Loot (Skaya)
Started by Anastasia, October 26, 2023, 03:09:25 PM
Quote from: Nephrite on May 03, 2025, 04:09:49 PM
Quote from: Anastasia on May 03, 2025, 04:01:56 PMLoot from LeBleau's house:
1 sack of platinum coins and gemstones
Devar will take 10 on Appraise for 24 to see if it's authentic and if so how much it all might be worth.
They're real. There's 1,850 gold in platinum coins here. The gems look real but aren't anything too special, they'd bump it up to 3,200 gold in total.
Quote from: Anastasia on May 04, 2025, 10:54:36 AM
Quote from: Nephrite on May 03, 2025, 04:06:46 PMDevar would like to see if there's a Rod of Bodily Restoration in Rockport!
Refresh me, you searched for this in Dareslan I believe and how did that go?
I got an 8 and needed a 1! I think. They didn't have one.
Give me another roll then. Not quite as unlikely here since it wasn't ground zero for a plague.
[13:12] <Devar> roll 1d100
[13:12] <Kobot> Devar rolled 1d100 --> [ 1d100=71 ]{71}
Once again no joy. Someone did have one, but it was bought up at a premium by a merchant who was worried about plague, before crossing the sea.
Ironic, really.
#170
-10 gold for definitely not bribery.
-5 more gold for being nice about debts.
Imp loot
Dagger
Several vials of poison, all broken by the fall.
Aglaine
This ring of plain iron is paired with another ring (one you do not have). When worn, you know the general health of the other wearer and can communicate telepathically with them. This ring is further enchanted to give a +5 competence bonus to Craft (Poisonmaking) and Knowledge (Nature) checks, as well as the benefits of a nondetection spell (caster level 7th).
Molten Silver Ring
This entirely solid ring transmutes the wearer's blood to molten silver when worn. This has none of the immediately lethal effects that you'd expect, but rather grants damage reduction 3/silver.
Ship Adventure Loot
A small quantity of gold and silver bars.
Death, The Silent Mask
This mask is said to have been forged by the yugoloths for unknown and unknowable aims. When worn, the user's face becomes ice cold as well as completely numb. This is uncomfortable, but bestows several powerful benefits.
The wearer gains a +15 competence bonus to Stealth checks. They may take 13 (as take 10 but as a result of 13 instead) on any Stealth check, no matter the circumstances. Additionally, they gain the benefit of a Nondetection spell, caster level 15th. Finally, once per day as an immediate action, the user may deal double damage on a sneak attack. This must be used when the attack is made.
Shadowleap
A ring set with a black gemstone, this ring comes with five charges per day. The charges may be used to invoke the following spell like abilities.
1-Expeditous Retreat
2-Dimension Door
3-Dimension Door + Invisibility
All spell like abilities are caster level 9th. However, the ring's magic only works when the wearer is unseen.
It's worth noting that Shar's unholy symbol has mostly been removed from the ring, but enough remains to identify it.
Gasconar's Spite
A dagger said to be a lost treasure of Gorgeland, this was wielded centuries ago by a master assassin. While the magic on it has decayed thanks to a partial purification, some power still remains. It is a dagger+2 that increases the save DC of any poison applied to it by 2. In the hands of an evil aligned spellcaster, they may add the following spells to their spell list: 1-disguise self. 2-alter self. 4-poison.
A good aligned creature who touches Gasconar's Spite suffers 1 point of ability score damage, with the ability score damaged determined randomly. This doesn't apply to creatures injured by the weapon, likely due to the partial purification.
Whisper Of Legrane
This gold armband is one noted in the histories of the northern lands, though none of you know more than that. When worn it grants the benefits of a tongues spell (caster level 5th) at all times, as well as benefits depending on the wearer's alignment.
Good aligned wearers gain access to a pool of healing identical to a paladin's lay on hands ability equal to (wearer's hit dice + wearer's Charisma modifier)*10. Should a paladin wear it, the two pools of healing merge into one. Additionally, 10 points of healing can be used to cure one point of ability damage, and 100 points to cure one point of ability drain. However, on any day the wearer does not heal at least three people in need, they suffer 1 point of Charisma damage. This damage cannot be healed until the wearer heals at least three people in need, nor can it be removed until the damage is healed. The wearer does not count as a person in need for the sake of this item.
Evil aligned wearers gain access to a pool of damage identical to a paladin of slaughter's deadly touch ability equal to (wearer's hit dice + wearer's Charisma modifier)*10. Should a paladin of slaughter or tyranny wear it, the two pools of damage merge into one. Any creature slain by this ability rises as a ghast (or similar creature if a ghast is not appropriate) that is loyal to the wearer and will not harm them. However, on any day the wearer does not harm at least three innocent people, they suffer one point of Charisma damage. This damage cannot be healed until the wearer heals at least three innocent people, nor can it be removed until the damage is healed.
Neutral aligned wearers gain no extra benefit or penalty.
It's said that there's some means to overcome the weaknesses of this armband, but the means are not known.
Nolairen
A ring of solid steel that is paired with Aglaine. When worn, you know the general health of the wearer of Aglaine and can communicate telepathically with them. The wearer of Aglaine cannot lie to you (you automatically pass all Sense Motive checks against them) and any attacks you make against them gain a +4 bonus. This includes to caster level if a spell is used to attack them.
Bellerena
This diamond is the size of a fist and sparkles with intense blues, verdant greens and lush oranges within. It's said to be a shooting star that fell, though the stories are old and faded with time. What is known that it generates one charge per day at nightfall. These charges can be stored up to a total of three, and they can be used in place of charges on other magical items.
Extremely powerful items, such as a ring of wishes or an artifact, place strain on Bellerena when its charges are used for it and may cause Bellerena to crack. Should Bellerena crack too far and break, the bearer will suffer a curse. The nature of this curse is not known.
Scroll of Cure Critical Wounds
Scroll of Poison
Scroll of Misteyes
Potion of Cure Serious Woundsx3
Potion of Cure Light Woundsx5
Diamond, 3,200 gold.
Sapphire, 1,750 gold.
Moonstone, 920 gold.
Ten purple-red agates, each worth 50 gold.
Gold and rose quartz chalice, 2,490 gold.
589 gold
Bounty for Brachidos
50,000 gold.
Tallying the gold and items worth gold (I assume we're just keeping the potions and everything) we get a total of 59449 gold in total - dividing it equally gives 11889.9 gold per person.
Unfortunately there's still no Rod of Bodily Restoration but Devar will keep looking! Are there any +5 Spellcraft items available in Rockgate, or anything else interesting he can spend some moneys on?
Give me a d100 real quick, Neph. We'll call it downtime stuff.
[12:40] <Devar> roll 1d100
[12:40] <Pixiebot> Devar rolled 1d100 --> [ 1d100=65 ]{65}
not even really good OR really bad!
There's one or two you all can get. Turns out some fame helps open doors as well.
