Shadow rondo
Broken tags.
[20:45] <@Ebiris> roll 1d20+77+30 improved mettle, many moments of prescience
[20:45] <Kobot> Ebiris rolled 1d20+77+30 improved mettle, many moments of prescience --> [ 1d20=7 ]{114}
> roll 1d20+96 Antenora is absolutely using her last moment of prescience for this
<Kobot> Kotono rolled 1d20+96 Antenora is absolutely using her last moment of prescience for this --> [ 1d20=13 ]{109}
> OOC: Would probably include the alignment +10 but she got high enough.
> roll 1d20+86 Malcanthet is prepared at least
<Kobot> Kotono rolled 1d20+86 Malcanthet is prepared at least --> [ 1d20=15 ]{101}
This time, you know the trick. You know the lies.
Ever distant but bright even now, you feel the warmth of the light of Chronias behind you. An illusion? Not quite, something real, even if unseen.
Opal light comes from Antenora as she meets the false celestial's gaze, "No." A single word, a rejection so complete that it drips contempt.
Malcanthet laughs, "I know exactly what I am, little demon." Another snap of her fingers, another wave of power over all of you.
Queen's Glory: +10 morale Charisma all. Grants an additional +20 insight to Charisma based checks. CL 44.
Go.
Purely a weekend spoiler block update.
Seething Fury (CL 44): +10 morale bonus to strength for you and Antenora. Melee attacks deal an extra 6d6 points of damage and count as adamantine and epic to overcome damage reduction.
Antenora
HP: 958/959
Resources: Holy Fury 35/42 (enc) Divine Retribution 1/1 Smite Evil 7/13 Channel Energy 12/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 15/25 Divine Blast 18/18
Spells Used: Heal
SLAs Used:
"Your lies are hurtful, but the truth hurts more doesn't it?" Alicia asks, a twist of space bringing her closer before she enlarges in size, enough to threaten all of the foes ahead with a single deadly sweep of her blade!
Five foot step, swift to change size to colossal, quickened true strike, whirlwind attack.
[14:53] <@Ebiris> roll 1d20+120 whirlwind attack, smite evil, -24 power attack, 10th level arcane strike, channelled vivacious black ice touch
[14:53] <Rei-chan> Ebiris rolled : 1d20+120 whirlwind attack, smite evil, -24 power attack, 10th level arcane strike, channelled vivacious black ice touch --> [ 1d20=9 ]{129}
[14:54] <@Ebiris> roll 1d20+49 SR
[14:54] <Rei-chan> Ebiris rolled : 1d20+49 SR --> [ 1d20=6 ]{55}
[14:54] <@Ebiris> roll 6d6+133+2d6+3d6+10d4+6d6+2*15d6
[14:54] <Rei-chan> Ebiris rolled : 6d6+133+2d6+3d6+10d4+6d6+2*15d6 --> [ 6d6=23 2d6=5 3d6=8 10d4=20 6d6=16 15d6=61 ]{327}
[14:54] <@Ebiris> roll 1d20+5 rank check to inflict negative levels
[14:54] <Rei-chan> Ebiris rolled : 1d20+5 rank check to inflict negative levels --> [ 1d20=2 ]{7}
[14:54] <@Ebiris> roll 1d4 negative levels if that goes through, +1 more from holy power
[14:54] <Rei-chan> Ebiris rolled : 1d4 negative levels if that goes through, +1 more from holy power --> [ 1d4=3 ]{3}
Alicia HP: 1136/1150
Active spells: Many moments of prescience (CL 39), extended mind blank (CL 40), extended nondetection (CL 40), greater heroism (CL 37), extended ray deflection (CL 40), epic mage armour (CL 37), sensual blessing (CL 37), greater foresight (CL 39), keen edge (CL 37 on sword), dance of the unicorn (CL 37), extended greater anticipate teleportation (CL 39), repelling shield (CL 39), freedom of movement (CL 37), greater visage of the deity (CL 37), recitation (CL 37), good hope (CL 37), Latha's sunmantle (CL 40), seething fury (CL 44)
Defences: AC 113, CMD 144, spell resistance 52, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 55), freedom of movement
Stat buffs/penalties: +4 morale attack/skills/saves, +10 armour AC, +25 competence perception, +7 insight AC/ref, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, +15 natural armour AC, -7 size attack/AC, +9 shield AC, +3 luck AC/attack/saves, +2 morale ability checks, +10 morale strength, +10 morale charisma, +6d6 melee damage
Sorcerer spell slots: 6/16/16/12/9/7/14/4/9/0/3/3/3/1/2/0
Duskblade spell slots: 6/23/23/19/11/4/16/1
Moments of prescience left: 4
Quick-casts left: 0
Give me a d100 for miss chance, thanks.
