Mystran rest
Started by Anastasia, July 21, 2020, 12:51:45 PM
> roll 1d20+33
<Penuche> Kotono invokes Penuche's magic: < 44 > [d20=11]
It's like trying to move sludge. A sludge that only slowly forms into the portal you desire.
But you are not unopposed. The shadows within the original portal scream silently as they erupt out, like a water cannon directing a massive spray of them at all of you.
Fort all.
Marie's invisible and not standing in the same place as her visible illusion if that helps her avoid this.
[18:21] <@Ebiris> roll 1d20+98 Alicia fort, improved mettle
[18:21] <Penuche> Ebiris invokes Penuche's magic: < 101 > [d20=3]
[18:21] <@Ebiris> roll 1d20+68 Marie fort
[18:21] <Penuche> Ebiris invokes Penuche's magic: < 69 > [d20=1]
Alicia HP: 1284/1284
Active spells: Many moments of prescience (CL 36), Extended mind blank (CL 39), extended nondetection (CL 39), greater heroism (CL 36), extended ray deflection (CL 39), epic mage armour (CL 36), sensual blessing (CL 36), greater foresight (CL 38), keen edge (CL 36 on sword), dance of the unicorn (CL 36), extended greater anticipate teleportation (CL 38), repelling shield (CL 38), freedom of movement (CL 36), greater visage of the deity (CL 36), recitation (CL 36), true seeing (CL 36), death ward (CL 36), energy immunity - cold (CL 38), good hope (CL 38), Seira's Arcane Thesis (CL 38)
Defences: AC 101, CMD 163, spell resistance 51, energy immunity (negative, fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +4 morale skills, +10 armour AC, +25 competence perception, +7 insight AC/ref, +40 str, +20 con, -2 dex, +2 int, +4 wis, +4 cha, +15 natural armour AC, -8 size attack/AC, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC, +2 ability checks, +5 spell DCs, +10 SR checks, +6 competence attack, +4 competence fort, +14 morale attack/damage
Sorcerer spell slots: 6/16/16/14/9/9/15/9/9/0/8/1/7/4/5/2
Many moments of prescience: 4/4
Marie HP: 830/830
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 36), extended nondetection (CL 36), greater heroism (CL 36), greater arcane sight (CL 36), epic mage armour (CL 36), sensual blessing (CL 36), repelling shield (CL 36), freedom of movement (CL 36), recitation (CL 36), true seeing (CL 36), bibliotheca arcana (CL 36), death ward (CL 36), energy immunity - cold (CL 38), superior invisibility (CL 40), good hope (CL 38)
Defences: AC 105, CMD 115, spell resistance 51, energy immunity (negative, cold, electricity, fire, sonic), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 51), freedom of movement
Stat buffs/penalties: +4 morale skills, +25 competence perception, +9 shield AC, +3 luck AC/attack/saves, +10 morale saves, +10 dodge AC, +2 morale ability checks, +6 competence attack, +4 competence fort, +14 morale attack/damage
Sorcerer spell slots: 6/8/10/8/8/9/9/7/7/6/7/4/6/6/3
Many moments of prescience: 1/4
600 damage all. Alicia nulls, Marie and Latha take full.
Alicia isn't touched. No, her blade and her light protect her.
It doesn't stop Latha's screams. You see shadows maul her, even as dozens burn away from her aura. You see them swarm her, dying in droves and yet more of them bombarding her. You hear Marie, her body torn again and again.
Not yet, Alicia. I'm not done with you yet.
The portal's almost done, just a little more and it should be ready and open.
Go.
Latha
HP: 1000/1010(800)
Aura: Holy Light 30ft (7d6+7 damage vs evil/round) Protective 20ft (+4 deflection/+4 resistance vs evil), Divine 10ft (various)
Bonuses: Attack+0, Damage+0 AC+12 (+12 armor), Saves+0, Skills+0, Checks+0
Resources: Channel Energy 15/15 Sun Devotion 4/4 Sunweaver 3/3 Vision of Heaven (rnd) 1/1 Zeal Domain 1/1
Spells Used:
SLAs Used:
Spells Active: Epic Mage Armor (CL36), Many Moments of Prescience (CL38), Death Ward (CL36), Mass Energy Immunity (Cold) (CL38)
Notes: Level + 22 extra damage per hit vs undead during sun devotion.
Many Moments of Prescience: 4 uses for a +30 insight bonus.
Being invisible didn't help Marie?
"Heal yourselves, I have this!" Alicia says, a quickened wall of force blocking off the other portal and its nasty shadows.
Invisible still, Marie grabs for Latha's hand so she'll know where to aim the healing.
[18:41] <@Ebiris> roll 1d20+44 Alicia charisma, just her this time
[18:41] <Penuche> Ebiris invokes Penuche's magic: < 51 > [d20=7]
Sorcerer spell slots: 6/16/16/14/9/9/15/8/9/0/8/1/7/4/5/2
Marie HP: 230/830
Area attack, so no.
The portal opens - flickering and weak, but it's open at least for the moment.
Latha's action pending Alicia here a sec, so go ahead and react.
"Heal and go, I'll be right behind you!"
They'll most likely be emptied out back in the same place they entered the demiplane through and it's far from friendly territory.
Latha flees at that chance, bloodied and alive, her escape at hand. She goes through the portal, gone in an instant.
Marie?
Not healed by Latha after all, Marie heals herself before she rushes after her. "That's me!" her illusion says right before the real Marie goes through the portal and the projected image goes slack.
Using her heal SLA on herself before she goes.
Marie HP: 530/830
Legit DM mistake, she meant to move and heal. Somehow that got lost in the post. She popped a mass heal as you fled. +250 HP both of you.
As Latha and Marie tumble through to the other side, meanwhile?
> roll 1d20+50
<Penuche> Kotono invokes Penuche's magic: < 53 > [d20=3]
Opposed Charisma check.
Latha
HP: 900/1010(800)
Spells Used:
SLAs Used:
Marie doesn't use her SLA then.
[19:32] <@Ebiris> roll 1d20+53 many moments of prescience popped
[19:32] <Penuche> Ebiris invokes Penuche's magic: < 63 > [d20=10]
Many moments of prescience: 3/4
Marie HP: 730/830
With her power concentrated, Alicia holds on. It's just long enough to resist Shar's pressure, the portal winking wildly but intact - at least for a few more moments.
Go.
Shrinking down to more manageable size, Alicia hurries through the portal she's made!
Escape.
You take a gasp of air.
You float in the Silver Sea of the Astral Plane. Latha and Marie are besides you as the portal lets out one last shudder and fails.
"The Astral," Latha says, at the ready, "It does not feel like a falsehood. But how?"
Take 10 for 70 on planes for relevant insights.
"I expected the ethereal," Alicia admits, looking around.
Your best guess is that something between your interference and whatever Shar was doing caused the portal to throw you out into the Astral. It's a default option for when something goes off with teleportation or portals. Your learned insight suggests it probably only worked because you're a goddess of magic.
As long as it isn't the Far Realm, but that's thankfully a rare fluke.
