Sunshine
Started by Anastasia, April 30, 2021, 01:44:19 PM
The beams strike and your foes slow. Not out of swiftness, but confusion. They look about, slower. Perhaps addled as meanwhile...
Honeydip but she'll hold, since the wizard is about to wizard and she wins nothing by getting in the way of that. Emily.
Emily points with a look of quiet concentration and suddenly the world around them explodes. A meteor comes from nowhere, the stone floor now boiling lava as a massive blast of fire engulfs them all, shaking the walls.
Emily's Meteor Smite. 312 damage since auto quickened and maximized.
> roll 1d20+23 evasion
<Kobot> Kotono rolled 1d20+23 evasion --> [ 1d20=10 ]{33}
In an instant all 50, already dumbed down and surprised, are simply vaporized in fire. Magma is the only thing left around them, Emily's hand slowly lowered. A vast lava field now pops away as she says, "And that is how you cast the unrighteous into eternal damnation."
Alyssa snorts and grins, "Let's continue on before one of his Champions or Avatars shows. I won't shy away from them, but that's not our goal."
At a quick glance, any loot?
It has a bad case of being crushed and on fire, so no, no really.
"Swiftly but effectively," Emily declares as you all hurry along.
"More like gross overkill," Bastian chuckles, "Nice spell, Emily."
Give me a d100.
[blockquote]Rolled 1d100 : 89, total 89[/blockquote]
You hurry along. The ground's starting to shake and the winds scream at you - faster and faster, harder and harder. They begin to push at you, trying to check your progress as...
Got anything active that would help against that, first o fall?
Umm... I could use Alter Reality to swap spells and do Weather Control, or simply do the Shrink+Xorn Movement+Tremorsense again. The latter would probably be the fastest/safest.
I meant in the moment and active, like an ongoing spell.
Oh. Uh, don't think so. I can react with like a Quickened Planar Bubble if need be.
The winds pick up - they're checking you fast and hard, starting to push you back as...
Go ahead.
'Get close!'
Alyssa snaps off a Quickened Planar Bubble to cover everyone.
'I say we get back underground. It's worked so far.'
Your reality takes over and things calm, at least for the moment.
Emily starts to talk but BAstian shakes his head, "Before an avatar or worse shows." he says.
"...fine." Emily says, "We made our point here."
Alyssa nods, "In that case, shall we simply Plane Shift away?"
"Once we get out of here and we can. Hurry," Bastian urges, "We're on a time limit, so move!"
Alyssa nods and casts the spells for their underground movement and starts leading them away!
