Shadow rondo
Give me a caster level check on waves too? Something the hawk man has in play.
[17:27] <@Ebiris> roll 1d20+42 waves of exhaustion caster level
[17:27] <Rei-chan> Ebiris rolled : 1d20+42 waves of exhaustion caster level --> [ 1d20=15 ]{57}
> roll 1d20+28 nalfeshnee reflex
<Rei-chan> Kotono rolled : 1d20+28 nalfeshnee reflex --> [ 1d20=19 ]{47}
> roll 1d20+26 wretches reflex
<Rei-chan> Kotono rolled : 1d20+26 wretches reflex --> [ 1d20=13 ]{39}
Does the prisons require a new batch of saves?
Anyone who's already stuck can't make saves and has to make strength/escape artist checks to try and break free. Anyone caught by the expansion as people die within the prison and it swells needs to save. Damage is taken every round while imprisoned or touching it, starting at 20d6 and going up by 1d6 for every creature killed to a max of 50d6.
Gimme another round of damage then.
[18:12] <@Ebiris> roll 20d6
[18:12] <Rei-chan> Ebiris rolled : 20d6 --> [ 20d6=72 ]{72}
[18:12] <@Ebiris> roll 20d8 for the purified one
[18:12] <Rei-chan> Ebiris rolled : 20d8 for the purified one --> [ 20d8=92 ]{92}
Your magic flies everywhere - and indeed, it seems to even slow the newborn demon lord. Antenora wretches her spear free as sunlances erupt on either side. With a tight smile you feel her courage and her simple contentment to be at your side, together with you.
Not that you have time to linger on such feelings, as...
Hawk man is up.
With sluggishness, the hawk creature lets out a deep cry. It is not a bird's cry, but a gurgling and wet sound. The winds come from that, razor winds slicing into you.
> roll 1d20+120 (+66 ???)
<Rei-chan> Kotono rolled : 1d20+120 (+66 ???) --> [ 1d20=7 ]{127}
AC?
113, but I'll use moment of prescience to make it 136 against this attack.
Alicia HP: 1120/1150
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/7/3/5/5/4/0
Duskblade spell slots: 6/23/23/21/11/6/15/3
Moments of prescience left: 2
Quick-casts left: 0
Alicia sees it coming, her blade strikes out. The wind blades are torn apart, leaving her untouched for now. Antenora is at your side, giving you some scant cover as they come. The balors surge forward even as the prison expands behind you and below you. As others are entombed the enemy draws nigh.
> roll 1d20+66
<Rei-chan> Kotono rolled : 1d20+66 --> [ 1d20=14 ]{80}
> roll 1d20+66 whips
<Rei-chan> Kotono rolled : 1d20+66 whips --> [ 1d20=17 ]{83}
AC?
113 now.
I'll take as many AoOs as I can get since I'm colossal and have lots of reach.
Alicia attacks them as they approach, clubbing them with the flat of her titanic blades so they won't explode on her, and also so they'll easily fall victim to the encroaching crystal and fuel it themselves.
[18:58] <@Ebiris> roll 5#1d20+88
[18:58] <Rei-chan> Ebiris rolled : 5#1d20+88 --> [ 1d20=11 ]{99}, [ 1d20=7 ]{95}, [ 1d20=20 ]{108}, [ 1d20=8 ]{96}, [ 1d20=11 ]{99}
[18:58] <@Ebiris> roll 1d20+84 crit check on that 20, subtract 4 from each roll since I'm hitting nonlethal
[18:58] <Rei-chan> Ebiris rolled : 1d20+84 crit check on that 20, subtract 4 from each roll since I'm hitting nonlethal --> [ 1d20=8 ]{92}
[18:59] <@Ebiris> roll 4#6d6+62+2d6+3d6 and a negative level, nonlethal
[18:59] <Rei-chan> Ebiris rolled : 4#6d6+62+2d6+3d6 and a negative level, nonlethal --> [ 6d6=22 2d6=10 3d6=12 ]{106}, [ 6d6=29 2d6=7 3d6=8 ]{106}, [ 6d6=18 2d6=5 3d6=16 ]{101}, [ 6d6=15 2d6=7 3d6=8 ]{92}
[18:59] <@Ebiris> roll 12d6+124+2d6+6d6 and 2 negative levels, nonlethal for the crit
[18:59] <Rei-chan> Ebiris rolled : 12d6+124+2d6+6d6 and 2 negative levels, nonlethal for the crit --> [ 12d6=50 2d6=4 6d6=21 ]{199}
Quick-casts left: 0
A handful around you are bashed down, the way cleared for a moment. For just a moment, as hands below reach up at you, grasping at your ankles.
> roll 1d20+60
<Rei-chan> Kotono rolled : 1d20+60 --> [ 1d20=13 ]{73}
Misses. Provokes an AoO.
[19:40] <@Ebiris> roll 1d20+88 AoO taken
[19:40] <Rei-chan> Ebiris rolled : 1d20+88 AoO taken --> [ 1d20=14 ]{102}
-4 on that for nonlethal.
[19:40] <@Ebiris> roll 6d6+62+2d6+3d6 and a negative level, nonlethal again
[19:40] <Rei-chan> Ebiris rolled : 6d6+62+2d6+3d6 and a negative level, nonlethal again --> [ 6d6=18 2d6=11 3d6=7 ]{98}
Init is Alicia (Supreme) > Broken Hawk (Supreme) > Balors = Nalfeshnee (30) > Wretched (30) > Antenora (23)
Yet Alicia's blade clears away the hands as above, the bellies of the nalfeshnee split open wider. Great gouts of green and black fluids pour forth, a rain of it down on the two of you.
Ref, both of you.
