Maps
Started by Sierra, November 16, 2008, 08:37:44 AM
Sierra
Okay, tossing this out for you guys for planning purposes. Floor plan of the Black Wind. I intend to put up a basic layout of the Ouna research colony as well, just in case you wind up going on the raid.
http://img389.imageshack.us/my.php?image=blackwindxv7.png
Red spaces are doors, blue represents the lift.
Upper deck: Rec room. The narrow space at the back is a rudimentary kitchen/food storage area. Brown squares are various bits of furniture.
Main deck: Yellow space = crew quarters. Four-square space in back is the engine room. Note that some floor/wall panels may be removed to access the innards of the ship's mechanisms, and that this interior space may not be shown on the floor plan. The room at the front end is the bridge, with the brown spaces representing workstations (two up front = pilot/copilot, top and bottom = gunner positions, two in back = commander's station plus various sensory/communication readouts).
Lower deck: Four-square room = infirmary. The room above that = locked storage compartment. The room in the back is the brig, with the green spaces being cells (though you haven't been there yet, pointing out how many cells there are isn't exactly a major spoiler).
Sierra
#1
Floor plans of the Ouna research colony, should you goons actually wind up going on the raid. Lorna appears to have given you the original blueprints for the compound. Assuming they didn't change anything when building the place, this is what you should find inside:
The extension at the lower left is the main airlock. There appear to be no other significant entrances, so that's where you'd be coming in unless you decide to blow a hole through a wall somewhere. The room immediately adjacent to the airlock is a foyer; the blue squares are stairs leading to the second floor. Proceeding right, the next square room is labelled "Admin" and the one at the end is simply "Security."
Moving north from the foyer are two research labs (the brown areas are apparently the intended positions of workstations). The green areas are labelled "Data storage" (left) and "Sterile area" (right). Anything sellable is probably here.
Second half of the first floor. Yellow squares are listed as quarters for technicians/maintenance/support staff. (Apparently the architects weren't too concerned about these folks getting out in an emergency). The large space up top is labelled "Coring room."
Second floor. The northern wing is supposedly quarters for the research staff; the eastern wing is for the security staff (the blue box at the end is a lift). Note that the room in the lower left corner is essentially a terrace overlooking the foyer (so yes, people could shoot at you from up there).
