Relief
Started by Anastasia, February 23, 2021, 11:27:47 PM
#390
Inspire Competence
Inspire Heroics
Inspire Greatness (+18 morale bonus to saves and +18 dodge to AC)
Inspire Excellence (Strength, Constitution, Dexterity, Intellect, Wisdom, Charisma)
Song of Fortune
---------- All the above last for 10 minutes
Fortunate Fate (CL 39)
Jetina's Deathlessness (CL 39)
Surge of Hope (CL 35) (35m)
Celestial Valor (CL 39) (39m)
Epic Mage Armor (CL24)
Mind Blank (CL17)
Afina's Perfect Sight (CL27)
Improvisation (CL 35)
Sublime Revelry (CL39)
Energy Immunity (All)
Moore's Marvelous Invisibility (CL35)
+22 morale bonus to skill checks
+4 morale bonus on attacks, ability checks
+16 competence to all stats for 10 minutes
+8 sacred vs fear and emotion effects that would sap the will to fight, +4 sacred to attack rolls, weapon damage rolls, armor class and saving throws, weapons count as holy
+20 to armor class
+25 competence bonus to Perception, blindsight 200 ft
Immune to negative energy, energy drain, ability damage, ability drain, poison, paralysis and stunning. Half damage is converted to nonlethal damage
Half damage from physical and ranged attacks.
Effects of Mind Blank
Energy Immunity to Fire, Cold, Acid, Sonic, Lightning
*Floating Pool of 70 luck points that can be used for skills, saves, ability checks.
*Invisibility that he can dismiss when he wants to, overcomes True Seeing.
Total bonuses:
HP: 72+Con modifier (after the +16 competence bonus) temp HP (since I don't know his stats I don't know how much this is, but it should be a hefty amount)
AC: 50
Skills: 30 (Perception is 55)
Saves: 30
Anything not listed with a duration has one of several hours, so isn't worth mentioning.
Isn't Improv a personal/you spell?
Sorry, should've specified. He's using Wish to use a higher level version to give to him.
That's fine.
Thus it's time. All of you are gathered and ready as...
Go ahead and set up how you plan to kick this off and send him over, and anything else immediately done.
#394
He will send affirmations to both Bel and Selune that his operation is beginning and for them to please act accordingly.
Right outside of Hope's Landing he stands, with all his friends and comrades, in the bright light of Chronias. "We will be waiting for you in Elysium." Moore says to the Grand Master. "We will have a gate open for you and it - that is the will of Celestia today."
He does add silent prayer to Tymora - she's watched over him more times than he can count, and right now he does need just a little bit of luck for this to work out.
Moore bows again to the Grand Master. "I have every hope that this will work. May your path forward be as safe as it can be." He says.
With that, he opens a Gate as close to the lair on Brolen as he can muster.
The lair? Do you mean where you fought the Hecatoncheires?
You manage to get fairly close, the portal opened as desired.
The Grand Master regards you before, "I will serve as far as Celestia takes me." Then he's gone, on through.
"All right. It's off to Elysium. I know you all want to be there, but in this, I think I need to go alone." Moore says. "I think the less divine beings, the better."
"For once you're right," Sylvie agrees, "Good luck, Moore."
"Don't die," Cresiel adds, "Win."
He doesn't need to say anything, he simply nods to all of them and then will use his divine will to plane shift himself to Elysium.
He doesn't need to specify where on Elysium - he knows that the High One - no, the plane of Elysium itself will guide him where he needs to go. Where he needs to be, today.
Because there is always hope.
You appear in a lush green field. Sunny, warm, bright. A perfect spring day, flowers wild with life and everything bursting with beautiful colors.
Moore takes the opportunity to place the stones down, next to each other.
He then will move away - north, a good amount such that, should everything go as planned, he isn't in immediate sight.
The gate - the portal that will lead there...
Once he's moved far enough away - a mile should do the trick, he can still activate the stones from there with his voice, he knees down and places a hand onto the grass, onto the very ground itself.
"Elysium, I speak to you in the name of Hope." Moore says. "There will be two who will come this day - one seeking to guide one in need of hope, and the other who does not realize today will change them forever. I ask that you open your doors to them both so that one may be saved, and for Creation to be a better one."
[blockquote]Rolled 1d20+63 : 4 + 63, total 67[/blockquote]
That is a charisma check to be clear
There's no response that you can discern, at least.
