Re:Derelict: Season 1.
Started by Carthrat, February 18, 2003, 02:01:28 AM
Rezantis
Nodding, Relm turned and stepped gingerly across the ruin of the floor to the door that had opened for the monster, moved into the corridor and started walking to the other end, looking about her curiously.
The entire corridor was made of a strange, smooth, black metal that had not collected any dust and had no markings; with the exception of several, roof mounted glowing lamps, lighting the room with an eerie red tinge..
While walking through the corridor, Relm felt lighter, somehow.
Rezantis
Putting the feeling of lightness aside to her current mental state (splitting headache), Relm walked up to the door and examined it, looking for a way to open it or anything else of interest.
The door itself is made of a grey metal. Part of the wall juts in for the door; the edge of the door is lined with dim, red lights.
The panel next to the door is lit up with a keypad of digits, a red button, and a white button.
Rezantis
Relm rapped on the door, trying to guage an idea of it's thickness.
Relm quickly discerns that the door is quite thick and solid. It feels like it's not going to get knocked down easily, definately.
Rezantis
Rubbing her temple with her left hand, Relm tentatively pressed the white button.
Another loud *BEEEEP!* echoes through the corridor at Relm's touch..
Rezantis
Jerking her hand back reflexively, Relm paused a moment, then tapped the red button.
Rezantis
"Hm."
Mentally admitting the fact that she really had no idea what she's doing, Relm walked back down where she came from . . .
CyMage
Sebastian went through each of the choices in the taskbar, looking for anything explaining what the program did.
OOC: Ack! Gomen, Panda. And I'll reply to CM when I get home. o-o
IC: At the other end of the corridor was a collection of wires and pipes, seemingly just thrown together in a random pattern. The wires were colour coded and labelled with unfamiliar markings.
One of the pipes appeared to have been ruptured; Spite could not sense anything leaking from it. The cause of the rupture isn't easily discernable; however, small, icy flakes seem to be attached to the hole..
thepanda
The queen studied the area. There were colored strings inside that hard box that opened doors. Where had these colored strings come from?
Sebastian came across the following options..
File
Open
Save
Find
Exit
Edit
Undo
Redo
Merge
Open Subroutine
Merge Subroutine
New Subroutine
Clear String
Test
Run
Stop
Switch
Bio
Display
Select
Switch
Prog
Edit
Results
