Fairy waltz
[21:36] <Nephrite> roll 2#1d20+116 Gem 1 and 1 TC
[21:36] <Kobot> Nephrite rolled 2#1d20+116 Gem 1 and 1 TC --> [ 1d20=5 ]{121}, [ 1d20=4 ]{120}
[21:36] <Nephrite> roll 2#1d20+111 Gem 2 and 2 TC
[21:36] <Kobot> Nephrite rolled 2#1d20+111 Gem 2 and 2 TC --> [ 1d20=13 ]{124}, [ 1d20=5 ]{116}
[21:36] <Nephrite> roll 2#1d20+106 Gem 3 and 3 TC
[21:36] <Kobot> Nephrite rolled 2#1d20+106 Gem 3 and 3 TC --> [ 1d20=10 ]{116}, [ 1d20=15 ]{121}
[21:36] <Nephrite> roll 2#1d20+101 Gem 4 and 4 TC
[21:36] <Kobot> Nephrite rolled 2#1d20+101 Gem 4 and 4 TC --> [ 1d20=8 ]{109}, [ 1d20=6 ]{107}
[21:42] <Nephrite> roll 2#1d20+116 Gold 1 and 1 TC
[21:42] <Kobot> Nephrite rolled 2#1d20+116 Gold 1 and 1 TC --> [ 1d20=8 ]{124}, [ 1d20=1 ]{117}
[21:43] <Nephrite> roll 2#1d20+111 Gold 2 and 1 TC
[21:43] <Kobot> Nephrite rolled 2#1d20+111 Gold 2 and 1 TC --> [ 1d20=16 ]{127}, [ 1d20=1 ]{112}
[21:43] <Nephrite> roll 2#1d20+106 Gold 2 and 1 TC
[21:43] <Kobot> Nephrite rolled 2#1d20+106 Gold 2 and 1 TC --> [ 1d20=4 ]{110}, [ 1d20=15 ]{121}
[21:43] <Nephrite> roll 2#1d20+101 Gold 4 and 4 TC
[21:43] <Kobot> Nephrite rolled 2#1d20+101 Gold 4 and 4 TC --> [ 1d20=5 ]{106}, [ 1d20=16 ]{117}
[21:51] <Kobot> Nephrite rolled 16#1d6+53+2+2d6+40+13+4 --> [ 1d6=4 2d6=9 ]{125}, [ 1d6=1 2d6=3 ]{116}, [ 1d6=3 2d6=9 ]{124}, [ 1d6=1 2d6=5 ]{118}, [ 1d6=3 2d6=10 ]{125}, [ 1d6=5 2d6=9 ]{126}, [ 1d6=6 2d6=6 ]{124}, [ 1d6=2 2d6=5 ]{119}, [ 1d6=1 2d6=7 ]{120}, [ 1d6=5 2d6=5 ]{122}, [ 1d6=2 2d6=10 ]{124}, [ 1d6=1 2d6=4 ]{117}, [ 1d6=5 2d6=5 ]{122}, [ 1d6=6 2d6=8 ]{126}, [ 1d6=3 2d6=7 ]{122}, [ 1d6=6 2d6=10 ]{128}
This is a bit confusing, but...
[21:51] <Kobot> Nephrite rolled 16#1d100 --> [ 1d100=6 ]{6}, [ 1d100=21 ]{21}, [ 1d100=4 ]{4}, [ 1d100=83 ]{83}, [ 1d100=34 ]{34}, [ 1d100=45 ]{45}, [ 1d100=93 ]{93}, [ 1d100=41 ]{41}, [ 1d100=54 ]{54}, [ 1d100=72 ]{72}, [ 1d100=20 ]{20}, [ 1d100=6 ]{6}, [ 1d100=9 ]{9}, [ 1d100=73 ]{73}, [ 1d100=67 ]{67}, [ 1d100=17 ]{17}
I'm assuming it's a 50% miss chance? I can suss out which one to hit.
