Dragon quickstep
In that case initiative.
Supreme Init at DvR 6. Imix isn't 6, so either he goes first or I do!
> roll 1d20+10 Donald
<Rei-chan> Kotono rolled : 1d20+10 Donald --> [ 1d20=4 ]{14}
> roll 1d20+43 Sanzha
<Rei-chan> Kotono rolled : 1d20+43 Sanzha --> [ 1d20=16 ]{59}
> roll 1d20+23 Ranbar
<Rei-chan> Kotono rolled : 1d20+23 Ranbar --> [ 1d20=12 ]{35}
> roll 1d20+50 Imix
<Rei-chan> Kotono rolled : 1d20+50 Imix --> [ 1d20=3 ]{53}
> roll 1d20+40 Imix avatars
<Rei-chan> Kotono rolled : 1d20+40 Imix avatars --> [ 1d20=14 ]{54}
Init is Seira (Supreme) > Sanzha (59) > Imix Avatars (54) > Imix (53) > Ranbar (35) > Donald (14)
Go.
Naturally, Seira stops time.
21:14 <Corwin> roll 1d4+1
21:14 <Rei-chan> Corwin rolled : 1d4+1 --> [ 1d4=4 ]{5}
Incidentally, are the Imix avatars standing on the ground or flying/floating?
Seira puts each avatar into a Forcecage in turn, even as she moves into melee range with Imix. Along the way there, she transforms into her draconic form, though not before creating two scrolls that she uses to boost her offensive range. Elementals are summoned around Imix to harry him from the air, while lava rocks transform into obedient golems that do the say from below, and a powerful spell is gathered in Seira's claws as she reaches out to strike!
5 rounds of stopped time.
Round 1: standard to create a scroll of Strength of the Dragon Princess, move to channel Superb Dispelling with my unarmed attacks, swift 1 to generate fodder around Imix with Summon Monster VIII, free action to connect the space next to me with one by Imix Avatar #1, swift 2 to cast Forcecage around Imix Avatar #1 (windowless cell unless he's too big, in that case barred cage)
Round 2: standard to use the scroll of Strength of the Dragon Princess, swift 1 to generate fodder around Imix with Animate Objects, free action to connect the space next to me with one by Imix Avatar #2, swift 2 to cast Forcecage around Imix Avatar #2 (windowless cell unless he's too big, in that case barred cage)
Round 3: standard to create a scroll of Endurance of the Dragon Princess, move to cross half the distance to Imix, swift 1 to cast Arcane Spellsurge, free action to connect the space next to me with one by Imix Avatar #3, swift 2 to cast Forcecage around Imix Avatar #3 (windowless cell unless he's too big, in that case barred cage)
Round 4: standard to use the scroll of Endurance of the Dragon Princess, move to get all the way into melee, move to cross half the distance to Imix, swift 1 to cast Lightning's Rise (Fire variant, damage is fire and weakness is water/cold), free action to connect the space next to me with one by Imix Avatar #4, swift 2 to cast Forcecage around Imix Avatar #4 (windowless cell unless he's too big, in that case barred cage)
Round 5: standard to True Strike, swift 1 to cast Arcane Thesis, swift 2 to use Fire Devotion, free action to connect the spot immediately behind me with my origin point with Space Compression
Let's see what happens! I'm still acting when time resumes, but would appreciate an idea of what spells the Imix Avatars and Imix himself have.
So I can properly adjudicate this, could I get a CL on time stop?
21:50 <Corwin> roll 1d20+38+6
21:50 <Rei-chan> Corwin rolled : 1d20+38+6 --> [ 1d20=1 ]{45}
Okay, what spell/power is detecting magic here? I'll provide info in the next post.
You make it about halfway through. When you approach Imix and get within 300ft, you feel a jolt. Your time stop magic crumbles around you like dust, dust that catches fire and burns away brightly. You abruptly come out of time stop half completed, as...
Time stop ends in round 3 when you're 300ft from Imix. This obviously prevents the rest of your actions in the time stop.
Greater Arcane Sight.
To confirm, these actions happen:
As for round 3, can I have the swifts go off pre-move?
CL on Greater Arcane sight then.
The first two rounds happen without incident, yes.
Unfortunately no, the only fair way I could come up with was by the order you typed it and you moved by that before you used the swifts.
19:43 <Corwin> roll 1d20+38+6
19:43 <Rei-chan> Corwin rolled : 1d20+38+6 --> [ 1d20=6 ]{50}
Nothing - you can tell greater arcane sight is being blocked, unfortunately.
"Well, this is embarrassing," Seira admits before taking a step back and stopping time again.
Do you take me as a fool? DO YOU? How often do little mages like you think that one spell is victory unto itself?
No good - the spell crumbles to dust just like the last one as Imix roars in your mind, the fire red of it an inferno.
We usually think it when standing over your corpse. Let's get to that part.
