Fairy waltz
[blockquote]Rolled 1d20+27 : 3 + 27, total 30[/blockquote]
You genuinely aren't sure.
more Question time: can I tell if these are the real deal or just avatar copies?
'I can try and destroy the weapons, but I think they're just the copies that avatars get. It may be best for me to just further bolster all of you against her attacks. My magic isn't strong enough to dispel hers I don't think, so it may be best to just go all in and try and strike her enough to destroy the avatar. I'm open to opinions.' His words come swiftly, filled with concern - but still full of hope.
Sylvie's a little busy to reply, dodging blades stained with Kaja's blood.
Kaja manages to gasp out in your mind, 'Do something! Disarm her if you can!'
Well, if they're just copies then this should be easier...
I said earlier I reject you. I reject the Hopeless nature of your weapons!
The light of Celestia and Chronias shines even here!
Because there is always Hope!
[blockquote]Rolled 1d20+68 : 20 + 68, total 88[/blockquote] charisma
He is using his Chastise Oblivion power against the two swords - focusing entirely on trying to destroy them both.
Nice time for a crit. Roll 1d20+88.
[blockquote]Rolled 1d20+88 : 5 + 88, total 93[/blockquote]
Give me a level check, too.
[21:29] <Nephrite> roll 1d20+38
[21:29] <Kobot> Nephrite rolled 1d20+38 --> [ 1d20=17 ]{55}
I was not sure whether I should add my divine +1 to that, if not then 54.
Your words are bright and brilliant, a soft grunt from Shar's avatar. The swords seem cracked now, a few notable ones on them. Nothing ruinous as of yet, but you can see the impact your words had on them.
Shar's gaze lingers on you a moment like a funeral shroud, thick and covering every sense you have.
Oh, you want to play with things you scarcely understand, Moore?
Doing anything else this turn?
Well, whether he wanted it or not, he has her attention. That should buy them some more time.
Even you know you're not at an advantage here. If you want so badly to lose an avatar, then keep fighting us. I'll destroy your swords and prove that Hope will be victorious.
He's going to use his movement action to restart Inspire Heroics for the temporary HP on everyone again. I'm not sure Sylvie's been hit, so I think it's just Kaja that gets them.
[12:02] <Nephrite> roll 14d10 temp HP
[12:02] <Rei-chan> Nephrite rolled : 14d10 temp HP --> [ 14d10=103 ]{103}
Oh, actually I forgot, everyone has the +16 to their Constitution score, this ends up being...
Kaja: 355
Sylvie & Moore: 341
So it overwrites what they had before since it's higher.
Walk me through the HP math since it's not matching what I have.
He's also going to use his move action to Inspire Excellence - everyone gets +16 competence bonus to Constitution. If we're going to fight, we're going to fight. Of course, now I have to do math, so let me see...
+16 competence to Constitution ends up being a +8 modifier to everyone's total Constitution, so that's... I believe everyone gains 288 Hit points, does that sound right?
Buffs currently:
+22 morale bonus on attack and weapon damage rolls
+18 to Dodge AC, +18 Morale bonus to Saves
+6 to attack and damage rolls, Improved Critical Feat, +18 to threat confirmation rolls
They also gain +14 Attack rolls and +7 competence to fort saves.
Total Buffs:
+45 to attack rolls
+28 to damage rolls
+Improved Critical Feat
+18 to threat confirms for crits
Immune to any spell or effect that would inflict negative emotions, such as fear or the effects of symbol of hopelessness. Also immune to fear.
Fast healing 11, and gain damage reduction 11/-.
+16 Charisma.
Kaja
HP: 590(433)/877(581)(375 Shar damage, noting separately)
Aura: Divine 10ft (various)
Resources: Breath Weapon 1/1 Dervish Dance 13/13 Endless Cuts 3/3 +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd) 1/1 Retribution Domain 1/1 Wrath Domain 1/1
Spells Used:
SLAs Used:
Spells Active:
Notes: Goes in and wrecks things. The end.
Sylvie
HP: 1008(701)+73/1145(849)
Resources: Inspiration 24/30 (enc) Opportunistic Piety 17/17 Mimic Class Feature 7/9 Mentalism Domain 1/1
Spells Used:
SLAs Used:
Spells Active: Bibliotheca Arcana (CL37), Lore of the Gods (CL37), Superior Mighty Wallop (CL36), Sylvie's Mental Peak (CL36)
Notes:
#569
Inspire Greatness does the following:
A creature inspired with greatness gains 2 bonus Hit Dice (d10s), the commensurate number of temporary hit points (apply the target's Constitution modifier, if any, to these bonus Hit Dice), a +2 competence bonus on attack rolls, and a +1 competence bonus on Fortitude saves. The bonus Hit Dice count as regular Hit Dice for determining the effect of spells that are Hit Dice dependant. Inspire greatness is a mind-affecting ability.
So 14d10 for the first part, which was rolled. Kaja's Consitution is at +10 normally, adding +16 to his score brings it up to a +18 bonus. 14 hit dice x 18 con bonus =  252, plus the 14d10s gives us 355.
EDIT: Sorry, Moore and Sylvie are the +9, Kaja usually has +10.