I used true strike specifically to avoid miss chance but in case it's one that doesn't use concealment...
[16:28] <@Ebiris> roll 1d100
[16:28] <Rei-chan> Ebiris rolled : 1d100 --> [ 1d100=7 ]{7}
Init is False Celestial (Supreme) > Malcanthet (Supreme) > Alicia (Supreme) > Syala? (Supreme) > Burnt Witch (37) > Antenora (20) > Severed Head (8)
> roll 1d20+3 Syala
<Rei-chan> Kotono rolled : 1d20+3 Syala --> [ 1d20=20 ]{23}
False Celestial and Witch have other immunities, head takes the negative level on the chin.
Alicia's blade cuts deep. The false celestial is blooded, blade drawing no blood but cutting deep. Syala bares her teeth as her shoulder is gashed open as she's slammed back. As the head is dashed into the ground, rising back up, Syala leaps at you with savage, hungry anger, going to tear right into you.
Provokes AoO.
[16:50] <@Ebiris> roll 1d20+77 AoO taken, same mods as the whirlwind attack
[16:50] <Rei-chan> Ebiris rolled : 1d20+77 AoO taken, same mods as the whirlwind attack --> [ 1d20=17 ]{94}
[16:50] <@Ebiris> roll 1d20+77 AoO taken, same mods as the whirlwind attack crit check
[16:50] <Rei-chan> Ebiris rolled : 1d20+77 AoO taken, same mods as the whirlwind attack crit check --> [ 1d20=1 ]{78}
[16:50] <@Ebiris> roll 12d6+266+2d6+6d6+10d4+6d6+4*15d6 if it critted
[16:50] <Rei-chan> Ebiris rolled : 12d6+266+2d6+6d6+10d4+6d6+4*15d6 if it critted --> [ 12d6=28 2d6=5 6d6=17 10d4=25 6d6=24 15d6=60 ]{605}
[16:50] <@Ebiris> roll 6d6+133+2d6+3d6+10d4+6d6+2*15d6 if it didn't
[16:51] <Rei-chan> Ebiris rolled : 6d6+133+2d6+3d6+10d4+6d6+2*15d6 if it didn't --> [ 6d6=24 2d6=10 3d6=15 10d4=27 6d6=19 15d6=55 ]{338}
-15 damage or -30 on a crit since I forgot to subtract the smite evil damage there.
Yet Syala's too fast, growing larger to pounce on you, claws out and a mouthful of teeth to tear into you.
> roll 1d20+136 (+66 ???)
<Rei-chan> Kotono rolled : 1d20+136 (+66 ???) --> [ 1d20=18 ]{154}
<Rei-chan> Kotono rolled : 1d20+136 (+66 ???) --> [ 1d20=17 ]{153}
> roll 1d20+131 (+66 ???) bite
<Rei-chan> Kotono rolled : 1d20+131 (+66 ???) bite --> [ 1d20=9 ]{140}
> roll 1d20+136 (+66 ???) crit check claw 1
<Rei-chan> Kotono rolled : 1d20+136 (+66 ???) crit check claw 1 --> [ 1d20=3 ]{139}
> roll 1d20+136 (+66 ???) crit check claw 2
<Rei-chan> Kotono rolled : 1d20+136 (+66 ???) crit check claw 2 --> [ 1d20=10 ]{146}
AC/miss chance?
118, no miss chance.
