Team Elf's Magical Gear
Started by Carthrat, July 12, 2006, 11:19:57 AM
Seryf
Sun - A sword+2 - it adapts to either a long sword, a short sword, a scimitar, a bastard sword or a two handed sword at the will of the wielder. It counts as +2 to hit/damage, scoring triple damage on trolls or regenerating creatures. Such creatures cannot heal the pain from this sword via regeneration. (However, magical healing such as clerical magic mends it correctly.)
Moon - A glove. No weapon can be used in this hand when it is worn, yet none needs to be. A tiny disc of force appears over this mythril mesh gauntlet, moving in time with it. It can be used in one of two ways at first - as a shield that counts as a buckler(Effective vs one attack per round) or as a short sword/dagger.
Further, the hand wearing this gauntlet is nearly invincible - nothing normal will cut it, flames fail to heat it, frost does not chill it. Effectively, the gloved hand is immune to damage of anything less than a fourth level spell - however, dipping up tyour arm in acid will eat through the forearm to shoulder just fine - only the hand is safe.
Should the glove be directly targeted by an effect that can damage it, it possesses 20 HP. It heals 1 HP per hour, and breaks apart forever if it runs out of HP.
10 Sheaf Arrows +2
Darius
Scimitar +1, Quickness (acts first every round)
Elaine
Silmara, Broad Sword +1, +2 on all saves vs. mind-affecting magic
Magic Boots (Doubles movement, +30% to move silently/hide in shadows)
Magic Dagger (Frosthammer)
Pendant of Protection +1
Saul
1x Green Ball of Revitalisation
Ring of Wizardry I (doubles 1st level spells)
Ring of Missile Avoidance (-2 to AC vs. ranged, +2 to saves vs. projectiles)
Arcanist's Red Dracoflint (+1 to caster level, additional +1 to caster level for fire spells)
Alluring Coin
Magic Sealing Tube
Mace of Disruption +2
Gavin
Rose Pin (+4 vs. fear, paralyation, 'evil' magic)
Periapt of Poison (+4 vs. poison)
Broad Sword +1, +2 vs. frostkin
Medium Shield +1
