Silken touch
Started by Anastasia, October 06, 2020, 12:37:12 PM
This is an awkward spot for a few reasons, so go ahead and sketch out what you'll do on your turn and I'll adjudicate/roll init as needed.
Compress space to put myself in melee with the avatar and full attack.
Alicia HP: 831+20/831
Active spells: Many moments of prescience (CL 38), extended mind blank (CL 39), extended nondetection (CL 39), greater heroism (CL 36), extended ray deflection (CL 39), epic mage armour (CL 36), sensual blessing (CL 36), greater foresight (CL 38), keen edge (CL 36 on sword), dance of the unicorn (CL 36), extended greater anticipate teleportation (CL 38), repelling shield (CL 38), freedom of movement (CL 36), greater visage of the deity (CL 36), recitation (CL 36)
Defences: AC 87, CMD 113, spell resistance 51, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 54), freedom of movement
Stat buffs/penalties: +4 morale attack/skills/saves, +10 armour AC, +25 competence perception, +7 insight AC/ref, +4 str, +2 dex, +4 con, +2 int, +4 wis, +4 cha, +1 natural armour AC, +9 shield AC, +3 luck AC/attack/saves
Perceptions: Arcane sight, 5 mile tremorsense/blindsight/scent perception +87
Sorcerer spell slots: 6/16/16/14/9/9/15/8/9/5/8/6/7/7/6/3
Moments of prescience left: 3
Go for it, you have supreme.
Alicia doesn't give that avatar a chance to do anything, a mental effort twisting space to connect the area next to her with what's behind the avatar. A quick shout will be all the warning the avatar gets as her magical defences are stripped away before Alicia's blades fall on her.
Quickened superb dispelling and full attack, how many dispels first?
Sorcerer spell slots: 6/16/16/14/9/9/15/8/9/5/8/6/7/6/6/3
Roll the first two dispels separately from the rest.
#140
[18:15] <@Ebiris> roll 1d20+44
[18:15] <Penuche> Ebiris invokes Penuche's magic: < 63 > [d20=19]
[18:15] <Penuche> Ebiris invokes Penuche's magic: < 62 > [d20=18]
[18:15] <@Ebiris> roll 23#1d20+44
[18:15] <Penuche> Ebiris invokes Penuche's magic: < 64, 58, 53, 63, 58, 52, 59, 49, 47, 51, 62, 46, 55, 56, 57, 61, 56, 62, 51, 54, 50, 55, 64 >
Alicia's blades then follow hot on the heels of that magical sundering!
[18:20] <@Ebiris> roll 1d20+91 channelled maximised/enhanced vampiric touch, 14th level arcane strike
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 95 > [d20=4]
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 99 > [d20=8]
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 104 > [d20=13]
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 100 > [d20=9]
[18:20] <@Ebiris> roll 1d20+86 channelled maximised/enhanced vampiric touch, 14th level arcane strike
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 90 > [d20=4]
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 99 > [d20=13]
[18:20] <@Ebiris> roll 1d20+81 channelled maximised/enhanced vampiric touch, 14th level arcane strike
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 91 > [d20=10]
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 85 > [d20=4]
[18:20] <@Ebiris> roll 1d20+76 channelled maximised/enhanced vampiric touch, 14th level arcane strike
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 89 > [d20=13]
[18:20] <Penuche> Ebiris invokes Penuche's magic: < 85 > [d20=9]
[18:21] <@Ebiris> roll 1d20+48 SR for vampiric touch
[18:21] <Penuche> Ebiris invokes Penuche's magic: < 66 > [d20=18]
[18:21] <@Ebiris> roll 1d20+5 rank check to inflict negative levels
[18:21] <Penuche> Ebiris invokes Penuche's magic: < 13 > [d20=8]
+4 more on the rank check from strata.
[18:22] <@Ebiris> roll 1d8+33+2d6+3d6+120+14d4 and 1 negative level if rank check won
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 217 > [d8=6][d6=2,5,6,5,2][d4=1,2,4,2,4,1,2,4,4,3,4,4,2,1]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 202 > [d8=1][d6=4,2,2,4,4][d4=2,2,3,2,1,3,1,4,1,4,3,3,2,1]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 205 > [d8=5][d6=3,3,2,2,3][d4=2,4,3,4,1,1,1,1,3,2,4,2,3,3]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 209 > [d8=5][d6=2,2,2,5,2][d4=1,2,4,3,4,3,4,4,4,2,1,2,1,3]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 205 > [d8=2][d6=1,6,1,6,2][d4=4,2,4,2,1,4,3,2,2,2,2,1,4,1]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 211 > [d8=8][d6=4,3,4,1,5][d4=4,3,2,3,3,2,3,4,1,2,1,1,2,2]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 214 > [d8=3][d6=6,3,6,5,3][d4=4,1,4,4,2,3,1,3,2,1,4,2,1,3]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 205 > [d8=7][d6=1,5,4,2,1][d4=2,4,2,2,4,1,1,1,2,4,3,1,4,1]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 216 > [d8=7][d6=2,1,3,6,5][d4=1,4,1,2,4,4,3,4,1,4,2,3,2,4]
[18:22] <Penuche> Ebiris invokes Penuche's magic: < 212 > [d8=5][d6=6,2,1,5,6][d4=4,1,1,1,3,2,3,2,4,1,4,1,4,3]
Alicia HP: 831+120/831
Duskblade spell slots: 6/23/22/23/11/7/15
> roll 1d20+12
<Penuche> Kotono invokes Penuche's magic: < 16 > [d20=4]
She's rolling remarkably poorly. Also that's only 4 since avatar.
