Wizard rythym
Started by Anastasia, December 01, 2020, 09:38:32 AM
Alyssa considers for a moment, then uses Alter Reality to cast a quick Disintegrate spell as a demonstration.
"I just used a 6th circle spell to make a point. Consider carefully if it's worth it."
Uh, what are you targeting with it?
Nothing, just firing it into the air as a demonstration. If it has to target something, then just like the ground.
In that case, Intimidate check.
Intimidate/Cunning Knowledge:
[blockquote]Rolled 1d20+98 : 17 + 98, total 115[/blockquote]
Bastian's roll isn't needed.
Skitters. Things flee, deeper into the broken buildings and desolate spaces between them. Bastian merely chuckles as he goes and leads you along.
Alyssa strides along confidently and comfortably with a sly grin.
You are lead to a particular building - an old stone building, dusty and run down. Bastian throws the door open and enters and -
> roll 1d20+28
<Kobot> Kotono rolled 1d20+28 --> [ 1d20=9 ]{37}
Bastian catches several knives and drops them, not even slowed. "Shut up and listen, or die again."
"We have a Paladin friend we can introduce you to if you'd prefer that to a conversation."
Gimme another Intimidate check?
[blockquote]Rolled 1d20+98 : 12 + 98, total 110[/blockquote]
Inside you see two dead bodies move. They step back, faces mostly gone and with knives in hand.
"Go on, Alyssa." Bastian says.
Alyssa strides in and takes the room in, and the two undead.
It's an old room with a bit of beaten furniture. Both retreat back as Bastian says, "We're looking for a newly turned vampire by the name of Balanursk."
As one, the two point to the next room ahead, a rotten old gray curtain the only thing that serves as a door.
Alyssa decides to teleport into the room since she expects an ambush at the doorway.
