Shadow rondo
Knew I should have used moment of prescience.
Alicia is very good at killing things.
Alicia is skilled with magic.
Alicia is logical and straightforward.
Does this count as enchantment for her to get another save with slippery mind next turn?
Alicia HP: 1030/1150
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/5/3/5/5/4/0
Duskblade spell slots: 6/23/23/21/11/6/15/3
Moments of prescience left: 2
Quick-casts left: 0
Make that save now in this case.
[17:41] <@Ebiris> roll 1d20+77+30 improved mettle using moment of prescience this time
[17:41] <Kobot> Ebiris rolled 1d20+77+30 improved mettle using moment of prescience this time --> [ 1d20=6 ]{113}
Moments of prescience left: 1
Quick-casts left: 0
> roll 1d3
<Kobot> Kotono rolled 1d3 --> [ 1d3=2 ]{2}
> roll 1d5 Syala, Antenora, Marie, Latha, Jessica
<Kobot> Kotono rolled 1d5 Syala, Antenora, Marie, Latha, Jessica --> [ 1d5=2 ]{2}
It's gone. It's all gone.
Your magic slips away. You never any good with magic. You had your blade and your anger. Your desire for bloodlust was all you ever needed. The feel of hot blood splattering on you as your foes fell was always your greatest pleasure. Magic is nothing to -
Somehow.
In one terrible moment you are two. Yourself and an Alicia who rejected magic, who hated it. Who relished in violence and destruction with her own two hands. A bloodstained monster of the battlefield. No. You are that monster and the other Alicia is a memory. A memory that fades. You remember how sweet Ferdi's blood was. You grow flushed when you remember G'renna's death cry. Malice's demise makes you smirk. Queen's death is only justice and joy for you as you lopped her head off, and you remember finally pinning that loathsome bitch Antenora down atop the Opal Mountain and...!
Too much.
Then you're as you should be, the lie exposed for what it is, Your heart hammers as spells fill your mind once more. Your breath is uneven, you gulp down air as sweat pours down your face and in your body's crevices. For one terrible moment you were two, and only by a miracle you stayed yourself instead of the other.
React.
Also your turn.
It takes a lot of Alicia's self control not to react more viscerally, but she tightens her grip on her sword. "I am provoked," she says with seething mildness, a twist of space bringing her next to the false celestial and exceptionally bloody violence following, of the kind that can only come from marrying swordplay with the arcane.
Full attack, quickened spell x2 to recast many moments of prescience where needed (after the first attack and after the fifth)
[18:31] <@Ebiris> roll 1d20+99+30 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp, many moments of prescience
[18:31] <Kobot> Ebiris rolled 1d20+99+30 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp, many moments of prescience --> [ 1d20=13 ]{142}
[18:31] <Kobot> Ebiris rolled 1d20+99+30 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp, many moments of prescience --> [ 1d20=20 ]{149}
[18:31] <@Ebiris> roll 1d20+94+30 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp, many moments of prescience
[18:31] <Kobot> Ebiris rolled 1d20+94+30 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp, many moments of prescience --> [ 1d20=9 ]{133}
[18:31] <@Ebiris> roll 1d20+94 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp
[18:31] <Kobot> Ebiris rolled 1d20+94 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp --> [ 1d20=1 ]{95}
[18:32] <@Ebiris> roll 1d20+89 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp
[18:32] <Kobot> Ebiris rolled 1d20+89 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp --> [ 1d20=14 ]{103}
[18:32] <Kobot> Ebiris rolled 1d20+89 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp --> [ 1d20=7 ]{96}
[18:32] <@Ebiris> roll 1d20+84 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp
[18:32] <Kobot> Ebiris rolled 1d20+84 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp --> [ 1d20=19 ]{103}
[18:32] <Kobot> Ebiris rolled 1d20+84 blinding speed, 14th level arcane strike, channelled maximised/vivacious flux grasp --> [ 1d20=13 ]{97}
[18:32] <@Ebiris> roll 1d20+99+30 crit check