Talona's avatar moves with inhuman speed, even as much of the magic around it crumbles. It sidesteps your first blow, yet the second and third slash across her side. The fourth bloods her again, across the shoulder. She manages to leap back, wounds leaking black, coagulated blood. "Fast!" she utters, face a loathsome visage, nothing but ruin and death.
Anything else for your turn?
Oh! Spell power also added to the vampiric touch damage so +7 damage on each of those. I take it 99s and above hit so four of them for +28 damage? Doubt that kills her but it's more temp hp for me.
Alicia merely tuts. It wasn't fast enough. She should've fought harder but she underestimated an avatar and wanted to save some surprises for the real Talona.
A desultory throw of her sword sends it scything through the air to hopefully blood Talona one more time, or even put her down if she's lucky.
Quickened whirling blade with my last swift.
[19:09] <@Ebiris> roll 1d20+92+18 whirling blade, same bonuses as the full attack, smite evil on this one
[19:09] <Penuche> Ebiris invokes Penuche's magic: < 123 > [d20=13]
[19:10] <@Ebiris> roll 1d8+34+2d6+3d6+120+14d4
[19:10] <Penuche> Ebiris invokes Penuche's magic: < 201 > [d8=8][d6=1,2,1,2,2][d4=1,2,2,2,2,1,4,4,1,2,4,3,2,1]
+7 more damage from the vampiric touch I forgot to add on the roll itself.
Alicia HP: 831+127/831
Sorcerer spell slots: 6/16/16/14/8/9/15/8/9/5/8/6/7/6/6/3
Correct on all counts there in the first bit.
Another rip, sudden and savage. The whirling blade goes through Talona's side, more dead blood spilled as she says in a low growl, "You arrogant bitch!"
Init.
> roll 1d20+29 Talona is fast
<Penuche> Kotono invokes Penuche's magic: < 32 > [d20=3]
> roll 1d20+26 Jessica
<Penuche> Kotono invokes Penuche's magic: < 38 > [d20=12]
> roll 1d20+13 Syala
<Penuche> Kotono invokes Penuche's magic: < 28 > [d20=15]
Init is Alicia (Supreme) > Jessica (38) > Talona (32) > Syala (28)
More in the next post, which is incoming.
Oh, also another negative level on that last hit too, can't forget!
> roll 1d20+77 (+15 shadow form and -90 HP, +2 charge, +2 fiend bane)
<Penuche> Kotono invokes Penuche's magic: < 94 > [d20=17]
A shadowed blur. Jessica is with you, a sudden strike that seeks to impale Talona through the throat. But the avatar jukes to the side at the last moment, the attack avoided by inches.
A moment later she leaps back as...
What's your current reach? Matters.
Jessica
HP: 635/725
Aura: Telepathic Block 20ft (Stops telepathy/summons) Magic Circle Against Evil 10ft (Protection from Evil), Divine 10ft (various)
Bonuses: Attack+0, Damage+0 AC+10 (+10 armor), Saves+0, Skills+0, Checks+0
Resources: Defensive Roll 1/1 Plane Hop 1/1 Superior Invisibility 3/3 Ghost Form 3/3 Shadow Form 2/3 Retribution Domain 1/1
Spells Used:
SLAs Used:
Spells Active: Epic Mage Armor (CL36), Nondetection (CL39)
Notes: +4 bonus to people who flank with her instead of +2. Use d8s for sneak attack against evil instead of d6s.
Syala
HP: 720/720
Aura: Protective 20ft (+4 deflection/+4 resistance vs evil) Divine 30ft (various)
Bonuses: Attack+0, Damage+0 AC+18 (+18 armor), Saves+0, Skills+0, Checks+0
Resources: Rage 8/8 Divine Blast 14/14 Family Domain 3/3 Wrath Domain 2/2 Add Twin 7/7 (non epic only)
Spells Used: 1 6th level, 1 14th level spell
SLAs Used:
Spells Active: Epic Mage Armor (CL36), Nondetection (CL39), Syala's Blessing (CL36)
5 feet, I did not go big to my shame.
> roll 1d20+43 (-4 negative levels, +2 spell penetration, just to be clear here)
<Penuche> Kotono invokes Penuche's magic: < 59 > [d20=16]
SR Alicia?
Not 5 negative levels? I hit with 99, 100, 104, 99, and 123 didn't I?
Not that it matters (unless the extra hp damage also wasn't counted and would be enough to kill her). SR is 51.
Typo, yes. Either way it gets by yours and also gets by Jessica's. Fort save, both of you.