Defences: AC 118, CMD 149, spell resistance 52, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 55), freedom of movement
Quick-casts left: 0
> roll 4d10+172+3d6 crit 1
<Rei-chan> Kotono rolled : 4d10+172+3d6 crit 1 --> [ 4d10=15 3d6=12 ]{199}
> roll 4d10+172+3d6 crit 2
<Rei-chan> Kotono rolled : 4d10+172+3d6 crit 2 --> [ 4d10=29 3d6=11 ]{212}
> roll 1d8+76 bite
<Rei-chan> Kotono rolled : 1d8+76 bite --> [ 1d8=5 ]{81}
> roll 4d10+106 rend
<Rei-chan> Kotono rolled : 4d10+106 rend --> [ 4d10=27 ]{133}
DR applies. HP after that?
571/1150
Alicia HP: 571/1150
Quick-casts left: 0
Those claws sink in - and tear her chest even though they're far too small, as if they were sized to hurt her. Blood flows as she bites into your flesh, chewing noisily, "Alicia, you always beg for my kisses," she mocks as you endure, moving to force her back. It buys you precious moments as...
From the Burnt Witch comes a whisper of flame, one that caresses all of you like a lover's embrace, hot as hellfire. Flames dance around you front, sides and back as if you were engulfed in them.
> roll 1d20+47
<Rei-chan> Kotono rolled : 1d20+47 --> [ 1d20=8 ]{55}
Beats up to SR 55. Note if it doesn't beat yours. Otherwise, fort all. Pierces immunity and resistance as you'd expect here.
[17:38] <@Ebiris> roll 1d20+98 improved mettle
[17:38] <Rei-chan> Ebiris rolled : 1d20+98 improved mettle --> [ 1d20=6 ]{104}
> roll 1d20+74 mettle Antenora
<Rei-chan> Kotono rolled : 1d20+74 mettle Antenora --> [ 1d20=1 ]{75}
> roll 1d20+84 Malcanthet
<Rei-chan> Kotono rolled : 1d20+84 Malcanthet --> [ 1d20=10 ]{94}
240 fire damage all. Alicia takes none thanks to mettle, Antenora takes none thanks to mettle and Malcanthet takes half. Antenora's very happy she has divine rank to cover that 1.
Yet Alicia's seen worse, fared with worse. She endures the fire even as her front is bloodstained and bloodied now, enduring the wet sounds of Syala chewing.
Antenora is simply at your side, her hand sufficient to mend your wounds.
Antenora's up. She drops her entire lay on hands bank on Alicia for 555 points of healing. 110 more from divine succor for 665 healing. She uses her other swift for Opal Inviolability on you. It grants the following benefits:
Opal Inviolability
Abjuration [Good]
Level: Pal 7
Components: V, S
Range: Short (25ft + 5ft/2 levels)
Target: 1 creature
Duration: 1 round/level
Spell Resistance: No
This spell wreathes the target in an opal aura. The target gains several bonuses, all of which only apply against attacks from evil creatures: Spell resistance equal to 12 + caster level, +4 sacred bonus to armor class and saving throws, damage reduction 10/- and a protection from evil effect. In addition, the target gains immunity to the unholy damage of a unholy weapon, the unholy damage of a spell modified with the corrupt spell metamagic, the fear aura of devils and the form of madness of obyriths.
Meanwhile the head rises and returns to the false celestial, whispering horrid words of the Dark Speech to him.
Then, with a howl of fury, the false celestial matches you. His size matches yours as other opponents are pushed aside, just the two of you.
THERE WILL BE NO MERCY!
The Gemstone of Truth glows crimson hot against your chest.
There are many of him that fan out, but it's a lie. Only one is before you, the others little more than phantasms. As you bring up your sword to defend yourself, Syala snarling away, you can see even this one is a phantasm. A lie.
Give me a Will save.
Antenora
HP: 958/959
Resources: Holy Fury 34/42 (enc) Divine Retribution 1/1 Smite Evil 7/13 Channel Energy 12/18 Lay On Hands 0/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 15/25 Divine Blast 18/18
Spells Used: Heal, Opal Inviolability
SLAs Used:
