Oh hey, did you just see what I found?!?!
Started by Anastasia, September 23, 2009, 01:18:48 AM
Sierra
Sounds good to me, Dune. Not getting cheated, yay.
I could try disable device, but I need at least a 14 to pull it off. Bad odds. Is taking 20 an option?
There is an appraiser in town! He charges 3% of the item's value to appraise. That okay with you guys?
It isn't, unless you don't mind failing over and over and over. Take 20 assumes you can make mistakes and keep going.
Zephyrus
Fine with me. I'm willing to share in the cost, as I have a decent amount of GP left.
Sierra
I'm inclined to say skip the bag and worry about it when we have more time to spare, really. Like, sometime when Mari getting poisoned and knocked out for 24 hours won't set back group plans.
Quote from: Zephyrus on December 16, 2009, 02:43:37 PM
Okay.
Agate: 75 GP.
Fine polished quartz: 43 GP.
So that costs 3 GP, 5 SP and 4 CP. Going to sell everything now?
Zephyrus
I'll wait for party consensus. They might want shiny things.
Mmm.
It deals 1 point of damage and absorbs blood if tried to open.  Does it do that with the string?  Does it still do that if, say, we gently cut the bottom out with a knife when its in its non-defensive state?
It'd destroy one magical item, for sure, but, it would let us at whatever said magical item was protecting, which odds are to be more valuable at least informationwise.  It's somewhat hard to even sell right now, given it's a magic item with something in it that we don't know how to open.  Was someone looking for a poisoned bag of hiding precious really?
Nothing about the identify indicates that this would fail when the bag isn't charged, though it would most likely destroy it as well. As for the contents inside, that depends on the contents.
Checking on the bottom.  How heavy does the bag seem?  Can we make any guess from touch on what's inside?  Whether its solid stuff or soft or paperish?
VySaika
No objection to the sell and divvy plan. Also kinda agreeing with Cid on the bag, though I won't shed any tears if Kam just cuts it open.
All About Monks
<Marisa> They're OP as fuck
<Marisa> just by being monks
Quote from: Dracos on December 17, 2009, 12:30:23 AM
It's a bit heavy and fairly smooth - more like a solid object rather than something loose. It's firm to the prodding, though it has a slight bit of give if you keep poking it.
Alright.  Giving anyone time to object, before Kamvakua would get it open the direct way.
I don't care about the bag, but I would care if the stuff inside broke?
Well, of course I'm assuming I can get it out without breaking it.  there's a little give, it's a solid object.  A careful cut should release it.  A penny-ante knife should be up to the job.
Last call on objections. If there are none, I'll assume Kam opens it up shortly.
