The old topic
Started by Anastasia, January 28, 2003, 07:40:17 AM
OOC: Except for the man, there is no one left to hear your goodbye. They all went to get this 'Jackson'.
CyMage
"Time to leave my friend.  We'll find no shelter here."
He started helping Carthrat to his feet.
"Riiight."
Carthrat springs to his feet and heads for the window, assuming trouble at the door from CM's words..
You escape the house...
As you flee, you can hear the stomping of fast moving feet out front.
"Let's split and meet up back at that restraunt. One person hides easier than two, yaddayadda."
Carthrat runs off for the exit from the lot that's furthest from the house..
OOC: If there's only one entrance, then we'll run out and go in opposite directions, right?
CyMage
Vanishing from sight again, Cy made his way towards another exit from the lot.
Both of you slip away without incident, a backpath from the house leads you safely away.
An hour later, you both arrive at the restaurant. Neither of you ran into anything of note.
CyMage
Making himself known to Carthrat, Cy mussed.  "Well, that place was a waste of time.  Want to see if our friend the blacksmith will offer us a place to stay for a few days?"
"Yes. Yes we will," Carthrat says. "You be the spectre, I'll be the medium. Will that work?"
CyMage
"Sure.  Anything specific you want me to do for the act?  I'll tell you now though, no sound effects."  Cy glared at Carthrat though the effect was kinda lost due to him still not being visible.
"I don't know. Make stuff look like it's levitating. Cast some spell which gives you a tangiable... you know, 'feeling'.
Just give evidence that you're *THERE*. I'll do the rest."
Carthrat looks down at the sword on his belt.
"Been a while since I exercised my training.. who'dve thought it'd be so effective, eh?"
CyMage
Sai nods, once again a useless gesture.  "Ok.  Lead the way then."
Carthrat ponders for a moment, realising that it's actually *quite* late at night.
Shrugging, he pulls his cloak around himself, and heads towards the blacksmith, figuring it's probably shut at this time of night..
As you travel the few blocks to the blacksmith, you note this city is rather well lit. Glass globes embedded into buildings provides good light in the commerce center.
CyMage reconizes this as Continual light cast on glass globes. It's a fairly common practice, even with technology, among mages. One glass globe lasts several years. It's one of those things that pops up in many dimensions.
The blacksmithery is dark and quiet when you get there. No one happens to be around, not street guard or ruffian.  The door is made of wood and looks to be solid.
CyMage
"Do we go in and try to get some sleep in there?  I can take care of the lock if we go in."
