Shadow rondo
Good/Silver/Epic.
Alicia HP: 1136/1150
Sorcerer spell slots: 6/16/16/12/9/7/14/4/9/0/5/3/3/1/2/0
Duskblade spell slots: 6/23/23/20/11/4/16/3
Moments of prescience left: 4
Quick-casts left: 0
Doesn't beat DR, so total damage if damage reduction is 30?
Oh sorry, that would help. AC is 100 on the dot.
Total damage from 3 crits and 3 hits is 678 and 9 negative levels.
Init is Malcanthet (Supreme) > Alicia (Supreme) > Idol (32) > Antenora (16) > Destruction (0) > Oblivion (-1)
Alicia's blade cuts into the profane idol. She draws no blood yet cuts away stone. It's hard going, resilient and tough. It doesn't go down as hunks of it fall away, and as it does...
Are you immune to petrification, and if so, from what source?
Yes, divine immunity.
Quick-casts left: 0
Rank check then. No strata bonuses apply either way.
[17:05] <@Ebiris> roll 1d20+5
[17:05] <Kobot> Ebiris rolled 1d20+5 --> [ 1d20=14 ]{19}
> roll 1d20+2
<Kobot> Kotono rolled 1d20+2 --> [ 1d20=16 ]{18}
Close.
Yet nothing more happens as you strike, and an instant later, Antenora rushes in besides you with a fearsome battle cry. Her wounds heal as she rushes in, relentless.
A heal spell this time for 150 points of healing.
> roll 1d20+100 (+4 charge, +1 blinding speed, +4 fiend dread, +15 smite evil, +18 furious strike, +7 Alicia, -10 PA, divine might) Can see it's tough enough to stop some of Alicia's hits so that means lay off the PA
<Kobot> Kotono rolled 1d20+100 (+4 charge, +1 blinding speed, +4 fiend dread, +15 smite evil, +18 furious strike, +7 Alicia, -10 PA, divine might) Can see it's tough enough to stop some of Alicia's hits so that means lay off the PA --> [ 1d20=3 ]{103}
> roll 3d8+594+2d6+2d6+10d6
<Kobot> Kotono rolled 3d8+594+2d6+2d6+10d6 --> [ 3d8=18 2d6=10 2d6=8 10d6=30 ]{660}
No rank check since Antenora has a racial immunity to petrification.
Antenora strikes a second behind you, spear driven into its stomach. More stone is broken away but the idol does not fall. Instead from it comes black tears as it whispers in your minds:
Bow. Bow and worship me.
> roll 1d20+2 Idol
<Kobot> Kotono rolled 1d20+2 Idol --> [ 1d20=10 ]{12}
Rank checks, all.
> roll 1d20+2
<Kobot> Kotono rolled 1d20+2 --> [ 1d20=19 ]{21}
Antenora's.
> roll 1d20+10 (+4 strata) Malcanthet
<Kobot> Kotono rolled 1d20+10 (+4 strata) Malcanthet --> [ 1d20=10 ]{20}
Rank check, Alicia.
Antenora
HP: 738/959
Resources: Holy Fury 37/42 (enc) Divine Retribution 1/1 Smite Evil 7/13 Channel Energy 12/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 15/25 Divine Blast 18/18
Spells Used: Heal
SLAs Used:
[17:22] <@Ebiris> roll 1d20+5
[17:22] <Kobot> Ebiris rolled 1d20+5 --> [ 1d20=17 ]{22}
Quick-casts left: 0
You resist.
Internally you want to scream. A lesser soul would break at this contact, even aborted. All it promises is bowing down to her, accepting slavery under her name. All to worship a lifeless, profane idol of no meaning. You feel it in your bones, the raw wrongness of what it is. Nothing more than a statue, a pointless idol.
Yet in the meantime destruction and oblivion war. It's enough to occupy them as they both recoil away from the contact.
Malcanthet.
Malcanthet glides forward, "Now strike it down," Malcanthet commands, as seething fury fills your veins.
Seething Fury (CL 44): +10 morale bonus to strength for you and Antenora. Melee attacks deal an extra 6d6 points of damage and count as adamantine and epic to overcome damage reduction.
Go.
Antenora
HP: 738/959
Spells Used: Heal
SLAs Used:
I absolutely want to learn that spell so a full writeup of it would be desired.
"Your spell selection is appreciated," Alicia says, glad she's not trying to cast anything with a moral component on them. Again she attacks the idol, using a stronger spell than vampiric touch on the logic it must be protected by something like a globe of invulnerability.