{/i]
Rather lousy luck, but these hit:
[ 1d6=1 2d6=5 ]{118}, [ 1d6=6 2d6=6 ]{124}, [ 1d6=1 2d6=7 ]{120}, [ 1d6=5 2d6=5 ]{122}, [ 1d6=6 2d6=8 ]{126} [ 1d6=3 2d6=7 ]{122}
For a total of 732 damage.
More blows wound the shadow - and this time it is at least fazed enough to pause a moment. It begins to curl inwards as - !!!!
Reflex saves, all, -20 penalty.
[12:03] <Nephrite> roll 1d20+58 Moore, evasion
[12:03] <Kobot> Nephrite rolled 1d20+58 Moore, evasion --> [ 1d20=20 ]{78}
[12:04] <Nephrite> roll 1d20+50 Sylvie evasion (I assume she has some points to spend on this but not sure how many)
[12:05] <Kobot> Nephrite rolled 1d20+50 Sylvie evasion (I assume she has some points to spend on this but not sure how many) --> [ 1d20=4 ]{54}
[12:06] <Nephrite> roll 1d20+51 Kaja
[12:06] <Kobot> Nephrite rolled 1d20+51 Kaja --> [ 1d20=12 ]{63}
That already factored in the -20 on all the rolls. I don't know what Sylvie has to spend on hers and I don't think Kaja has evasion unless I missed it.
There's a gush of shadow, a wave of it. Moore dodges and Sylvie holds her ground, but Kaja is carried away, swept away thousands of feet by it. As he tumbles away Sylvie calls, "Got anything that can hit it all over?"
"That isn't really my specialty! I wish Xandra was here!" Moore shouts. "Well... actually, I haven't used it in quite some time, but... I know something that may at least weaken it."
In that case, after deliberation since she doesn't have that gun either, she'll hold pending what you pull. Shadow is up.
Wounded or perhaps simply angry, the shadow rears back. It raises its blade high and focuses in on Sylvie, before bringing it down all at once.
> roll 1d20+87 touch AC (+8 ???, +19 solitary hunter)
<Kobot> Kotono rolled 1d20+87 touch AC (+8 ???, +19 solitary hunter) --> [ 1d20=1 ]{88}
Unfortunately for it, Sylvie sees the blow coming. She's already gone when it's there, tumbling to the side.
Go.
Moore straightens himself up and looks directly at the creature. The next words reverberate with a power he's not tried to use since he fought against Sylvie.
In the name of the Master of the Illuminated Heavens, the wisdom of the Holy Mountain and the light of Chronias itself, I reject your Oblivion with one word -
Hope!
He's not done this since the Orb of Shar that we dealt with way back, but he's trying a modified version of this.
Chastise Oblivion: You can use the Words of Creation to repel and drive back Sharrans and the essence of entropy, which opposes creation. You can use this to chastise such a creature, stunning them for 1d4 rounds. The creature must be within 30ft of you. This ignores immunity to stunning (except divine immunities) and allows a Fortitude save (10 + 1/2 your hit dice + your Charisma modifier) to negate. Stunning a creature in this way deals 77d4 points of nonlethal damage to you. Failing to stun a creature only deals 7d4 points of nonlethal damage to you.
His goal here is not to stun it, but that'd be cool too - his goal is to shut down its miss chance for a round or two by repelling / weakening it.
Since I assume it'd call for it anyway, here's a Charisma check:
[13:47] <Nephrite> roll 1d20+18+18+15 charisma
[13:47] <Kobot> Nephrite rolled 1d20+18+18+15 charisma --> [ 1d20=3 ]{54}
Forgot a +2 there so that's 56.
Since I'm back but need a sec, what's the save DC?
If we go by the original stun one, it's 46.
> roll 1d20+19
<Kobot> Kotono rolled 1d20+19 --> [ 1d20=14 ]{33}
Moore's words cause the entire shadow to reel. It is knocked back from that, the entire form of it momentarily knocked out of alignment. In that moment, Sylvie...
Anything else?
He's not got anything meaningful to do here since everyone has all the buffs he can provide for the most part.
Actually, that's a lie - He'll throw out an Inspire Excellence (Charisma) to give everyone +16 competence to it.
