Dragon quickstep
Seira gestures for Donald to lead the way, floating an inch off the ground. There's no reason to risk a misstep and either alert an enemy or trigger a trap needlessly.
Okay, give me Stealth all, please.
Taking 10 for 91. People have Greater Heroism for +4 and Divine Insight for a +15.
CL38
Cast on all (unless refused):
Glorious Rally [1min/lvl], Celestial Valor [1min/lvl], Foresight [10min/lvl], Visions of the Future [1hr/lvl], Dragonskin [10min/lvl], True Seeing [1min/lvl], Vision of the Omniscient Eye [1min/lvl], Detect Scrying [24hr], Greater Arcane Sight [1min/lvl], Freedom of Movement [10min/lvl], Pass Without Trace [1hr/lvl], Voice of the Dragon [10min/lvl], Greater Heroism [1min/lvl], Good Hope [1min/lvl], Mind Blank [24hr], Nondetection [1hr/lvl], Mass Death Ward [1min/lvl], Heroes's Feast [12hr], Fortunate Fate [10min/lvl], Spell Turning [10min/lvl], Sign [1min/lvl], Divine Insight [1hr/level], Greater Improvisation [10min/level, 114 luck points/up to 19 usable each action]
Cast on self in addition to the above spells:
Sensual Blessing [1min/lvl], Greater Anticipate Teleport [24hr], Bibliotheca Arcana [24hr], Many Moments of Prescience [1hr/lvl], Moment of Prescience [1hr/lvl]
> roll 1d20+26 Donald
<Kobot> Kotono rolled 1d20+26 Donald --> [ 1d20=3 ]{29}
> roll 1d20+34 Sanzha
<Kobot> Kotono rolled 1d20+34 Sanzha --> [ 1d20=3 ]{37}
> roll 1d20+27 Ranbar
<Kobot> Kotono rolled 1d20+27 Ranbar --> [ 1d20=13 ]{40}
It's hot here - a cavern of some sort, buildings all in the wall. No one seems to be around - and the next door is clear. An old, forgotten storage again, filled with shelf after shelf of nails that do not melt in the heat. Another door is ahead, also trap free.
Donald taps on it thrice, then pushes in inward instead of pulls it outward. The door in the doorframe is gone, a passage into dim redness ahead.
Donald leads on - but your checks reveal something. A subtle trap just past the threshold, one to have a blade of force bisect anyone who crosses it.
Seira checks the trap over, pausing Donald with a hand on his shoulder.
Does the trap reset after triggered? Does it give off a signal if it goes off? What about if it gets dispelled?
Donald pauses without a word being said. It resets, but does not send out a signal. Nothing happens if it's dispelled - or at least that's what it wants you to think. You're good enough you can tell that it does sent out an alarm. Unless you can dispel both at the same time or disable both at the same time, of course.
Seira can, in fact, do both! And as her magic strikes down the force blade trap and the backup both, she makes sure that no further failsafes exist. It would serve as a good test of the defenses, too!
18:41 <Corwin> roll 1d20+41
18:41 <Kobot> Corwin rolled 1d20+41 --> [ 1d20=18 ]{59}
18:41 <Kobot> Corwin rolled 1d20+41 --> [ 1d20=7 ]{48}
Continuing to take 10 for 120 for detections and analysis, of course.
Got it. Both traps are undone smoothly, your magic sufficient to undo the trap completely.
Seira taps Donald's shoulder again, nodding for him to proceed. The preliminary traps are beneath her, then, and the true challenge awaits within, with Imix and his most trusted servants.
You walk in. Here is a large, warehouse-like chamber. Here various things are stored. Namely coins. Heaps and piles of copper, brass and similar coins of little value. No two seem alike, heaps and dunes of them like a desert. A single path winds through this place, surely millions of tiny coins laid out in this place before you.
What do you think of creating a bag of holding via divine will and drawing the coins into it? Seira asks the others. I think Moore had a spell for that, but it could be brute forced via divine will as well.
We hardly need Imix's pocket change. On the other hand, a rather crude man once said a great pearl of wisdom: Fuck Imix.
There's no reason to let Imix keep them, you're right.
It really is the principle of the thing, Seira agrees, producing bags of holding for all of them.
I presume it happens without objection, I'll keep an eye out for anything about to get triggered by this, either magically or mechanically via pressure plates and what not.
