The full wheel
Started by Anastasia, August 07, 2020, 12:29:32 PM
Will studies them, "I see," it finally says. "This is what you found?"
"Yes." Moore says. "I know it isn't exactly helpful to you, but I thought maybe if we worked together we might be able to create something... maybe using Hope's Landing and my ability to change it as a sort of... 'base'? If that makes sense?" He offers. "I'd like to try and see if we can emulate the power that was used in creating the effect from Syllen's gear, so that we could just make the other pieces in the set if need be, or use it for other things going forward."
"Watch," Is the answer, "Can you follow this?"
Intelligence check, +1 bonus.
22:23] <Nephrite> roll 1d20+13+15 Int check
[22:24] <Penuche> Nephrite invokes Penuche's magic: < 32 > [d20=4]
Forgot the bonus, so that's 33.
With some work - yes, yo uthink you could copy a good part of it, at least. Probably.
"Ah! Yes." Moore nods. "I think it's worth a shot of trying, at least."
Moore will grab Sylvie for this since why not if they're going to make a serious attempt at it.
Okay, what's your goal here?
The first step will be if they can at all figure out what happens with the actual Syllen pieces, since that's ultimately what they're going for. Can they figure out what makes them do what they do, basically.
If they need to experiment with something else first that's fine.
You could. What do you want to experiment on in particular? Matters.
So, to break it down mechanically:
If 2 Syllen Pieces, what happens? (I.e. is it a magical 'effect' that enhances both)
If 3 Syllen pieces, what happens? (Is it just a stronger version of the previous 'effect', or something different?)
Is the 'effect' itself tied to the pieces somehow, or could it be moved to some other items through some means?
Is the 'effect' something that, should they be able to understand fully, something that could be replicated via an artifact, maybe? They'd obviously have to go to someone else to have the artifact created, but this is mostly just seeing if it's a possibility. I'd assume they'd need to go to someone with a portfolio over magic in this case.
No, I mean what are you experimenting on? A magical item? Raw magic? Spells? You said you were going to experiment on something.
Oh, I'm sorry.
Okay, he will first create two +1 Good Daggers and then see if they can apply the theoretical information from the notes to make them somehow 'stronger' (maybe aiming to make them +2 daggers in the presence of each other).
Cool. What's your item creation gold limit?
You think you could do something like that, but not precisely copy it. You'd also need someone with less limits or to make them the hard way.
