Mihoshi and Kiyone
Started by Bean Bandit, September 02, 2002, 04:49:23 PM
CyMage
"Might as well see if it works too.  There should be a button on the side of the face."
calendar
She pushed the button, waiting to see if the same thing would happen.
 Princess_Herb turns into the sexy girl soldier, Sailor_Dragon
*** Princess_Herb is now known as Sailor_Dragon
* Unseen is vaguely creeped out
<Calendar> Only vaguely?
Bean Bandit
The seam opened, revealing an identical lens, and a similar holographic display formed above the transponder, giving all the details that the one Kiyone was holding did.
There was a as the gauges and dials settled back to normal, the locator screen identical to the one they had used to find the second transponder flashed a message.
GP Transponder detected and active. Hold switch to connect.
calendar
Mihoshi stared at the screen for a second, then held it out for her partner to see.
"What do you think?  Should I hold the switch?"
CyMage
Kiyone shrugged after reading the message.
"Sure, why not?  I don't think anything bad will happen to us if you do, and it might shed some light on what's going on."
calendar
Shrugging, Calendar pressed the switch and held it down.
Bean Bandit
Mihoshi's transponder beeped once, and suddenly filled the display with an image of Kiyone.
Kiyone's transponder in turn, beeped as well.
Transponder connection established. Open a channel?
CyMage
Kiyone blinked and pressed the button on her own 'watch' holding it in.
Bean Bandit
A similar image of Mihoshi appeared in Kiyone's display, with minute movements that matched Mihoshi's.
calendar
Mihoshi grinned at the picture of Kiyone on her screen.  "This is so cool!  Cy, do you have a picture of me on your watch?  There's a little you on mine!"
This comment brought something to her attention, though.  "Cy, I know I look like Mihoshi right now, but if you call me by her name, I'll have to hurt you, okay?"
CyMage
Looking up at Mihoshi, Kiyone smiled.  "Yes.  I guess these are communicators of some sort."
Blinking a couple times at the request, she shrugged.  "No problem.  I would rather not be called Kiyone either.  I just hope we don't have to pretend to be them."
Looking back at the watch, Kiyone searched for any other 'functions' aviable.
calendar
Calendar grimaced.  Pretend to be Mihoshi?  "But... we're going to have to, y'know.  Because how else are we supposed to act in front of the Masaki's and everyone else?"
CyMage
"We might be able to get help from them if we tell them straight away.  They probably wouldn't be too surprised."
Saying that, Cy returned to examining the watch.
calendar
Calendar frowned.  She had thought about telling them, but figured no one would believe her.  But... Cy might be right.  They were in Tenchi's world, right?  Why wouldn't they be believed?
"I guess... you're right."
CyMage
Grinning a bit, Cy nodded.  "Scary isn't it?  But it does happen from time to time."
