To Far Away Times
Started by Brian, April 04, 2004, 01:55:07 AM
Dracos decides to continue the relatively relaxed hunt for the rest of the group.  In the worst case, at least they are getting a damn good feel for the castle.
From the rear battlements, you think you see Paul walking along the southern training field, though he's some distance away.
Dracos tries to ascertain where he's headed, and heads, at the same relaxed pace, in the same general direction, not making a ruckus about it.
Well, it's a pass, with pretty much sheer cliff walls on either side.  It's pretty easy he's going in one of the two directions that it's possible to go in.  Catching him will be a different matter.
Either way, you and Nathan set off across the field, heading south and keeping your eyes peeled for Paul.
Paul appears to see you, and turns around to meet up with you.
This thread temporarily joins Secret Game
Your search for Bjorn is interupted almost before it begins as, ahead of you in the corridor, you hear a door shutting heavily.  When you look up, a pair of guards look astonished to see you, then salute Phil sharply.  "Sir Bloom," the one on the left calls, gesturing to the door.  "Sir Lammermore has requested your presence, along with Lord Kevin and Madame Mirallia."
Rezantis
Rez turns his head, and raises an eyebrow at Drac.
Dracos instantly went into command attitude.  "I see.  Where is he now?"
The soldier points at the door directly behind him.  "This way, if you don't mind," he says, opening the door.
This thread temporarily joins Stay.
Bjorn walks away, leaving the pair of you in the corridor in front of Lord Kevin's chambers.
Dracos heads inward to Lord Kevin's chambers.
Rezantis
Rez tags along, a couple of steps behind and to the side of Drac.
The guards halt you, announce you, and then usher you in.
Lord Kevin and Sir Lammermore are there, though Mirallia is gone at this point.  "Ah," Lord Kevin asks, "and, did you have any luck with your Lorekeeper?"
"He's currently speaking with Radagast.  He seemed to have had some fortune, but wanted to ponder it more with the older wizard.  I could not get more out of him."
