Box O' Yomi
Started by Olvelsper, January 11, 2006, 04:52:44 PM
Olvelsper
GM's Note: Anything that is in Yomi's box should be listed here.  If it is not, it is not here.  When something is removed in game, remove it here.
In the main lobby:
Jewelry Box, a set of unlabeled rings is inside.
A battle handbook, covering basic fighting techniques and focusing on the use of spears and staves.
The maps the party has collected.
A desk, along with other furniture furnishing the room.
1 Yomi, sometimes.
Weapon Room:
GM's Note: The descriptions are what you see if you try them out.  You do not, inherently, know the names but for ease you may refer to them OOC by which one you want.
3 part rod - This appears to be some kind of staff at first glance.  Picking it up and trying it reveals that it is actually able to be separated into three rods connected by chains.
Hex Rod - A long sturdy wooden staff that appears to have certain symbols carved into it.
Ra Spear - A spear made entirely of wood.  It looks very fragile but feels warm to the touch.
Roc Spear - A spear made of some kind of black rock, it's both dark and heavy with a very sturdy tip.
Neo Fang - You'd swear this  one was made out of bone, what appears to be a lion's fang fused at the top of it to provide a sort of strange cutting edge.
Silver Pike - Has a slight illuminscient glow to it, but otherwise a normal silver spear with a short and sharp end.
Light Rod - A slender rod, covered with paper that seems to glow with a soft white hue.  Its got a sharp tip to it.
*Rest to be done later*
Icepick=Made of a highly rigid icicle.[STR+25]
Brnz Pike=Made of durable bronze.[STR+17]
Fire Pike=Cloaked in a layer of fire.[STR+14](Fire)
Trident=Normally used for fishing.[STR+28]
Soul Wand=A staff thst increases LIFE.[STR+24]
Thun Pike=Charged with thunderbolts.[STR+35] (Thunder)
Sea Spear=The favored weapon among mermaids.[STR+37]
Geo Staff=A staff blessed by Earth.[STR+43](Earth)
Drgn Pike=Bears a carving of a flying dragon.[STR+40]
Fauchard=A knife-flipped rod used by samurais.[STR+58]
http://www.fanfiction.net/u/2589971/Ol%27Velsper : Then we will write in the shade.
Olvelsper
Here's more stuff to expand on the previous post:
JEWELRY BOX
Fire Ring=A spell for unleashing fire.
Pyro Ring=A spell for unleashing flames.
Ice Ring=A spell for shooting ice.
Snow Ring=A spell for a blizzard.
Zap Ring=A spell for lightning.
Boom Ring=A spell that zap all foes.
Geo Ring=A spell that causes a quake.
Sky Ring=A spell that voids all foes.
Ray Ring=A spell that fires a light orb.
Elec Ring=A spell that strikes all.
Grass Pin=A healing spell from Ra Tree.
Wind Pin=A spell that cures all abnormalities.
Bone Pin=A teleportation spell from Kumari.
Horn Pin=A spell shielding special attacks.
Water Pin=An invincibility spell.
WEAPON ROOM
Hex Rod=Made of sturdy wood.[STR+4]
Cry Spear=Gradually heals when equipped.[STR+3]
Ra Spear=Made from a branch of Ra Tree.[STR+6]
Roc Spear=Can shatter large boulders.[STR+8](Earth)
Sticker=Made of a thorny bush.[STR+9]
Neo Fang=Sharply tipped with Neo's fang.[STR+12]
Light Rod=A staff with a glowing tip.[STR+15](Light)
Slvr Pike=Efective against wolvws.[STR+22]
3 Part Rod=Raises DEF points slightly.[STR+48]
Lght Pike=Casts a brilliant glow from within[STR+51](Light)
X-Spear=Raises probability of critical hits[STR+40]
Hero Pike=Once beheld by heroes[STR+80]
Enbu Pike=Changes DEF into STR.[STR+44]
Alpha Rod=Changes STR into luck.[STR+53]
Block Rod=Changes STR into DEF[STR+50]
