A Cardcaptor, a Paper User and an Explorer walk into a bar..
Started by Bean Bandit, February 28, 2004, 11:46:19 AM
Ginnezumusha
Ginn uses he budding piloting skill to make the craft take off, and circle upwards towards a target ceiling.
Bean Bandit
Spike smoothly lifted off, and brought Swordfish to the desired height in a slow spiral, his command of the Aircraft improving with every moment he operated it...
CyMage
After getting his bearing back, Sai looked into the direction the sounds came from.  A pair of binoculars was ready to make an appearance if for some reason he couldn't get a good look.
Bean Bandit
Tokyo looked pretty much as one would expect a teeming metropolis to look. Houses, businesses, all of the usual...though there did seem to be some commotion in one of the residential districts, near a small wooded area. It was still a fair ways away, so some smoke, and motion from large objects were all that could be made out...
CyMage
Pulling out the binocs, Sai tried to make out some details...
Bean Bandit
The binoculars provide Bolt with a closer look, but it doesn't add too much to what he already knows. The action appears to be taking place at a shrine of some sort, and there's been damage to it, as well as some of the surrounding trees.
Bolt can also see flashes of color moving amongst the foliage, bright orange, red and white among them, and there appeared to be a fire nearby. A loud noise caught his attention, and a writhing mass of metal rose slightly above the treetops, a grotesque looking head screaming...
CyMage
"Whatever that is, I think we're headed that way."
"Might as well take us down, Ginn.  Need to tell the others."  As he said that, he pulled the binoculars away and snacked on them.
Ginnezumusha
Ginn raised an eyebrow to the snacking, but did as he was told, taking the plane down back towards the others.
CyMage
Once the fighter was down and the two men got out, Sai motioned the others to come closer.  "I think that we need to head towards that disturbance.  Whatever is going on there will either involve one of the sides in this fight or both."
Bean Bandit
Nenene looked curiously at the big man, frowning a little. "Where is it, exactly?" She wondered.
Ginnezumusha
Ginn points in the general direction of the disturbance.
Bean Bandit
OOC: *pokes you all* Uhm...Hello out there? Kwok, Ra-chan? Do I need to get out the poking stick? >_>;
Nenene frowned. "Can you be a bit more specific? Without some sort of directions, getting there in a car would be hard...Unless that plane of yours is roomier than it looks."
Ginnezumusha
Bean Bandit
In lieu of an answer, Nenene simply jerked her thumb behind her where her car was still parked, nodding.
Ginnezumusha
"I think if you drive in the general direction, you'll be able to see it soon enough."
