Re:Tomb Omake: The Tomb of Delphi
Started by Dracos, February 17, 2003, 11:36:31 PM
Genma stepped up to the door, he could see the fine wood ceiling, the three japanese sliding doors, the three bonsai all to the left of each of those doors, and the two nice looking bonsai on either side of the door he stood before.  The floor was tiled.
Fearless Leader
Figment
Genma examined the tiled floor.
Carthrat swears to himself, and dives into a roll underneath the big thing in hope that it'll give him up and find someone else to eat.
And with any luck, it won't sit down.
Genma saw a beautiful dragon pattern of silver designed into the tile floor.  The floor was completely flat and level.
Fearless Leader
Kwokinator
Yokoshima roughly shoved the man back.
"Deal with it now!"
Carthrat rolled towards the beast, moving as fast as he could as he slid under the beast's head...  as the beast brought down one of it's sharp limbs, spearing Carthrat as he tried to roll under and dragging the bloody corpse back out.
Fearless Leader
Life sucks and then you die..
"Shisho!"
Now, Kwok, should I ever die, I've gone on to a better place. Under no circumstances are you to ever, ever, EVER bring me back to life.
An evil plot hatched in Kwok's mind as he decided upon his course of action...
And so, he began heading in the opposite direction to the monster, keeping low, and scooping up whatever rifle or weapon he came across first..
thepanda
Onion tried to determine the opening mechanism for the doors. If they were the same as the others they would be fairly easy to get into.
To Yokoshima:
"Oh, you play rough...Fun!"  The young man grinned as he suddenly shed his tuxedo, revealing before Yokoshima the most horrifying sight he'd ever seen.  In leather straps and with very black tight pants that accented his throbbing member, the formerly tuxedo'ed man slapped a bullwhip against his side before lashing out with it, ensnaring Yokoshima's legs.
Fearless Leader
The creature continued down the path, slaughtering more as he crushed what lay before him.
Kwok, lucky kwok, was quickly able to find a rifle on the ground.
For one, it had a series of indentations above him.  For the other it had a familiar type of handle.
Fearless Leader
thepanda
Onion climbed the wall above the door with the familiar handle and used his psuedopodia to open it.
The door opened with a mighty hiss as a wave of heat came through the door...
Fearless Leader
thepanda
~HEAT!~
Onion grasped the wall above the door with psuedopodia and gently lowered himself enough to see into the next room.
Inside there was a large room with four huge braziers arrayed in the corners, glowing with large flames.  In the center a huge circle with a pentagram inside was errected.  A torch sitting at every point of the star.
Fearless Leader