[18:32] <Kobot> Ebiris rolled 1d20+99+30 crit check --> [ 1d20=14 ]{143}
[18:32] <Kobot> Ebiris rolled 1d20+99+30 crit check --> [ 1d20=20 ]{149}
[18:32] <@Ebiris> roll 1d20+84 crit check
[18:32] <Kobot> Ebiris rolled 1d20+84 crit check --> [ 1d20=11 ]{95}
[18:33] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+700 and 1 negative level
[18:33] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+700 and 1 negative level --> [ 6d6=25 2d6=11 3d6=12 14d4=30 ]{823}
[18:33] <@Ebiris> roll 12d6+90+2d6+6d6+14d4+1400 and 2 negative levels if 149/143 critted
[18:33] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4+1400 and 2 negative levels if 149/143 critted --> [ 12d6=45 2d6=10 6d6=22 14d4=38 ]{1605}
[18:33] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+700 and 1 negative level if it didn't
[18:33] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+700 and 1 negative level if it didn't --> [ 6d6=20 2d6=12 3d6=11 14d4=34 ]{822}
[18:33] <@Ebiris> roll 12d6+90+2d6+6d6+14d4+1400 and 2 negative levels if 149/149 critted which it clearly did because 2 20s
[18:33] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4+1400 and 2 negative levels if 149/149 critted which it clearly did because 2 20s --> [ 12d6=37 2d6=7 6d6=25 14d4=30 ]{1589}
[18:34] <@Ebiris> roll 12d6+90+2d6+6d6+14d4+1400 and 2 negative levels if 149/149 critted which it clearly did because 2 20s
[18:34] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4+1400 and 2 negative levels if 149/149 critted which it clearly did because 2 20s --> [ 12d6=33 2d6=7 6d6=19 14d4=34 ]{1583}
[18:34] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+700 and 1 negative level
[18:34] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+700 and 1 negative level --> [ 6d6=12 2d6=8 3d6=13 14d4=36 ]{814}
[18:34] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+700 and 1 negative level --> [ 6d6=18 2d6=11 3d6=10 14d4=32 ]{816}
[18:34] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+700 and 1 negative level --> [ 6d6=17 2d6=3 3d6=7 14d4=35 ]{807}
[18:34] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+700 and 1 negative level --> [ 6d6=20 2d6=5 3d6=7 14d4=39 ]{816}
[18:34] <@Ebiris> roll 12d6+90+2d6+6d6+14d4+1400 and 2 negative levels if 103/95 critted
[18:34] <Kobot> Ebiris rolled 12d6+90+2d6+6d6+14d4+1400 and 2 negative levels if 103/95 critted --> [ 12d6=42 2d6=10 6d6=20 14d4=35 ]{1597}
[18:34] <@Ebiris> roll 6d6+45+2d6+3d6+14d4+700 and 1 negative level if it didn't
[18:34] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+700 and 1 negative level if it didn't --> [ 6d6=17 2d6=6 3d6=15 14d4=33 ]{816}
[18:34] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+14d4+700 and 1 negative level --> [ 6d6=22 2d6=10 3d6=8 14d4=28 ]{813}
DC 40 fort or -10 armour/-10 natural armour inflicted by flux grasp, doesn't stack but needs to roll for every hit.
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/5/3/5/4/2/0
Moments of prescience left: 4
Quick-casts left: 0
Everything hit and critted. Total damage?
11,263.
You think I was kidding about 'very good at killing things'?
Also this, though it probably doesn't matter for one reason or another.
[18:50] <@Ebiris> roll 1d20+5 rank check to inflict negative levels
[18:50] <Kobot> Ebiris rolled 1d20+5 rank check to inflict negative levels --> [ 1d20=1 ]{6}
Crits are scary.
The figure is - gone? Torn apart? Your blade ends it, tears the nightmare asunder, banishes it back to whence it came.
No.
For one moment, you see. A lie. Just another lie.
You remember, of all things, the song that greeted your entry to Chronias. The song of worlds, sung with the Words of Creation. A song unlike any other you have heard before, a song that bids light and life to prosper. A voice sung by countless voices within that blessed place. It is of a beauty that only a few snatches of the most holy of Ebony or Moore's songs can approach, sung with all the heart and soul.
You have been to Chronias.
The voice of the false celestial fills your mind. A voice filled with the deepest loathing and furious anger.
YOU HAVE BEEN TO CHRONIAS!
The scream echos far and wide, a berserk, wild howl of the blackest anger.
