks to the altar or will unbinding/violence solve its problem?
No tricks, either should suffice, but unbinding would be much cleaner.
Alicia's avatar releases a pulse of liberating energy!
Just because she's a lawful deity doesn't mean she doesn't appreciate freedom. Everything in its proper place, and the proper place in this case is free!
And does my remote sensing tell me what plane the first vampire is on while he's being all Draco in Leather Pants at me?
The Abyss. Death's Stare in particular.
Before that the altar melts like snow in the sun, souls freed and coming forth from your liberation. There is a sense of relief from them as this unholy work is done, the affront against you no more.
"It's done, I leave the rest to you heroes of Aurora," Alicia turns to the others, focusing on Nial in particular as the blessing of being her familiar leaves him, returning him to normal. "This could have been your time, Nial. But I would not permit the affront this place prepared for you. Treat every day that comes as a gift."
Nial kneels before you, "I will remember this lesson," he vows.
Alicia nods and then she plane shifts away.
Meanwhile the real Alicia goes over what if anything is known about Death's Stare.
[18:27] <@Ebiris> roll 1d20+114 buffed up planes check (greater heroism, divine insight, guidance of avatar, improvisation, greater visage of the deity) using Rei
[18:27] <Rei-chan> Ebiris rolled : 1d20+114 buffed up planes check (greater heroism, divine insight, guidance of avatar, improvisation, greater visage of the deity) using Rei --> [ 1d20=11 ]{125}
Death's Stare is said to be a lost layer of the Abyss: 389. The legends don't get into details, but Orcus did something there in a battle against another demon prince - possibly Demogorgon or Pale Night, or maybe Graz'zt. It's said that the dead are as home there as in Thanatos, and that something nothing there ever dies forever, but rises in unholy life.
