Fairy waltz
You play a simple melody on the harp. Nothing immediately seems to happen, you strum it well enough.
"So pretty," Jetina murmurs in her beautiful voice.
"Hm..." Moore says. "I expected something more obvious to happen."
Can I tell through a Spellcraft of 115 / K:A of 120 if it's 'activated' right now?
It has activated, yes.
"Okay, well, I turned it on and nothing untoward seemed to happen." Moore says.
Hm.
He uses his divine will to produce a piece of paper with a memory of his - his first meeting with Elena. It's just writing of the memory, but he's curious if it works this way.
He directs the power of the harp at the piece of paper with the memory written down to see what happens!
The paper crumbles away into dust right away.
"Okay..." Moore says. "What else can we do to test this? I'd really like to try it in some sort of controlled environment. Maybe... some sort of construct that has no soul but has memories?"
"You see fine," Jetina chips in.
Sylvie hms, "It's also possible that you're resistant to casual usage by your nature. I suspect a mortal bard would not be as fortunate."
Moore nods. "I don't feel it doing anything strange to me either. So I guess my question is what do we do next? I do admit that I'd like to try its ability to remove sorrow and pain from someone, but only in a very controlled environment."
"We're playing with something...hm." Sylvie goes to the window, "We should try it somewhere besides Celestia, too."
"You think it could interfere?" Jetina asks, going over with her.
"I think that if Anthraxus came here to make trouble, he'd burst into holy flames under this light," Sylvie says, "Or at least once Zaphkiel noticed him making trouble. The point is that yes, it might influence it as well."
"We could always go somewhere exciting like Limbo." Moore says with a smile.
"How about somewhere neutral?" Sylvie suggests, "Discreet and neutral. Limbo is never neutral."
"Hm... Ysgard?" Moore asks. "I'm open to suggestions."
"Safer," Jetina says, "It's not the worst."
"Far from the worst," Sylvie says, "We can find some quiet valley or peak and experiment there."
Moore nods. "All right. We may get some notice because we're visiting, but we'll deal with anything that happens." He says.
We can go hit up the Blessing Stone before we go.
Anywhere in particular in Ysgard?
