Shadow rondo
Mechanically, are you trying to use Antenora as cover?
Mechanically I'm trying to make myself an item in Antenora's inventory and thus rely on her saves instead of my own. She's carrying me, so if she evades something I get evaded along for the ride.
Alicia HP: 468/854
Defences: AC 119, CMD 117, spell resistance 52, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 55), freedom of movement
Stat buffs/penalties: +4 morale attack/skills/saves, +10 armour AC, +25 competence perception, +7 insight AC/ref, -6 str, +10 dex, +2 con, +2 int, +4 wis, +4 cha, +1 natural armour AC, +7 size AC/attack, +9 shield AC, +3 luck AC/attack/saves, +2 morale ability checksPerceptions: Arcane sight, 5 mile tremorsense/blindsight/scent perception +88
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/4/3/5/4/2/0
Duskblade spell slots: 6/23/23/21/11/6/15/3
Moments of prescience left: 4
Quick-casts left: 0
Okay.
Antenora zips forward and ahead, a narrow target as again it comes.
> roll 1d20+64 improved evasion
<Kobot> Kotono rolled 1d20+64 improved evasion --> [ 1d20=10 ]{74}
<Kobot> Kotono rolled 1d20+64 improved evasion --> [ 1d20=5 ]{69}
She'll pop two of her moments since I copy pasted without thinking.
Somehow Antenora's not there. You're racing onward and ahead as both blasts are missed, Antenora diving lower as they miss. Just in time for it appears. Another of the false celestial, thins one with a massive blade held in both hands. He screams in fury as he flies up to intercept, even as you glimpse more purple in the distance.
Behind you remnants of purple linger and they gather together, beginning to form some sort of body.
Init. Only Antenora rolls so she goes last, she rolls in case it's relevant later.
> roll 1d20+14 Antenora
<Kobot> Kotono rolled 1d20+14 Antenora --> [ 1d20=16 ]{30}
Init is False Celestial (Supreme) > Alicia (Supreme) > Antenora (30) > Purple Mass (???)
You shall be rended down to bone, and your bones cast into the eternity of oblivion!
Like a meteorite Antenora and the false celestial clash, blade coming to strike true. It is black as dried blood and emits no shine at all.
> roll 1d20+143
<Kobot> Kotono rolled 1d20+143 --> [ 1d20=19 ]{162}
> roll 1d20+143 crit?
<Kobot> Kotono rolled 1d20+143 crit? --> [ 1d20=12 ]{155}
> roll 10d8+200+2d6+2d6+4d6+4d6+23d6
<Kobot> Kotono rolled 10d8+200+2d6+2d6+4d6+4d6+23d6 --> [ 10d8=50 2d6=7 2d6=6 4d6=13 4d6=17 23d6=75 ]{368}
Beats her DR.
Antenora is impaled through the stomach, a bloody gasp as the two meet. Metal tears away as armor yields, the last foot of the blade erupting out from Antenora's back.
Go.
Antenora
HP: 591/959
Resources: Holy Fury 37/42 (enc) Divine Retribution 1/1 Smite Evil 8/13 Channel Energy 13/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 16/25 Divine Blast 18/18
Spells Used:
SLAs Used:
This'll be far enough for now. Hopping off of Antenora and swelling back up to colossal proportions, Alicia brings her blade to play on their host. "Don't come back for a third round!" she snaps as he's chopped apart into many little pieces.
Free to let go of Anty, swift to change size, full attack and swift to recast quickened many moments of prescience after attack #4.
[19:18] <@Ebiris> roll 1d20+98+30 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch, many moments of prescience
[19:18] <Kobot> Ebiris rolled 1d20+98+30 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch, many moments of prescience --> [ 1d20=18 ]{146}
[19:19] <@Ebiris> roll 1d20+98+30 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch, many moments of prescience
[19:19] <Kobot> Ebiris rolled 1d20+98+30 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch, many moments of prescience --> [ 1d20=10 ]{138}
[19:19] <Kobot> Ebiris rolled 1d20+98+30 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch, many moments of prescience --> [ 1d20=7 ]{135}
[19:19] <Kobot> Ebiris rolled 1d20+98+30 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch, many moments of prescience --> [ 1d20=15 ]{143}
[19:19] <@Ebiris> roll 1d20+93 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch
[19:19] <Kobot> Ebiris rolled 1d20+93 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=1 ]{94}
[19:19] <Kobot> Ebiris rolled 1d20+93 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=11 ]{104}
[19:19] <@Ebiris> roll 1d20+88 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch
[19:19] <Kobot> Ebiris rolled 1d20+88 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=15 ]{103}
[19:19] <Kobot> Ebiris rolled 1d20+88 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=9 ]{97}
[19:19] <@Ebiris> roll 1d20+83 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch
[19:19] <Kobot> Ebiris rolled 1d20+83 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=20 ]{103}
[19:19] <Kobot> Ebiris rolled 1d20+83 blinding speed, 13th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=6 ]{89}
[19:19] <@Ebiris> roll 1d20+98+30 crit check
[19:19] <Kobot> Ebiris rolled 1d20+98+30 crit check --> [ 1d20=11 ]{139}
[19:19] <@Ebiris> roll 1d20+83 crit check
[19:19] <Kobot> Ebiris rolled 1d20+83 crit check --> [ 1d20=12 ]{95}
[19:20] <@Ebiris> roll 12d6+90+2d6+3d6+13d4+240 and 2 negative levels if 146/139 critted
[19:20] <Kobot> Ebiris rolled 12d6+90+2d6+3d6+13d4+240 and 2 negative levels if 146/139 critted --> [ 12d6=36 2d6=5 3d6=8 13d4=30 ]{409}
[19:20] <@Ebiris> roll 6d6+45+2d6+3d6+13d4+120 and 1 negative level if it didn't
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level if it didn't --> [ 6d6=17 2d6=3 3d6=7 13d4=34 ]{226}
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level --> [ 6d6=22 2d6=8 3d6=11 13d4=31 ]{237}
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level --> [ 6d6=15 2d6=5 3d6=9 13d4=33 ]{227}
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level --> [ 6d6=17 2d6=7 3d6=12 13d4=28 ]{229}
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level --> [ 6d6=17 2d6=10 3d6=8 13d4=26 ]{226}
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level --> [ 6d6=20 2d6=9 3d6=10 13d4=27 ]{231}
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level --> [ 6d6=20 2d6=4 3d6=11 13d4=37 ]{237}
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level --> [ 6d6=16 2d6=4 3d6=10 13d4=36 ]{231}
[19:20] <@Ebiris> roll 12d6+90+2d6+3d6+13d4+240 and 2 negative levels if 103/95 critted
[19:20] <Kobot> Ebiris rolled 12d6+90+2d6+3d6+13d4+240 and 2 negative levels if 103/95 critted --> [ 12d6=48 2d6=3 3d6=7 13d4=28 ]{416}
[19:20] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+13d4+120 and 1 negative level if it didn't --> [ 6d6=19 2d6=9 3d6=7 13d4=31 ]{231}
[19:21] <@Ebiris> roll 1d20+49 SR for vampiric touch
[19:21] <Kobot> Ebiris rolled 1d20+49 SR for vampiric touch --> [ 1d20=14 ]{63}
Alicia HP: 801+240/1150
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/5/3/5/2/2/0
Duskblade spell slots: 6/23/23/21/11/6/1/3
Quick-casts left: 0
Total damage? Everything hit.
2,443 this time. Got to pace myself!
The false celestial is torn apart - gone again.
The Gemstone of Truth is suddenly warm on your chest.
You whirl in reaction. The false celestial is there, blade coming for your neck and sized to match you. Yet you are able to parry and stop it, the blow averted. A split second later and that is gone entirely. Another lie?
Meanwhile Antenora swiftly heals her wounds as...
Do we stay or move?
She just spent two holy fury to heal 220.
Antenora
HP: 811/959
Resources: Holy Fury 42/42 (enc) Divine Retribution 1/1 Smite Evil 8/13 Channel Energy 13/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 16/25 Divine Blast 18/18
Spells Used:
SLAs Used:
Keep on towards where the purple masses, it's our best shot for now.
Antenora soars ahead as far in the distance, the purple gathers once more. It's growing more intense by the moment.
Go.
Alicia shrinks down again, twisting space to bring herself closer to Antenora and grabbing on. "Just until we get close enough to do something about that."
She'll even twist space more ahead of Antenora so she can skip ahead further once she gets going.
Back to fine size and hanging onto Anty now.
Alicia HP: 505+240/854
Defences: AC 126, CMD 110, spell resistance 52, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 55), freedom of movement
Quick-casts left: 0
As you fly your wounds mend in part, restoring you.
110 HP from Antenora for you, and 110 HP for her.
Both of you flee. Both of you flee like a shot, but it's coming. Twin blasts, one after another as Antenora dodges and dives, desperately trying to avoid it all.
<Kobot> Kotono rolled 1d20+64 improved evasion --> [ 1d20=4 ]{68}
> roll 1d20+94 improved evasion popping MMoP
<Kobot> Kotono rolled 1d20+94 improved evasion popping MMoP --> [ 1d20=5 ]{99}
1 use left.
333 damage to both of you since Antenora still has improved evasion. What's your HP after that, Alicia?
Antenora
HP: 588/959
Resources: Holy Fury 38/42 (enc) Divine Retribution 1/1 Smite Evil 8/13 Channel Energy 13/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 16/25 Divine Blast 18/18
Spells Used:
SLAs Used:
632/854
Is it fleeing if we're moving towards the enemy?
Alicia HP: 632/854
Quick-casts left: 0
A fair point.
Closer. Closer. You can see it closer even as you both endure. Antenora is bloodied all over, blasted but still going.
A portal? A single purple portal is ahead. Antenora swoops to avoid it, but another appears. Another. Another. Another. In moments you're surrounded by hundreds of portals. Each one has a set of golden eyes that peer out.
YOU DID NOT ESCAPE. YOU HAVE ALREADY DIED. I WILL ESCORT YOU TO OBLIVION.
The portals surround you on every side, ranging in size from a fist to large enough for several Hannas to pass through at the same time. Antenora has to pause in the air, gaze going about as you're surrounded.
Are they actual portals to another plane or just a cosmetic effect for whatever magic or fuckery is going on here?
They seem to be actual portals, but wrong somehow. You can tell they only connect to themselves.