[17:49] <@Ebiris> roll 1d20+100 blinding speed, 10th level arcane strike, channeled vivacious black ice touch
[17:49] <Kobot> Ebiris rolled 1d20+100 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=8 ]{108}
[17:49] <Kobot> Ebiris rolled 1d20+100 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=9 ]{109}
[17:49] <Kobot> Ebiris rolled 1d20+100 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=3 ]{103}
[17:49] <Kobot> Ebiris rolled 1d20+100 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=6 ]{106}
[17:49] <@Ebiris> roll 1d20+95 blinding speed, 10th level arcane strike, channeled vivacious black ice touch
[17:49] <Kobot> Ebiris rolled 1d20+95 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=14 ]{109}
[17:49] <Kobot> Ebiris rolled 1d20+95 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=7 ]{102}
[17:49] <@Ebiris> roll 1d20+90 blinding speed, 10th level arcane strike, channeled vivacious black ice touch
[17:49] <Kobot> Ebiris rolled 1d20+90 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=18 ]{108}
[17:49] <Kobot> Ebiris rolled 1d20+90 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=5 ]{95}
[17:49] <@Ebiris> roll 1d20+85 blinding speed, 10th level arcane strike, channeled vivacious black ice touch
[17:49] <Kobot> Ebiris rolled 1d20+85 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=9 ]{94}
[17:49] <Kobot> Ebiris rolled 1d20+85 blinding speed, 10th level arcane strike, channeled vivacious black ice touch --> [ 1d20=17 ]{102}
[17:49] <@Ebiris> roll 1d20+90 crit check
[17:49] <Kobot> Ebiris rolled 1d20+90 crit check --> [ 1d20=8 ]{98}
[17:49] <@Ebiris> roll 1d20+85 crit check
[17:49] <Kobot> Ebiris rolled 1d20+85 crit check --> [ 1d20=3 ]{88}
[17:50] <@Ebiris> roll 1d20+49 SR for black ice touch
[17:50] <Kobot> Ebiris rolled 1d20+49 SR for black ice touch --> [ 1d20=20 ]{69}
[17:50] <@Ebiris> roll 6d6+45+2d6+3d6+10d4+6d6+2*15d6
[17:50] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=16 2d6=6 3d6=12 10d4=31 6d6=19 15d6=52 ]{233}
[17:50] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=19 2d6=8 3d6=7 10d4=17 6d6=25 15d6=65 ]{251}
[17:50] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=21 2d6=2 3d6=10 10d4=31 6d6=25 15d6=57 ]{248}
[17:50] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=22 2d6=9 3d6=9 10d4=27 6d6=22 15d6=57 ]{248}
[17:50] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=19 2d6=9 3d6=6 10d4=28 6d6=25 15d6=51 ]{234}
[17:50] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=18 2d6=9 3d6=9 10d4=29 6d6=23 15d6=48 ]{229}
[17:50] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=24 2d6=7 3d6=9 10d4=29 6d6=23 15d6=58 ]{253}
[17:50] <Kobot> Ebiris rolled 6d6+45+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=26 2d6=7 3d6=8 10d4=24 6d6=16 15d6=46 ]{218}
[17:51] <@Ebiris> roll 8#1d4 negative levels, plus 8 more from the weapon enhancement
[17:51] <Kobot> Ebiris rolled 8#1d4 negative levels, plus 8 more from the weapon enhancement --> [ 1d4=1 ]{1}, [ 1d4=2 ]{2}, [ 1d4=2 ]{2}, [ 1d4=2 ]{2}, [ 1d4=1 ]{1}, [ 1d4=2 ]{2}, [ 1d4=4 ]{4}, [ 1d4=1 ]{1}
[17:51] <@Ebiris> roll 1d20+5 rank check to inflict them
[17:51] <Kobot> Ebiris rolled 1d20+5 rank check to inflict them --> [ 1d20=7 ]{12}
I rolled damage for every attack that hit over 100 assuming AC is the same as last time.
Active spells: Many moments of prescience (CL 39), extended mind blank (CL 40), extended nondetection (CL 40), greater heroism (CL 37), extended ray deflection (CL 40), epic mage armour (CL 37), sensual blessing (CL 37), greater foresight (CL 39), keen edge (CL 37 on sword), dance of the unicorn (CL 37), extended greater anticipate teleportation (CL 39), repelling shield (CL 39), freedom of movement (CL 37), greater visage of the deity (CL 37), recitation (CL 37), good hope (CL 37), Latha's sunmantle (CL 40), seething fury (CL 44)
Defences: AC 113, CMD 144, spell resistance 52, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 55), freedom of movement
Stat buffs/penalties: +4 morale attack/skills/saves, +10 armour AC, +25 competence perception, +7 insight AC/ref, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -7 size attack/AC, +9 shield AC, +3 luck AC/attack/saves, +2 morale ability checks, +10 morale strength, +6d6 melee damage
Sorcerer spell slots: 6/16/16/12/9/7/14/4/9/0/4/3/3/1/2/0
Duskblade spell slots: 6/23/23/20/11/4/16/2
Quick-casts left: 0
Give me one more rank check. Good luck.
[18:00] <@Ebiris> roll 1d20+5
[18:00] <Kobot> Ebiris rolled 1d20+5 --> [ 1d20=10 ]{15}
