Wizard rythym
Started by Anastasia, December 01, 2020, 09:38:32 AM
"There's a real possibility none of these has anything to do with it," Jarem continues on, "But better to try than to do nothing."
"Unfortunately we'll have to do this the hard way and hope we get lucky," Emily agrees, "Though if all else fails, we can explore the deepest layer and see. That's where I'd hide it, but that doesn't mean it helps to find it."
Alyssa nods, "Well, until we get a better idea..."
"We can go investigate," Jarem agrees. "Who goes?"
"Me, obviously. Anyone else want to? Someone aligned to war."
Jarem steps forward. After a few moments Honeydip does the same, "The three of us can handle most threats easily," she declares, "As long as we don't try and fight an army."
Alyssa nods, "Then lets get our prep done and be off."
Okay then, to set up for next week, what's your prep here?
I'm gonna redo my spells to be a bit more combat oriented. In that vein, I assume Dolmaya would teach me her spells?
Alright, spells updated. Before we teleport over, I wanna do the key thing in the grove.
Sure.
Ianvasah's grove is quiet and peaceful. As you'd expect and hope, nothing here to disturb the quiet of it. An honorable resting place for someone lost, who gave so much for you.
Alyssa takes a moment in silence to remember her friend, then removes the key from a pocket and uses it!
That requires a door to be built. Have you done so?
You can just create one through will, this hardly  matters, but as it's a feature of the area, take a sec to describe it, integrate it in?
Oh, I misunderstood, I thought the key would like generate one. But yeah, I'll create one.
Alyssa focuses her will, calling an archway for the door into being: a pair of trees twisting together and a door, covered in bark, looking like a part of the trees and living.
It is done to your will, the door created as desired.
