Wizard rythym
Started by Anastasia, December 01, 2020, 09:38:32 AM
"I can demonstrate it if you like," Is his agreement, "You should be able to use this through your divine will."
"Good," Emily says, "Would a heal spell work?"
"It would be sufficient in minor cases, but an advanced case like this needs a more specialized treatment." Chrona 42 explains.
It is like a twist of magic that should have always been there. Unfamiliar but right, something that feels good as you watch it, understand it.
The creature lets out a sigh of relief, before a flicker and another. "What...what was I...?"
"As you can see, the deck is wet again, to continue the metaphor." Chrona 42 explains.
Alyssa nods, "And it's fixed? Or is there follow up to make sure it doesn't reopen?"
"Alyssa," Emily says gently, "The problem's still there. He tried to fix that poor fey, not the underlying problem."
Alyssa tries to mimic the spell, to fix it.
It's easy. It flows so well, your divine will copying the spell you just did.
A moment later Emily does the same, "I didn't know I was missing so much magic," she murmurs aloud. "Not in my heart."
"There's always more to learn."
"Now then," Chrona 42 says, "I believe you have a path onward?"
Alyssa nods, "We need to get this one back to Titania and figure out what he was doing."
"Now or later?" Bastian says, "Well, once we deal with the source of the time problems."
Didn't I just fix it? That was my intention.
You fixed the problem with the fey, which was noted to recur if the underlying cause (the temporal issues here) weren't resolved.
Oh, I thought by that you meant the actual time anomaly thing. That still needs to be resolved?
Yes. As noted that has be gotten at the source.