"I've seen the highs and lows of Creation," Alicia says grimly, waiting for the other shoe to drop after that bit of cathartic violence.
Init is False Celestial (Supreme) > Alicia (Supreme) > Antenora (31) > Crystalline Creature (16)
In the distance, you can see points of purple light rapidly manifesting, from one to ten to a hundred, and then countless more. They're gathering together, a great mass of unknown energies.
Chance to react and then Antenora's up.
Antenora
HP: 959/959
Resources: Holy Fury 38/42 (enc) Divine Retribution 1/1 Smite Evil 9/13 Channel Energy 14/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 17/25 Divine Blast 18/18
Spells Used:
SLAs Used:
There's more and it's always worse.
But then Antenora surely knew that coming in. Hopefully she can deal with that crystal thing quickly before the purple thing finishes setting up.
Quick-casts left: 0
> roll 1d20+90 (+4 charge, +1 blinding speed, +4 fiend dread, +15 smite evil, +18 furious strike, +7 Alicia, -20 PA, divine might)
<Kobot> Kotono rolled 1d20+90 (+4 charge, +1 blinding speed, +4 fiend dread, +15 smite evil, +18 furious strike, +7 Alicia, -20 PA, divine might) --> [ 1d20=5 ]{95}]
A collision. Crystal and spear, spear on crystal. Antenora slams into it, but a shield of crystal forms from part of it, enough to check the charge. It cracks all over but holds, the two locked in a deep struggle as it flees. It flees away - but not fast enough.
The light comes. The purple light gathers together, then a beam larger and wider than a castle erupts across the landscape, the three of you consumed.
Ref save, all. This includes the crystal demon.
Antenora
HP: 959/959
Resources: Holy Fury 37/42 (enc) Divine Retribution 1/1 Smite Evil 8/13 Channel Energy 13/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 16/25 Divine Blast 18/18
Spells Used:
SLAs Used:
[17:07] <@Ebiris> roll 1d20+73 ref
[17:07] <Kobot> Ebiris rolled 1d20+73 ref --> [ 1d20=15 ]{88}
> roll 1d20+64 improved evasion
<Kobot> Kotono rolled 1d20+64 improved evasion --> [ 1d20=19 ]{83}
> roll 1d20+43 crystalline
<Kobot> Kotono rolled 1d20+43 crystalline --> [ 1d20=7 ]{50}
666 damage. Antenora made the save so none and Alicia takes half for 333. Crystalline takes full.
The blast blows past both of you. How Antenora dodges it you'll never know. She's just not there somehow as you block - it engulfs you. A massive stream of energy that flays at your flesh and chips at your bones. Yet you stand it despite the pain, enough blocked to dull the damage. But not stop it as you can see more gathering ahead, more ready to come your way.
There's no sign of the crystal creature birthed, nor of anything else.  The path is gone, only utter dark around you in every direction. You can feel the air of the realm press against you, as if trying to hold you in place. The gravity feels stronger by the moment, your body and armor heavier.
Go.
She retreats back through twisted space to regroup with Antenora. "I'll need a bit more healing to stand up to this," she asks, wishing Marie was here to use her planar perinarch spell to try taking control of the Abyss for a bit.
Although speaking of Marie? She shrinks down to the size of a thimble and grabs onto Antenora's shoulder. "Head for the source and don't slow down, I'll hold on," she says, quite literally piggy-backing off of Antenora's evasive skills. She gave them to her, it's only fair.
Move to reach Anty, swift to turn fine size, swift for quickened/maximised limited wished cure critical wounds (+104 hp after sensual blessing) standard to grab her. I'm done.
Alicia HP: 468/854
Defences: AC 119, CMD 117, spell resistance 52, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 55), freedom of movement
Stat buffs/penalties: +4 morale attack/skills/saves, +10 armour AC, +25 competence perception, +7 insight AC/ref, -6 str, +10 dex, +2 con, +2 int, +4 wis, +4 cha, +1 natural armour AC, +7 size AC/attack, +9 shield AC, +3 luck AC/attack/saves, +2 morale ability checksPerceptions: Arcane sight, 5 mile tremorsense/blindsight/scent perception +88
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/4/3/5/4/2/0
Quick-casts left: 0
